can the PaperUI Control Tab entrys be edited, to remove unused tabs and rename in use tabs ?
Control tabs are location groupings e.g. rooms, which you can provide on thing level (edit thing > “Location” field)
…of course you can use it for any kind of grouping you like.
For the unused tabs I have no clue (assuming you meant by that “no items are there”)
Bear in mind PaperUI is an administrator’s toolbox, it doesn’t really have the prettyfication options of the user facing UIs.
I have no problem with pretty, its just unused tabs, that could just not be used by the GUI, if I found the storage I would edit it I guess
