- Platform information:
- Hardware: Raspberry Pi3
- OS: Openhabian
Hi
Since upgrading to latest snapshot #1414 earlier today, PaperUI has stopped working and no UI’s now appear on the dashboard. The following is logged on startup…
2018-11-06 20:33:22.576 [INFO ] [org.eclipse.smarthome.ui.paper ] - FrameworkEvent INFO - org.eclipse.smarthome.ui.paper
org.osgi.framework.BundleException: The bundle class path entry "patch/" could not be found for the bundle "osgi.identity; type="osgi.bundle"; version:Version="0.10.0.201811061504"; osgi.identity="org.eclipse.smarthome.ui.paper"; singleton:="true""
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassPathEntry(ClasspathManager.java:174) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.buildClasspath(ClasspathManager.java:152) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.<init>(ClasspathManager.java:81) ~[?:?]
at org.eclipse.osgi.internal.loader.EquinoxClassLoader.<init>(EquinoxClassLoader.java:43) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.createClassLoaderPrivledged(BundleLoader.java:316) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.getModuleClassLoader(BundleLoader.java:233) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findEntries(BundleLoader.java:819) ~[?:?]
at org.eclipse.osgi.container.ModuleWiring.findEntries(ModuleWiring.java:289) ~[?:?]
at org.eclipse.osgi.storage.ManifestLocalization.findResource(ManifestLocalization.java:199) ~[?:?]
at org.eclipse.osgi.storage.ManifestLocalization.lookupResourceBundle(ManifestLocalization.java:130) ~[?:?]
at org.eclipse.osgi.storage.ManifestLocalization.getResourceBundle(ManifestLocalization.java:101) ~[?:?]
at org.eclipse.osgi.storage.ManifestLocalization.getHeaders(ManifestLocalization.java:64) ~[?:?]
at org.eclipse.osgi.storage.BundleInfo$Generation.getHeaders(BundleInfo.java:125) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.privGetHeaders(EquinoxBundle.java:462) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.getHeaders(EquinoxBundle.java:457) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.getHeaders(EquinoxBundle.java:451) ~[?:?]
at org.apache.aries.spifly.BaseActivator.getAllHeaders(BaseActivator.java:133) ~[?:?]
at org.apache.aries.spifly.BaseActivator.addConsumerWeavingData(BaseActivator.java:95) ~[?:?]
at org.apache.aries.spifly.ConsumerBundleTrackerCustomizer.addingBundle(ConsumerBundleTrackerCustomizer.java:37) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183) ~[?:?]
at org.osgi.util.tracker.BundleTracker.open(BundleTracker.java:156) ~[?:?]
at org.apache.aries.spifly.BaseActivator.start(BaseActivator.java:79) ~[?:?]
at org.apache.aries.spifly.dynamic.DynamicWeavingActivator.start(DynamicWeavingActivator.java:37) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309) ~[?:?]
at org.eclipse.osgi.container.Module.doStart(Module.java:581) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:449) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
I believe my rules are still working ok and item states are being updated, but I’m unable to access any UI to manage the system.
