Is there anything after these two entries in the log:
OH-thingHandler-5 2019-10-01 08:09:25.736 [DEBUG] [l.communication.AbstractCommunicator] - Socket time out occurred. Informing listener. Request={}. Exception=
java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream.java:210) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:?]
at java.io.DataInputStream.read(DataInputStream.java:100) ~[?:?]
at org.openhab.binding.paradoxalarm.internal.communication.AbstractCommunicator.receivePacket(AbstractCommunicator.java:141) ~[?:?]
at org.openhab.binding.paradoxalarm.internal.communication.AbstractCommunicator.communicateToParadox(AbstractCommunicator.java:105) ~[?:?]
at org.openhab.binding.paradoxalarm.internal.communication.AbstractCommunicator.communicateToParadox(AbstractCommunicator.java:112) ~[?:?]
at org.openhab.binding.paradoxalarm.internal.communication.AbstractCommunicator.submitRequest(AbstractCommunicator.java:98) ~[?:?]
at org.openhab.binding.paradoxalarm.internal.communication.EvoCommunicator.readRAM(EvoCommunicator.java:229) ~[?:?]
at org.openhab.binding.paradoxalarm.internal.communication.EvoCommunicator.refreshMemoryMap(EvoCommunicator.java:218) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
OH-thingHandler-5 2019-10-01 08:09:25.745 [TRACE] [arm.internal.communication.SyncQueue] - Removing from queue request=RamRequest [getType()=RAM, getRamBlockNumber()=9]
Nothing after that. I have copied opehnab.log in the TXT and there was no relevant line.You can see that this is the time what in paradox log as well. It is strange for me, thatâs why I had mentioned that I had internet outage in that time, probably it caused mess. Normally it should not affect it, as it communicates locally. I have restated and will see next ones.
OK. Thanks.
As I donât see this behavior locally at home and I also donât see in the code a meaningful reason the bridge handler to be null when the timeout occurs, I will have to simulate that. I have some ideas how to do so.
Please give me some time. Hope I can have a look at it during the weekendâŠ
I am rather new to openhab but I have thus far managed to get quite a few things working (Insteon, Zwave, Rachio, âŠ).
I just started trying to use the Paradox binding to communicate with my IP150/EVO192. After installing the binding I added the following paradox.things file, based on the online doc:
Note that for the real value of ip150Password given in my file is the same one as I need to type in the field âPanel user codeâ in order to do a manual login through the IP150 web page at 192.168.0.200. Perhaps this is not correct?
After restarting openhab, I found in the log that the things file has been read in. However, a bit later in the log I get the following warning:
2019-10-03 16:59:56.556 [WARN ] [l.handlers.ParadoxIP150BridgeHandler] - Initial communicator not coming up online for 10000 seconds. Probably there is something wrong with communication.
And just a bit later the following error message:
2019-10-03 17:13:07.819 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.paradoxalarm.internal.model.ParadoxPanel.isPanelSupported(ParadoxPanel.java:75) ~[?:?]
at org.openhab.binding.paradoxalarm.internal.handlers.EntityBaseHandler.initializeDelayed(EntityBaseHandler.java:58) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) ~[?:?]
at java.util.concurrent.FutureTask.run(Unknown Source) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
at java.lang.Thread.run(Unknown Source) [?:?]
have you read the README?
Please make sure you provide both your IP150 password and the so-called PC Password which is something like a PIN from your system setup. Can be seen when entering in configuration mode from keyboard on section 3012. Default value is 0000.
Please check this: https://www.openhab.org/addons/bindings/paradoxalarm/
Not sure what README you are referring to. I had read the bionding doc page but unfortunately I had no clue what âcode 3012 settingâ meant. Now I think I understand it is part of the programming mechanism available through the keyboard of my alarm panel. And it seems that I need the installer to help me with finding out that code. Right?
Iâve made a new binary for you. Tested it locally by simulating timeout. Found the bug and now it should be fine. At least I was able to reconnect when simulating.
Please give it a try and let me know if it works so I can make a PR. Hopefully we can make it in the next milestone release.
The installer provided me with a 4-digit value for âaddress 3012â which is different from â0000â. Unfortunately, after entering this new value for pcPassword, I am still getting the very same error messages as before.
Could it be that I also need to provide a value for ip150Password that is also known to the installer and is different from âpanel user codeâ value that I use to login on the ip150 web page (and same as I provide on my alarm keypad)?
The code I need to enter at that point happens to be the same as my pin on the alarm keypad. On the IP150 log it is then reported that âuser1: PIERREâ has entered his code. Thus the value I am currently providing for ip150Password is in fact my pin on the alarm keypad. I do not know whether or not I should be provided with a different value.
As explained in my latest reply to Konstantin, the installer provided me with what is apparently the correct value for pcPassword.
Unfortunately using that pair of values in paradox.things does not result in a successful login through openhab.
Thatâs just a wild guess that your IP150 is with the ânewâ firmware. I guess this is the firmware that supports the cloud services but I have no experience with it. Can you post which version is your IP150 pls?
It is the new one. I think it wouldnât work with that integration. I had bought with old one as it is still in the market. With some tricks new one can be downgraded as well, but it can be done by the installer.
Oh: I see⊠Thanks for your diagnostic. I will check with the installer about âdowngradingâ my board. Any chance you will be able to integrate the new version in the future? Thanks again!
if Paradox âopensâ their API we could integrate that easily but the old way has been a result of reverse-engineering by few people from the community. As far as I know currently there is no any open API by Paradox aside from the one for Windows using a DLL library.
