First of all, thank you for your answer and great binding!
I’d attached paradox.log.
As far as I can see, the problem is that both comunicators gets the same IP address and one is timing out…
See those lines:
2022-10-31 15:20:03.894 [DEBUG] [l.handlers.ParadoxIP150BridgeHandler] - Phase2 - Creating communicator for panel EVO192
2022-10-31 15:20:03.897 [DEBUG] [.communication.ParadoxBuilderFactory] - Creating new builder for Paradox EVO192 system
2022-10-31 15:20:04.082 [DEBUG] [l.communication.AbstractCommunicator] - IP Address=10.10.6.10, TCP Port=10000
2022-10-31 15:20:04.099 [DEBUG] [al.communication.GenericCommunicator] - Use encryption=false
2022-10-31 15:20:04.113 [DEBUG] [ternal.communication.EvoCommunicator] - PanelType=EVO192, Max Partitions=1, Max Zones=16
2022-10-31 15:20:04.184 [DEBUG] [l.handlers.ParadoxIP150BridgeHandler] - Phase2 - Creating communicator for panel EVO192
2022-10-31 15:20:04.185 [DEBUG] [.communication.ParadoxBuilderFactory] - Creating new builder for Paradox EVO192 system
2022-10-31 15:20:04.188 [DEBUG] [l.communication.AbstractCommunicator] - IP Address=10.10.6.10, TCP Port=10000
The second IP should be 192.168.100.2 not 10.10.6.10 again.
openhab things are set like this:
In paradox_mcs.things file:
Bridge paradoxalarm:ip150:mcs "Paradox IP150 MCS" [refresh=3, panelType="EVO192", ip150Password="paradox", pcPassword="0000", ipAddress="10.10.6.10", port=10000, reconnectWaitTime=10, maxPartitions=1, maxZones=16 ] {}
In paradox_vb.things file:
Bridge paradoxalarm:ip150:vb "Paradox IP150 Vulcana" [refresh=10, panelType="EVO192", ip150Password="paradox", pcPassword="0000", ipAddress="192.168.100.2", port=10000, reconnectWaitTime=30, maxPartitions=1, maxZones=16 ] {}
paradox.log (160.7 KB)
