Paradox EVO Binding
Yeah. And maybe try to raise the log level so we can check the RAM map too…
Will the TRACE log not do that? Will do both the proxy item and the TRACE logging.
So I managed to squeeze this in quickly.
I monitored the Items linked to the channnels and they did not update, I also have a rule that triggers if they update to change a proxy item.
The TRACE log seems to show that the alarm state was picked up:
2026-08-18 17:07:28.200 [DEBUG] [nhab.binding.paradoxalarm.internal.model.Partition] - Partition House main state:	InAlarm
2026-08-18 17:07:28.200 [TRACE] [nhab.binding.paradoxalarm.internal.model.Partition] - Partition House detailed state:	Audible Alarm
2026-08-18 17:07:28.201 [TRACE] [nhab.binding.paradoxalarm.internal.model.Partition] - Partition House full state dump:	PartitionState [isArmed=true, isArmedInAway=false, isArmedInStay=false, isArmedInNoEntry=false, isInAlarm=true, isInSilentAlarm=false, isInAudibleAlarm=true, isInFireAlarm=false, isReadyToArm=false, isInExitDelay=false, isInEntryDelay=false, isInTrouble=false, hasAlarmInMemory=true, isInZoneBypass=false, hasZoneInTamperTrouble=false, hasZoneInLowBatteryTrouble=false, hasZoneInFireLoopTrouble=false, hasZoneInSupervisionTrouble=false, isStayInstantReady=false, isForceReady=true, isBypassReady=true, isInhibitReady=true, areAllZoneclosed=false]
2026-08-18 17:07:28.201 [DEBUG] [nhab.binding.paradoxalarm.internal.model.Partition] - Partition Beams main state:	Disarmed
2026-08-18 17:07:28.201 [TRACE] [nhab.binding.paradoxalarm.internal.model.Partition] - Partition Beams detailed state:	Disarmed
2026-08-18 17:07:28.201 [TRACE] [nhab.binding.paradoxalarm.internal.model.Partition] - Partition Beams full state dump:	PartitionState [isArmed=false, isArmedInAway=false, isArmedInStay=false, isArmedInNoEntry=false, isInAlarm=false, isInSilentAlarm=false, isInAudibleAlarm=false, isInFireAlarm=false, isReadyToArm=true, isInExitDelay=false, isInEntryDelay=false, isInTrouble=false, hasAlarmInMemory=false, isInZoneBypass=false, hasZoneInTamperTrouble=false, hasZoneInLowBatteryTrouble=false, hasZoneInFireLoopTrouble=false, hasZoneInSupervisionTrouble=false, isStayInstantReady=true, isForceReady=true, isBypassReady=true, isInhibitReady=true, areAllZoneclosed=true]
2026-08-18 17:07:28.201 [DEBUG] [nhab.binding.paradoxalarm.internal.model.Partition] - Partition Ceiling main state:	Armed
2026-08-18 17:07:28.201 [TRACE] [nhab.binding.paradoxalarm.internal.model.Partition] - Partition Ceiling detailed state:	Armed
2026-08-18 17:07:28.201 [TRACE] [nhab.binding.paradoxalarm.internal.model.Partition] - Partition Ceiling full state dump:	PartitionState [isArmed=true, isArmedInAway=false, isArmedInStay=false, isArmedInNoEntry=false, isInAlarm=false, isInSilentAlarm=false, isInAudibleAlarm=false, isInFireAlarm=false, isReadyToArm=true, isInExitDelay=false, isInEntryDelay=false, isInTrouble=false, hasAlarmInMemory=false, isInZoneBypass=false, hasZoneInTamperTrouble=false, hasZoneInLowBatteryTrouble=false, hasZoneInFireLoopTrouble=false, hasZoneInSupervisionTrouble=false, isStayInstantReady=true, isForceReady=true, isBypassReady=true, isInhibitReady=true, areAllZoneclosed=true]
2026-08-18 17:07:28.201 [DEBUG] [nhab.binding.paradoxalarm.internal.model.Partition] - Partition Flat main state:	Armed
2026-08-18 17:07:28.201 [TRACE] [nhab.binding.paradoxalarm.internal.model.Partition] - Partition Flat detailed state:	Armed
2026-08-18 17:07:28.201 [TRACE] [nhab.binding.paradoxalarm.internal.model.Partition] - Partition Flat full state dump:	PartitionState [isArmed=true, isArmedInAway=false, isArmedInStay=false, isArmedInNoEntry=false, isInAlarm=false, isInSilentAlarm=false, isInAudibleAlarm=false, isInFireAlarm=false, isReadyToArm=true, isInExitDelay=false, isInEntryDelay=false, isInTrouble=false, hasAlarmInMemory=false, isInZoneBypass=false, hasZoneInTamperTrouble=false, hasZoneInLowBatteryTrouble=false, hasZoneInFireLoopTrouble=false, hasZoneInSupervisionTrouble=false, isStayInstantReady=true, isForceReady=true, isBypassReady=true, isInhibitReady=true, areAllZoneclosed=true]
2026-08-18 17:07:28.201 [TRACE] [hab.binding.paradoxalarm.internal.util.ParadoxUtil] - Zone opened flags 0100000000000000 0000000000000000 0000000000000000
2026-08-18 17:07:28.201 [TRACE] [hab.binding.paradoxalarm.internal.util.ParadoxUtil] - Zone tampered flags 0000000000000000 0000000000000000 0000000000000000
2026-08-18 17:07:28.201 [TRACE] [hab.binding.paradoxalarm.internal.util.ParadoxUtil] - Zone low battery flags 0000000000000000 0000000000000000 0000000000000000
2026-08-18 17:07:28.201 [TRACE] [hab.binding.paradoxalarm.internal.util.ParadoxUtil] - Zone special flags C000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000
2026-08-18 17:07:28.201 [DEBUG] [g.openhab.binding.paradoxalarm.internal.model.Zone] - Zone MAG Front Door state updated to: ZoneState [isOpened=true, isTampered=false, hasLowBattery=false, supervisionTrouble=false, inTxDelay=false, shuttedDown=false, bypassed=false, hasActivatedIntellizoneDelay=false, hasActivatedEntryDelay=false, presentlyInAlarm=true, generatedAlarm=true]
The zone I was testing with is Zone MAG Front Door
Note sure if you can see any reason the items did not update?
Mark
The binding is reading the alarm state correctly - the TRACE logs confirm both the partition (isInAlarm=true) and the zone (presentlyInAlarm=true, generatedAlarm=true) are parsed correctly on that poll cycle.
The channel update path looks correct on our end, so it should be propagating to items. To pinpoint why it didn’t, could you share the exact channel UIDs your items are linked to?
The zone has two transient Switch channels (presentlyInAlarm, generatedAlarm) and the partition has a sticky Switch (alarmInMemory, only clears on keypad acknowledge) plus a String channel (state) that shows “InAlarm”. Depending on which ones you’re linked to, the behaviour will differ - especially if the alarm was silenced before the next poll cycle.
I am focusing on the ZONE channels. The Partition chanel seems to work correctly and updates.
The Thing channels are as follows:
paradoxalarm:zone:ParadoxIP150:MAG_Front_Door:presentlyInAlarm
with linked ITEM
version: 1
items:
  Zone_MAG_Front_Door_Currently_in_Alarm:
    type: Contact
    label: Zone MAG Front Door Currently in Alarm
    groups:
      - Partition1_Zones_in_Alarm_Group
    tags:
      - Alarm
and
paradoxalarm:zone:ParadoxIP150:MAG_Front_Door:generatedAlarm
with linked ITEM
version: 1
items:
  Zone_MAG_Front_Door_Generated_an_Alarm:
    type: Contact
    label: Zone MAG Front Door Generated an Alarm
    groups:
      - Partition1_Zones_Generated_an_Alarm_Group
    tags:
      - Alarm
I saw in teh TRACE log that the binding seems to know that the alarm is active.
Also, There was a subsequent poll that still showed the alarm active, but no updates to item.
Mark
EDIT: Wonder if it could be because the ITEM is a CONTACT not a SWITCH. Adding a new item defaults to CONTACT even though they are refered to as SWITCH:
With a little help from Claude, we found the issue — it’s a type mismatch between the channel and your items.
presentlyInAlarm and generatedAlarm are Switch channels (they publish ON/OFF), but your items are declared as type: Contact (which expects OPEN/CLOSED). openHAB
silently discards the state update when the types don’t match, which is why the binding correctly reads the alarm but the item never changes.
Change both items to type: Switch:
type: Switch
type: Switch
The opened channel is the one that’s Contact type — that’s why that one works fine.
You owe me some tokens for Claude Code now… :smiley:
(take it with a grain of salt as it may not be 100% correct) :smiley:
Thanks, that was what I picked up in my EDIT above, however I cannot link a SWITCH item to the channel (wants a profile if I select a switch) - and also, when I follow the defaults to add a new item it defauls to contact.
Not sure if this is because of possible new checks in the GUI - I think I recall that you said you use .items files only?
I am sure I owe you more than a few tokens :slight_smile:
I have managed to work aorund the “restrictions” of linking a SWITCH item to the channels by using a MAP Profile as folows:
CLOSED=ON
OPEN=OFF
ON=ON
OFF=OFF
undefined=-
uninitialized=-
NULL=-
Probably don’t need the first two, but was being cautious.
In this way the items do update.
When you get a chnace it could be great if you could look at the channels and make the default create etc use SWITCH types and allow teh linking of a switch without the need for a profile.
As always, appreciate your work
EDIT:
I added a few new Zones (THINGS) this week-end that were not added before and I see that the linked type is switch now , not contact.
My guess is that the type changed at some point after I created the THINGS, so I pobably need to delete the THING and re-discover to get the updated requirements. Will try this and report back.
Hi Konstantin
I have been working on my widget again and was wondering if you know of any way to send “Panics” similar to the 3 panic buttons on teh keypad (Police Panic, Medical Panic and Fire Panic)
I do nto see anything in the documenation that would allow this.
Mark
I don’t think this is implemented but with the power of LLM I may try to gather the information about that and implement it…
That would be highly appreciated
