- Platform information:
- Hardware: _Win 10 8GB Ram
- OS: what OS is used and which version
- Java Runtime Environment:Zulu 8.1 which java platform is used and what version
- openHAB 2 version:
- Issue of the topic: please be detailed explaining your issue OpenHAB2-Service.bat Install FAILING
with Path Not found error.
Doing a PATH cmd yields that Zulu 8.1 is in the PATH.
What else might it be looking for?
Copied the openHAB2-wrapper.conf as directed. verified that the set default OPENHAB_HOME is correct. - Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
FIXED IT!
The openHAB2-service.bat was looking for C:\openHAB and i had change folder to openHAB2.
Off tot the races///
kaw
