Paxton Net2 Access Control Binding
This binding provides integration with the Paxton Net2 Access Control system via its REST API, enabling door control, real-time status monitoring, access logging, user management, and building lockdown – all from openHAB.
Features
- Door Control – Open/close doors remotely, timed open with server-side timing
- Real-time Synchronization – Hybrid sync with SignalR real-time events (<500ms latency) + API polling fallback
- SignalR Auto-Reconnect – Automatic reconnection with exponential backoff after Net2 server restart or network outage (new in v5.2.1)
- Status Monitoring – Live door lock/unlock status via SignalR doorRelayOpen events
- Access Logging – Track last user and access time per door, JSON-formatted entry events
- Access Denied Detection – Real-time alerts for unauthorized access attempts (invalid cards/tokens)
- User Management – Create/delete users and assign access levels from the bridge
- Building Lockdown – Enable/disable lockdown across all configured doors
- Activity Report – Auto-generated HTML report showing last 24h of access events, embeddable in sitemaps
- Entry Log Dashboard – JSON entry events ready for InfluxDB persistence and Grafana visualization
- Multi-Door Support – Control multiple doors from a single Net2 server
- Token Management – Automatic JWT token refresh (30-min tokens)
- Self-signed SSL – Works with Net2 self-signed certificates
Requirements
- Paxton Net2 6.6 SR5 or newer
- Net2 Local API enabled and licensed
- Valid API client credentials (OAuth2)
- Paxton Net2 Plus ACU or Net2 Classic ACU (Nano/Paxlock not supported)
Supported Things
| Thing Type | Description |
| net2server (Bridge) | Connection to Net2 server via REST API + SignalR |
| door | Individual door with relay control and status |
Channels
Door Channels
| Channel | Type | R/W | Description |
| status | Switch | RO | Door relay physical status (ON=Open, OFF=Closed) – real-time via SignalR |
| action | Switch | RW | Control door (ON=Hold Open, OFF=Close) |
| controlTimed | Number | RW | Timed open in seconds (server-side timing) |
| lastAccessUser | String | RO | Last user who accessed the door |
| lastAccessTime | DateTime | RO | Timestamp of last door access |
| entryLog | String | RO | JSON entry event (physical badge access only) |
| accessDenied | String | RO | JSON access denied event (invalid card/token) |
Bridge Channels
| createUser | String | WO | Create user: firstName,lastName,accessLevel,pin |
| deleteUser | String | WO | Delete user by ID |
| listAccessLevels | String | WO | Query and log all access levels |
| listUsers | String | WO | Query and log all users as JSON |
| lockdown | Switch | RW | Building lockdown (ON=enable, OFF=disable) |
| activityReport | String | RO | Last report update timestamp |
Quick Start
net2.things
Bridge net2:net2server:myserver [
hostname="net2.example.com",
port=8443,
username="John Doe",
password="your_secure_password",
clientId="your_oauth_client_id",
tlsVerification=false,
refreshInterval=600
Thing door frontdoor [doorId=6203980, name="Front Door"]
Thing door backdoor [doorId=6203981, name="Back Door"]
Thing door garage [doorId=6203982, name="Garage"]
net2.items
Group gNet2 "Access Control" <lock>
// Front Door
Switch Front_Door_Lock "Front Door" <lock> (gNet2) { channel="net2:door:myserver:frontdoor:action" }
Switch Front_Door_Status "Front Door Status" <door> (gNet2) { channel="net2:door:myserver:frontdoor:status" }
String Front_Door_LastUser "Last Access [%s]" (gNet2) { channel="net2:door:myserver:frontdoor:lastAccessUser" }
DateTime Front_Door_LastTime "Last Time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" (gNet2) { channel="net2:door:myserver:frontdoor:lastAccessTime" }
String Front_Door_EntryLog "Entry Log [%s]" (gNet2) { channel="net2:door:myserver:frontdoor:entryLog" }
String Front_Door_Denied "Access Denied [%s]" (gNet2) { channel="net2:door:myserver:frontdoor:accessDenied" }
// Bridge - User Management
String Net2_CreateUser "Create User" { channel="net2:net2server:myserver:createUser" }
String Net2_DeleteUser "Delete User" { channel="net2:net2server:myserver:deleteUser" }
Switch Net2_Lockdown "Building Lockdown" { channel="net2:net2server:myserver:lockdown" }
Rules Example
rule "Door Opened"
Item Front_Door_Status changed to ON
logInfo("Door", "Front door has been opened")
rule "Access Denied Alert"
Item Front_Door_Denied received update
logWarn("Security", "Unauthorized access attempt: {}", Front_Door_Denied.state)
sendNotification("admin@example.com", "Access denied at Front Door!")
rule "Create User"
Item CreateUser_Button received command ON
Net2_CreateUser.sendCommand("Michael,Agesen,3,7654")
Activity Report
The binding auto-generates an HTML report at /static/net2_activity.html:
Webview url="/static/net2_activity.html" height=100
The binding uses a hybrid approach:
| Method | Latency | Purpose |
| SignalR WebSocket | <500ms | Instant door state changes via DoorStatusEvents |
| API Polling | 10 min (configurable) | Backup synchronization fallback |
SignalR subscribes to DoorStatusEvents (door relay open/close) and LiveEvents (access granted/denied events).
Auto-Reconnect (v5.2.1): If the Net2 server restarts or a network outage occurs, the binding automatically reconnects SignalR with exponential backoff (30s, 60s, 120s, 240s, 300s cap). All door subscriptions are re-established after reconnect. The API polling cycle also acts as a safety-net: if it detects SignalR is down with no reconnect scheduled, it triggers one immediately.
Resources
- Download JAR (v5.2.1): org.openhab.binding.net2-5.2.0-SNAPSHOT.jar (59 KB)
- Source Code: github.com/Prinsessen/openhab-net2-binding
- Full Documentation: README.md
- Quick Start Guide: QUICKSTART.md
- Examples: EXAMPLES.md
- Entry Log Dashboard (Grafana): ENTRY_LOGGING.md
- Changelog: CHANGELOG.md
- License: EPL-2.0
