Ah, thanks for pointing me to the autoupdate setting. I’ve set that to false for the devices in question and will see if that sorts the plug.
I tried toggling the plug on from HABPanel and as far as I can determine it does report the state:
May 27 11:59:23 openhab zwave [DEBUG] [tocol.commandclass.ZWaveCommandClass] NODE 4: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
Full log:
May 27 11:59:23 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Command received zwave:device:071de70e:node4:switch_binary --> ON [OnOffType]
May 27 11:59:23 openhab zwave [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] NODE 4: Creating new message for application command SWITCH_BINARY_SET
May 27 11:59:23 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_BINARY
May 27 11:59:23 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: Command Class COMMAND_CLASS_SWITCH_BINARY is NOT required to be secured
May 27 11:59:23 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Adding to device queue
May 27 11:59:23 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Added 5248 to queue - size 1
May 27 11:59:23 openhab zwave [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] NODE 4: Sending REQUEST Message = 01 0A 00 13 04 03 25 01 FF 25 F1 EE
May 27 11:59:23 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Polling intialised at 86400 seconds - start in 1500 milliseconds.
May 27 11:59:23 openhab zwave [DEBUG] [l.serialmessage.SendDataMessageClass] NODE 4: sentData successfully placed on stack.
May 27 11:59:23 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: TID 5248: Transaction not completed
May 27 11:59:23 openhab zwave [DEBUG] [l.serialmessage.SendDataMessageClass] NODE 4: SendData Request. CallBack ID = 241, Status = Transmission complete and ACK received(0)
May 27 11:59:23 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: resetResendCount initComplete=true isDead=false
May 27 11:59:23 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Response processed after 68ms
May 27 11:59:23 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: TID 5248: Transaction completed
May 27 11:59:23 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: notifyTransactionResponse TID:5248 DONE
May 27 11:59:23 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
May 27 11:59:23 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Application Command Request (ALIVE:DONE)
May 27 11:59:23 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 0
May 27 11:59:23 openhab zwave [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] NODE 4: Switch Binary report, value = 255
May 27 11:59:23 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
May 27 11:59:23 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_BINARY, value=255
May 27 11:59:23 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:switch_binary to ON [OnOffType]
May 27 11:59:23 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Commands processed 1.
May 27 11:59:23 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4d8b190a.
May 27 11:59:24 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Polling...
May 27 11:59:24 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Polling zwave:device:071de70e:node4:switch_binary
May 27 11:59:24 openhab zwave [DEBUG] [converter.ZWaveBinarySwitchConverter] NODE 4: Generating poll message for COMMAND_CLASS_SWITCH_BINARY, endpoint 0
May 27 11:59:24 openhab zwave [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] NODE 4: Creating new message for application command SWITCH_BINARY_GET
May 27 11:59:24 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_BINARY
May 27 11:59:24 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: Command Class COMMAND_CLASS_SWITCH_BINARY is NOT required to be secured
May 27 11:59:24 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Polling skipped for zwave:device:071de70e:node4:switch_binary on COMMAND_CLASS_BASIC
May 27 11:59:24 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Polling zwave:device:071de70e:node4:meter_kwh
May 27 11:59:24 openhab zwave [DEBUG] [ternal.converter.ZWaveMeterConverter] NODE 4: Generating poll message for COMMAND_CLASS_METER, endpoint 0
May 27 11:59:24 openhab zwave [DEBUG] [.commandclass.ZWaveMeterCommandClass] NODE 4: Creating new message for application command METER_GET
May 27 11:59:24 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: SECURITY NOT required on COMMAND_CLASS_METER
May 27 11:59:24 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: Command Class COMMAND_CLASS_METER is NOT required to be secured
May 27 11:59:24 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Polling zwave:device:071de70e:node4:meter_watts
May 27 11:59:24 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Polling zwave:device:071de70e:node4:meter_current
May 27 11:59:24 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Polling zwave:device:071de70e:node4:meter_voltage
May 27 11:59:24 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Adding to device queue
May 27 11:59:24 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Added 5249 to queue - size 1
May 27 11:59:24 openhab zwave [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] NODE 4: Sending REQUEST Message = 01 09 00 13 04 02 25 02 25 F2 13
May 27 11:59:24 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Added 5250 to queue - size 1
May 27 11:59:24 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Added 5251 to queue - size 2
May 27 11:59:24 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Added 5252 to queue - size 3
May 27 11:59:24 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Added 5253 to queue - size 4
May 27 11:59:24 openhab zwave [DEBUG] [l.serialmessage.SendDataMessageClass] NODE 4: sentData successfully placed on stack.
May 27 11:59:24 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: TID 5249: Transaction not completed
May 27 11:59:25 openhab zwave [DEBUG] [l.serialmessage.SendDataMessageClass] NODE 4: SendData Request. CallBack ID = 242, Status = Transmission complete and ACK received(0)
May 27 11:59:25 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: resetResendCount initComplete=true isDead=false
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: TID 5249: Transaction not completed
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Application Command Request (ALIVE:DONE)
May 27 11:59:25 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 0
May 27 11:59:25 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_BINARY
May 27 11:59:25 openhab zwave [DEBUG] [tocol.commandclass.ZWaveCommandClass] NODE 4: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
May 27 11:59:25 openhab zwave [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] NODE 4: Switch Binary report, value = 255
May 27 11:59:25 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
May 27 11:59:25 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_BINARY, value=255
May 27 11:59:25 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:switch_binary to ON [OnOffType]
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Commands processed 1.
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@65a75029.
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@65a75029.
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: notifyTransactionResponse TID:5249 DONE
May 27 11:59:25 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
May 27 11:59:25 openhab zwave [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] NODE 4: Sending REQUEST Message = 01 0A 00 13 04 03 32 01 00 25 F3 04
May 27 11:59:25 openhab zwave [DEBUG] [l.serialmessage.SendDataMessageClass] NODE 4: sentData successfully placed on stack.
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: TID 5250: Transaction not completed
May 27 11:59:25 openhab zwave [DEBUG] [l.serialmessage.SendDataMessageClass] NODE 4: SendData Request. CallBack ID = 243, Status = Transmission complete and ACK received(0)
May 27 11:59:25 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: Incoming command class COMMAND_CLASS_METER, endpoint 0
May 27 11:59:25 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: SECURITY NOT required on COMMAND_CLASS_METER
May 27 11:59:25 openhab zwave [DEBUG] [tocol.commandclass.ZWaveCommandClass] NODE 4: Received COMMAND_CLASS_METER V3 METER_REPORT
May 27 11:59:25 openhab zwave [DEBUG] [.commandclass.ZWaveMeterCommandClass] NODE 4: Meter: Type=Electric(1), Scale=kWh(0), Value=-21474816.35
May 27 11:59:25 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got an event from Z-Wave network: ZWaveMeterValueEvent
May 27 11:59:25 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=-21474816.35
May 27 11:59:25 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:meter_kwh to -21474816.35 [DecimalType]
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1baf3e5a.
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1baf3e5a.
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: notifyTransactionResponse TID:5250 DONE
May 27 11:59:25 openhab zwave [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] NODE 4: Sending REQUEST Message = 01 0A 00 13 04 03 32 01 10 25 F4 13
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: TID 5251: Transaction not completed
May 27 11:59:25 openhab zwave [DEBUG] [l.serialmessage.SendDataMessageClass] NODE 4: SendData Request. CallBack ID = 244, Status = Transmission complete and ACK received(0)
May 27 11:59:25 openhab zwave [DEBUG] [.commandclass.ZWaveMeterCommandClass] NODE 4: Meter: Type=Electric(1), Scale=W(2), Value=0E+1
May 27 11:59:25 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=0E+1
May 27 11:59:25 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:meter_watts to 0 [DecimalType]
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4e1d6ba5.
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4e1d6ba5.
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: notifyTransactionResponse TID:5251 DONE
May 27 11:59:25 openhab zwave [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] NODE 4: Sending REQUEST Message = 01 0A 00 13 04 03 32 01 28 25 F5 2A
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: TID 5252: Transaction not completed
May 27 11:59:25 openhab zwave [DEBUG] [l.serialmessage.SendDataMessageClass] NODE 4: SendData Request. CallBack ID = 245, Status = Transmission complete and ACK received(0)
May 27 11:59:25 openhab zwave [DEBUG] [.commandclass.ZWaveMeterCommandClass] NODE 4: Meter: Type=Electric(1), Scale=A(5), Value=0E+1
May 27 11:59:25 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:meter_current to 0 [DecimalType]
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5bcb6825.
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5bcb6825.
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: notifyTransactionResponse TID:5252 DONE
May 27 11:59:25 openhab zwave [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] NODE 4: Sending REQUEST Message = 01 0A 00 13 04 03 32 01 20 25 F6 21
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: TID 5253: Transaction not completed
May 27 11:59:25 openhab zwave [DEBUG] [l.serialmessage.SendDataMessageClass] NODE 4: SendData Request. CallBack ID = 246, Status = Transmission complete and ACK received(0)
May 27 11:59:25 openhab zwave [DEBUG] [.commandclass.ZWaveMeterCommandClass] NODE 4: Meter: Type=Electric(1), Scale=V(4), Value=240.92
May 27 11:59:25 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=240.92
May 27 11:59:25 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:meter_voltage to 240.92 [DecimalType]
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4324d6d.
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4324d6d.
May 27 11:59:25 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: notifyTransactionResponse TID:5253 DONE
May 27 11:59:28 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Application Command Request (ALIVE:DONE)
May 27 11:59:28 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: resetResendCount initComplete=true isDead=false
May 27 11:59:28 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: Incoming command class COMMAND_CLASS_METER, endpoint 0
May 27 11:59:28 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: SECURITY NOT required on COMMAND_CLASS_METER
May 27 11:59:28 openhab zwave [DEBUG] [tocol.commandclass.ZWaveCommandClass] NODE 4: Received COMMAND_CLASS_METER V3 METER_REPORT
May 27 11:59:28 openhab zwave [DEBUG] [.commandclass.ZWaveMeterCommandClass] NODE 4: Meter: Type=Electric(1), Scale=kWh(0), Value=-21474816.35
May 27 11:59:28 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got an event from Z-Wave network: ZWaveMeterValueEvent
May 27 11:59:28 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=-21474816.35
May 27 11:59:28 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:meter_kwh to -21474816.35 [DecimalType]
May 27 11:59:28 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Commands processed 1.
May 27 11:59:28 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@a972c3e.
May 27 11:59:28 openhab zwave [DEBUG] [.commandclass.ZWaveMeterCommandClass] NODE 4: Meter: Type=Electric(1), Scale=W(2), Value=84.72
May 27 11:59:28 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=84.72
May 27 11:59:28 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:meter_watts to 84.72 [DecimalType]
May 27 11:59:28 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@35bf4dcf.
May 27 11:59:28 openhab zwave [DEBUG] [.commandclass.ZWaveMeterCommandClass] NODE 4: Meter: Type=Electric(1), Scale=V(4), Value=239.78
May 27 11:59:28 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=239.78
May 27 11:59:28 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:meter_voltage to 239.78 [DecimalType]
May 27 11:59:28 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@34c0d124.
May 27 11:59:28 openhab zwave [DEBUG] [.commandclass.ZWaveMeterCommandClass] NODE 4: Meter: Type=Electric(1), Scale=A(5), Value=0.48
May 27 11:59:28 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=0.48
May 27 11:59:28 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:meter_current to 0.48 [DecimalType]
May 27 11:59:28 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@ba83deb.
May 27 11:59:58 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Application Command Request (ALIVE:DONE)
May 27 11:59:58 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: resetResendCount initComplete=true isDead=false
May 27 11:59:58 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: Incoming command class COMMAND_CLASS_METER, endpoint 0
May 27 11:59:58 openhab zwave [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] NODE 4: SECURITY NOT required on COMMAND_CLASS_METER
May 27 11:59:58 openhab zwave [DEBUG] [tocol.commandclass.ZWaveCommandClass] NODE 4: Received COMMAND_CLASS_METER V3 METER_REPORT
May 27 11:59:58 openhab zwave [DEBUG] [.commandclass.ZWaveMeterCommandClass] NODE 4: Meter: Type=Electric(1), Scale=kWh(0), Value=-21474816.35
May 27 11:59:58 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got an event from Z-Wave network: ZWaveMeterValueEvent
May 27 11:59:58 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=-21474816.35
May 27 11:59:58 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:meter_kwh to -21474816.35 [DecimalType]
May 27 11:59:58 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Commands processed 1.
May 27 11:59:58 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2ad9a08a.
May 27 11:59:58 openhab zwave [DEBUG] [.commandclass.ZWaveMeterCommandClass] NODE 4: Meter: Type=Electric(1), Scale=W(2), Value=84.48
May 27 11:59:58 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=84.48
May 27 11:59:58 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:meter_watts to 84.48 [DecimalType]
May 27 11:59:58 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5633b84e.
May 27 11:59:58 openhab zwave [DEBUG] [.commandclass.ZWaveMeterCommandClass] NODE 4: Meter: Type=Electric(1), Scale=V(4), Value=239.93
May 27 11:59:58 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=239.93
May 27 11:59:58 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:meter_voltage to 239.93 [DecimalType]
May 27 11:59:58 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@e6cf7b3.
May 27 11:59:58 openhab zwave [DEBUG] [.commandclass.ZWaveMeterCommandClass] NODE 4: Meter: Type=Electric(1), Scale=A(5), Value=0.48
May 27 11:59:58 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=0.48
May 27 11:59:58 openhab zwave [DEBUG] [ding.zwave.handler.ZWaveThingHandler] NODE 4: Updating channel state zwave:device:071de70e:node4:meter_current to 0.48 [DecimalType]
May 27 11:59:58 openhab zwave [DEBUG] [nal.protocol.ZWaveTransactionManager] NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@357b594a.
Thanks,
Torkil
