Hmm…after ~3 hours working, again issues.
Here is a snippet of my openhab.log file (see below).
I am getting only a much delayed log entry, when triggering my rule containing the http send request.
2023-03-24 14:53:34.593 [ERROR] [enhab.core.model.script.actions.HTTP] - Fatal transport error: java.lang.InterruptedException
any idea what to try next?
thanks,
Christian
2023-03-24 07:41:49.554 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 08:11:48.783 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 08:41:48.492 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 09:11:48.196 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 09:41:47.674 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 10:11:48.453 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 10:41:46.858 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 10:47:35.532 [ERROR] [enhab.core.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.TimeoutException: Total timeout 5000 ms elapsed
2023-03-24 10:47:50.412 [WARN ] [p.internal.http.HttpResponseListener] - Requesting 'http://192.168.178.166:8080/list?nukiId=******&token=*******' (method='GET', content='null') failed: java.util.concurrent.TimeoutException: Total timeout 3000 ms elapsed
2023-03-24 10:47:50.420 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2023-03-24 10:47:50.422 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 82...55, base URL = http://localhost:8080)
2023-03-24 10:48:20.411 [WARN ] [p.internal.http.HttpResponseListener] - Requesting 'http://192.168.178.166:8080/list?nukiId=*****&token=*****' (method='GET', content='null') failed: java.util.concurrent.TimeoutException: Total timeout 3000 ms elapsed
2023-03-24 10:48:41.073 [ERROR] [enhab.core.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.ExecutionException: java.net.UnknownHostException: api.huum.eu: Temporärer Fehler bei der Namensauflösung
2023-03-24 10:48:41.084 [ERROR] [enhab.core.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.ExecutionException: java.net.UnknownHostException: api.huum.eu
2023-03-24 10:48:50.412 [WARN ] [p.internal.http.HttpResponseListener] - Requesting 'http://192.168.178.166:8080/list?nukiId=****&token=******' (method='GET', content='null') failed: java.util.concurrent.TimeoutException: Total timeout 3000 ms elapsed
2023-03-24 10:49:20.413 [WARN ] [p.internal.http.HttpResponseListener] - Requesting 'http://192.168.178.166:8080/list?nukiId=****&token=*******' (method='GET', content='null') failed: java.util.concurrent.TimeoutException: Total timeout 3000 ms elapsed
2023-03-24 10:49:37.000 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.de/api/phoenix/state' fails with unknown error
java.net.UnknownHostException: alexa.amazon.de
at sun.nio.ch.NioSocketImpl.connect(NioSocketImpl.java:567) ~[?:?]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:327) ~[?:?]
at java.net.Socket.connect(Socket.java:633) ~[?:?]
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:304) ~[?:?]
at sun.security.ssl.BaseSSLSocketImpl.connect(BaseSSLSocketImpl.java:174) ~[?:?]
at sun.net.NetworkClient.doConnect(NetworkClient.java:183) ~[?:?]
at sun.net.www.http.HttpClient.openServer(HttpClient.java:531) ~[?:?]
at sun.net.www.http.HttpClient.openServer(HttpClient.java:636) ~[?:?]
at sun.net.www.protocol.https.HttpsClient.<init>(HttpsClient.java:266) ~[?:?]
at sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:380) ~[?:?]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:193) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1242) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1128) ~[?:?]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:179) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(HttpURLConnection.java:1430) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1401) ~[?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(HttpsURLConnectionImpl.java:220) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:640) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:561) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.getSmartHomeDeviceStatesJson(Connection.java:1082) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.updateSmartHomeState(AccountHandler.java:911) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.lambda$2(AccountHandler.java:167) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
at java.lang.Thread.run(Thread.java:833) ~[?:?]
2023-03-24 10:49:37.018 [WARN ] [trol.internal.handler.AccountHandler] - updateSmartHomeState fails with unexpected error
2023-03-24 10:49:49.158 [ERROR] [enhab.core.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.ExecutionException: java.net.UnknownHostException: api.huum.eu: Temporärer Fehler bei der Namensauflösung
2023-03-24 10:49:49.175 [ERROR] [enhab.core.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.ExecutionException: java.net.UnknownHostException: api.huum.eu
2023-03-24 10:49:50.413 [WARN ] [p.internal.http.HttpResponseListener] - Requesting 'http://192.168.178.166:8080/list?nukiId=*******&token=***********' (method='GET', content='null') failed: java.util.concurrent.TimeoutException: Total timeout 3000 ms elapsed
2023-03-24 10:50:13.615 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 82...55, base URL = http://localhost:8080)
2023-03-24 11:11:47.466 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 11:41:46.268 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 12:11:45.852 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 12:41:45.531 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 13:02:08.878 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 13:11:45.397 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 13:41:44.613 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 14:11:44.297 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-03-24 14:41:43.929 [WARN ] [mazonechocontrol.internal.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"335f80d2-4a9f-4fd1-b318-66957c2f5959","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
