I have a tiny Permundo controller for my awning. It has two channels: a switch and a dimmer. The switch item works with ON and OFF. The rollershutter item for the dimmer works with a percentage value and ON and OFF, but not with STOP. A workaround is, using ON to start and another ON to stop.
As far as I learned from the forum, other rollershutter controller like Fibaro uses UP and DOWN.
Also in the sitemap when I am using for the dimmer item a switch, nothing worked. When I am using a slider, I can control my awning.
Is this a wrong definition in the Z-Wave database or did I make a mistake?
There was a mistake in my original post: The Permundo has to channels (not items): switch and dimmer.
I assigned a rollershutter item, but it didn’t work.
I got the buttons in my sitemap, but without function. When I am using a slider for the rollershutter item (dimmer channel), I can control the position. The switch for the switch item (switch channel) worked like a switch.
