is there a way to get a diagramm for persistance in habpanel like in habmin with the values of more than one item in one diagramm?
Alex, If you use the n3-line-chart in HABPanel you can add multiple items in the series tab.
Alternatively if you want to use the default charting you could create a group in your items file and then point the chart at the group - you should see all items within the group.
Regards
Nic
