tomhag
(Tommy Hagenes)
December 22, 2017, 4:49pm
1
Platform information: Windows 10
I have a problem with my logging. Some items are logging OK, while other are not. I cant see any pattern why some items are working and others not. Even not a pattern on device, date i made it or nothing. Have tried with new items also withour any luck.
Cant see any problems in openhab.log and my rrdj4.persist is loading without errors.
I have tried to install a fresh copy of the 2.2.0 with this guide: https://docs.openhab.org/installation/windows.html
I had double checked that org.ops4j.pax.logging.cfg is the new one.
Is there anyway to troubleshot this a easy way?
Have anyone seen similar problems?
Not working
Working:
rrdj4.persist
// persistence strategies have a name and a definition and are referred to in the "Items" section
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
* : strategy = everyChange, everyDay, restoreOnStartup
// vim: syntax=Xtend syntax=openhab
job
(Joachim Boeddeker)
December 22, 2017, 4:51pm
2
You need to add everyMinute to make rrd4j work.
tomhag
(Tommy Hagenes)
December 22, 2017, 4:54pm
3
Is this not covered in my rrdj4.persist? Can you please spesify?
job
(Joachim Boeddeker)
December 22, 2017, 5:14pm
4
You defined everyMinute, but none of your items uses it. Just add everyMinute to your default strategy and your strategy for all items.
I’m at the phone, so i can’t modify your file without breaking my fingers.
tomhag
(Tommy Hagenes)
December 22, 2017, 5:17pm
5
tomhag
(Tommy Hagenes)
December 22, 2017, 5:42pm
6
Updated the rrdj4.persist.
Still one problem, now the logging shows, but the value is no updating in the chart.
Did i do something wrong?
The value went from 67, 68, 69, 70
But the logging only shows this:
Strategies {
default = everyChange, everyMinute
Items {
* : strategy = everyChange, everyMinute, everyDay, restoreOnStartup
tomhag
(Tommy Hagenes)
December 22, 2017, 7:54pm
7
Its seems that its just logging the value at startup, and when i added everyMinute it will just add the same value, even if the number is changing.
The strange this is that its not all items…
opus
(Jürgen Baginski)
December 22, 2017, 8:45pm
8
When doing such changes to the rrd4j setup it is a good idea to restart the logging completly (i.e. delete the old .rrd files).
tomhag
(Tommy Hagenes)
December 22, 2017, 10:23pm
9
Deleted all .rrd files (even tho it hurt with all the good date i have collected over 1 year:()
But it seems to be working, thanks again
opus
(Jürgen Baginski)
December 22, 2017, 10:26pm
10
Yes, that is the negative point about rrd4j. It needs to get the data in the correct timesequence. A later change of the values is not possible(at least as far as I understand. A change in archive 1 migth be possible, but that won’t change anything in the other archives).
