I’m trying to use the spotify integration. There is a prerequisite that says you must have persistence turned on as to not loose settings after reboot. I have installed the persistence add on but cannot see a switch to turn it on. Can someone help me on where I would find it or how to turn it on.
Also in the installation instructions it says to copy client secret to spotify_client_secret in openhab e.g. through rest Api. In the rest api I can’t find anything about spotify. After some searching I found a command
I just installed the add-on for persistence. I haven’t set up a service as I’m not sure which to choose. I will set the service up with the mapdb once I get home from work. Or do you recommend another service?
Bit of a silly newb here thinking it was a simple switch to turn it off and on.
