I’ve been trying to have a rule return the Min and Max of a item for the last 48 hours. I can’t get it to work right, and wondered if someone could help, or if it is even possible to do this.
With creative logging (not shown below), I’ve figure out that the error is when trying to retrieve the min or max values.
rule "Adaptive Lighting Min Max Calculations"
Member of LightSensorRaw changed
triggeringItem.name+"_Min".postUpdate(triggeringItem.minimumSince(now.minusHours(48)).state)
triggeringItem.name+"_Max".postUpdate(triggeringItem.maximumSince(now.minusHours(48)).state)
logInfo("Adaptive Lighting", "Calculated Min Max Light Values")
Openhasbian 2.4, on RaspberryPi3 B+. using JDBC Persistence - Maria DB. A similar rule successfully retrieves min and max when using the direct item names.
2019-01-29 23:51:29.047 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'AdaptiveLighting Min Max Calculations': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.postUpdate(java.lang.String,java.lang.String) on instance: null
Any ideas on how to have one rule get Min, Max, and maybe even averages while using triggeringItem?
import org.eclipse.smarthome.model.script.ScriptServiceUtil
val minItem = ScriptServiceUtil.getItemRegistry.getItem(triggeringItem.name .toString + "_Min")
val maxItem = ScriptServiceUtil.getItemRegistry.getItem(triggeringItem.name .toString + "_Max")
minItem.postUpdate(triggeringItem.minimumSince(now.minusHours(48)).state)
maxItem.postUpdate(triggeringItem.maximumSince(now.minusHours(48)).state)
