I see, using the .averageSince will select your DEFAULT persistence service. My guess you are using rrd4j and MapDB AND have not selected anyone of those as the default. The rule selected the first queryable service (in this case MapDB).
Try the set rrd4j as the default persistence service (PaperUI under Configuration System).
BTW: When using the default setup of rrd4j make sure you do understand when and how your stored values are consolidated! For example requesting the data for the last 24 hrs will NOT give you the actual minute-wise stored values.
thanks for the hint!
i just changed default (was mapdb before). but why is this relevant, this item is persisted only in rrd4j?
for now i just need last 5 minutes so it should be ok!
If you are not persisting this item in MapDB , this database might be used when you call it for this item.
You can use as much persistence services as you want, however you got to understand when the default is used or when you have to state the desired service explicitly ( for example when charting).
