Hi everyone i’m hoping for some help again
both my persistence services are behaving weird and have developed problems some stuff works but others not both services have errors
services used Infuxdb & mapdb
MAPDB (Restore everything on startup every change persisted)
most of this works fine as far as i can tell but my log is full of errors relating too mapdb differnet items
Example error repeated over and over different items
2019-03-07 20:38:56.999 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener 'org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl@e65c13' about state update of item Bathroom_Motion_Last_Updated: null
java.lang.IndexOutOfBoundsException: null
at java.nio.Buffer.checkIndex(Buffer.java:546) ~[?:?]
at java.nio.HeapByteBuffer.getLong(HeapByteBuffer.java:416) ~[?:?]
at org.mapdb.DataInput2.readLong(DataInput2.java:104) ~[?:?]
at org.openhab.persistence.mapdb.internal.MapDBitemSerializer.deserialize(MapDBitemSerializer.java:81) ~[?:?]
at org.openhab.persistence.mapdb.internal.MapDBitemSerializer.deserialize(MapDBitemSerializer.java:1) ~[?:?]
at org.mapdb.BTreeMap$NodeSerializer.deserialize(BTreeMap.java:449) ~[?:?]
at org.mapdb.BTreeMap$NodeSerializer.deserialize(BTreeMap.java:288) ~[?:?]
at org.mapdb.Store.deserialize(Store.java:297) ~[?:?]
at org.mapdb.StoreDirect.get2(StoreDirect.java:486) ~[?:?]
at org.mapdb.StoreWAL.get2(StoreWAL.java:336) ~[?:?]
at org.mapdb.StoreWAL.get(StoreWAL.java:320) ~[?:?]
at org.mapdb.Caches$HashTable.get(Caches.java:246) ~[?:?]
at org.mapdb.EngineWrapper.get(EngineWrapper.java:58) ~[?:?]
at org.mapdb.BTreeMap.put2(BTreeMap.java:677) ~[?:?]
at org.mapdb.BTreeMap.put(BTreeMap.java:643) ~[?:?]
at org.openhab.persistence.mapdb.internal.MapDBPersistenceService.store(MapDBPersistenceService.java:161) ~[?:?]
at org.openhab.core.persistence.internal.PersistenceServiceDelegate.store(PersistenceServiceDelegate.java:55) ~[?:?]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.handleStateEvent(PersistenceManagerImpl.java:148) ~[?:?]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.stateChanged(PersistenceManagerImpl.java:464) ~[?:?]
at org.eclipse.smarthome.core.items.GenericItem$1.run(GenericItem.java:251) [102:org.eclipse.smarthome.core:0.10.0.oh240]
INFLUX (Persistence service for graphs and everything else every change persisted)
This is the same some things are working somethings are not
will edit too update influx errors
