Persistence, mysql: every10Minutes stores every 10 seconds!?
Hi
I have a strange behavior with openhab2, and MySQL persistence.
I have configured different values to be stored every 10 minutes, but it looks like the values are stored every 10 seconds.
example from mysql.persist:
every5Minutes : “/5 * * * * ?"
every10Minutes : "
/10 * * * * ?”
Items {
Wetter_Temperatur : strategy = every10Minutes, restoreOnStartup
MySQL entries for Wetter_Temperatur (outside temperature):
2017-02-14 13:54:40 3.8
2017-02-14 13:54:50 3.8
2017-02-14 13:55:00 3.8
2017-02-14 13:55:10 3.8
2017-02-14 13:55:20 3.8
Any ideas?
Thanks and regards
Markus
Openhab uses a slightly other cron format. You should search the wiki for the right format, but as far as i know “* */10 * * * ?” should do the work
I see. That makes much more sense, now.
Many thanks for the fast advice. Seems to work correctly :slight_smile:
