I’m using openHAB 3.2.0 on a synology NAS, running openHAB in docker.
For controlling some lights I use the DMX binding. I already configured some Items and Things via textual editor, my configuration is running well.
Now I decided to store the dimming values if they are changed in case the docker container or the whole NAS is restarted. If so I want to restore the former setting of some of my lights controlled via DMX.
For my purposes I thougth that “MapDB” is the most efficient persistence service.
I’ve set up everything and can see in the folder “userdata\persistence\mapdb” that the timestamp of the files is updated if I change the dimming value of one of the relevant items (see e.g. “Test_Wohnstube_LED_gruen” below in items section). So I think, storing is working.
But after a restart, the dimming value is set to 0, not to the former value.
I tried to store a virtual switch (see “Test_Schalter” below in items section), the state (ON or OFF) of this switch is restored properly after a restart. So fundamental stroring seems to be possible.
I’ve also tried it with RRD4J and MariaDB persistence services, same behaviour - DMX values are not restored but the state of my virtual switch is restored.
MapDB is defined as the default persitence service in the settings of openHAB (“Settings” → “System Services” → “Persistence”).
What am I doing wrong?
*.things:
dimmer Wohnstube_ind_Bel_gr "Wohnstube ind. Bel. grün" [dmxid="24", fadetime=150, turnonvalue="255", turnoffvalue="0" ]
*.items:
Dimmer Test_Wohnstube_LED_gruen "Test Wohnstube LED grün" <energy> (Erdgeschoss, Wohnstube, MapDB) { channel="dmx:dimmer:ArtNet_Bridge:Wohnstube_ind_Bel_gr:brightness" }
Switch Test_Schalter "Test Schalter" <switch>
mapdb.persist:
Strategies {
everyMinute : "0 * * * * ?"
every15Minutes : "0 */15 * ? * *"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
MapDB* : strategy = everyChange, restoreOnStartup
Test_Wohnstube_LED_gruen : strategy = everyChange, restoreOnStartup
Test_Schalter : strategy = everyChange, restoreOnStartup
Thanks in advance!
Sebastian
