Hi there,
I experienced that the configuration changes I make via PaperUI does not automatically get persisted to the conf-directory. Is that right?
With build 104 I configured some things like from astro-binding and was expecting, I would find the configuration somewhere in the conf-dir afterwards.
Is the paperUI config stored somewhere else or is it a bug or just not implemented yet? If the latter is the case is it recommended to only configure the things manually in the config files?
Cheers,
Hauke
