With the following items:
Group g_gf_cupboard1
Group g_br_master
Group g_ups
Group g_temperature
Group g_humidity
Group g_chart
/* Indoor Temperatures */
/* Cupboard */
Number gf_cupboard1_temperature "Temperature [%.1f °C]" <temperature> (g_gf_cupboard1,g_gf_cupboard1_temperature,g_temperature) {mqtt="<[mosquitto:cupboard/temperature1:state:default]"}
Number gf_cupboard1_humidity "Humidity [%.1f%%]" <humidity> (g_gf_cupboard1,g_humidity,g_gf_cupboard1_humidity) {mqtt="<[mosquitto:cupboard/humidity1:state:default]"}
DateTime gf_cupboard1_lastupdate "Last Update [%1$td/%1$tm %1$tH:%1$tM]" (g_gf_cupboard1)
/* Master Bedroom */
Number br_master_temperature "Temperature [%.1f °C]" <temperature> (g_br_master,g_br_master_temperature,g_temperature) {mqtt="<[mosquitto:2fmaster/temperature:state:default]"}
Number br_master_humidity "Humidity [%.1f%%]" <humidity> (g_br_master,g_humidity,g_br_master_humidity) {mqtt="<[mosquitto:2fmaster/humidity:state:default]"}
DateTime br_master_lastupdate " Last Update [%1$td/%1$tm %1$tH:%1$tM]" (g_br_master)
Group g_gf_cupboard1_temperature
Number gf_cupboard1_temperature_max "Todays Maximum [%.1f °C]" <temperature> (g_gf_cupboard1)
Number gf_cupboard1_temperature_min "Todays Minimum [%.1f °C]" <temperature> (g_gf_cupboard1)
Number gf_cupboard1_temperature_chart_period "Chart Period" (g_gf_cupboard1,g_chart)
Group g_br_master_temperature
Number br_master_temperature_max "Todays Maximum [%.1f °C]" <temperature> (g_br_master,g_br_master_temperature)
Number br_master_temperature_min "Todays Minimum [%.1f °C]" <temperature> (g_br_master,g_br_master_temperature)
Number br_master_temperature_chart_period "Chart Period" (g_br_master,g_chart)
Group g_gf_cupboard1_humidity
Number gf_cupboard1_humidity_max "Todays Maximum [%.1f%%]" <humidity> (g_gf_cupboard1,g_gf_cupboard1_humidity)
Number gf_cupboard1_humidity_min "Todays Minimum [%.1f%%]" <humidity> (g_gf_cupboard1,g_gf_cupboard1_humidity)
Number gf_cupboard1_humidity_chart_period "Chart Period" (g_gf_cupboard1,g_chart)
Group g_br_master_humidity
Number br_master_humidity_max "Todays Maximum [%.1f%%]" <humidity> (g_br_master,g_br_master_humidity)
Number br_master_humidity_min "Todays Minimum [%.1f%%]" <humidity> (g_br_master,g_br_master_humidity)
Number br_master_humidity_chart_period "Chart Period" (g_br_master,g_chart)
I’m wanting to persist only the gf_cupboard1_temperature, gf_cupboard1_humidity, br_master_temperature and br_master_humidity.
Based on the groups (and how I thought groups worked, I’d put both the temp sensors in g_temperature and both the humidity sensors in g_humidity).
With this persist file for mysql:
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
//* : strategy = everyChange, restoreOnStartup
// next we define specific strategies of everyHour for anything
//in the Temperature group, and and every minute for Humidity
g_temperature : strategy = everyChange
g_humidity : strategy = everyChange
g_ups : strategy = everyHour
//g_chart : strategy = restoreOnStartup
Shouldn’t it only persist those sensors I wanted and not everything else? Basically I don’t care about keeping the max and min, nor (at the moment) the chart switch.
Also a follow on, I’ve renamed a bunch of my sensors my so mqsql server is a bit of a mess, how can I clean it up.
