Persistence: Possible to specify both time and value with postUpdate?
Take a look at this post. You can send a POST request to InfluxDB from a rule with any data you want and you can specify the timestamp. The persistence interface is simple and doesn’t let you use tags or different retention policies or set specific timestamps as you found which is a bit limiting.
