installed is the OH 2.4.0.1, and the Persistence rrd4j. Also in the configuration system is set the rr4jd.
The rrd4j.persist is coded as follows:
Strategies{
default = everyChange
Items{
Wohnzimmer_Kamin_Betriebsstundenzaehler : strategy = everyUpdate, everyMinute, restoreOnStartup
My Item is:
Number Wohnzimmer_Kamin_Betriebsstundenzaehler “Betriebsstunden: [%d]”
There is a rule wich is counting the Item every hour, which is shown on sitemap very well.
After restart of the system i expected the same value again, but the values are wrong.
Shortly after the restart I get the following log message:
2019-12-12 11:19:41.360 [vent.ItemStateChangedEvent] - Wohnzimmer_Kamin_Betriebsstundenzaehler changed from NULL to 26100.0
Which is not my expected value. I expected in this case a number of 30.
How can is solve this.what I am duing wrong?
Thank you very much
Holgus
