since a few days a have many warnings, like this, in my logs. I’ve updatet to the last oh2-snapshot.
2017-08-27 10:51:22.837 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.StringItem with key'SystemLocalMoon_Phase_MoonphaseName' already exists! Failed to add a second with the same UID!
2017-08-27 10:51:22.840 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DateTimeItem with key'NetAtmoRegen_LastMessage' already exists! Failed to add a second with the same UID!
2017-08-27 10:51:22.842 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'NetAtmoAussen_BatteryLevel' already exists! Failed to add a second with the same UID!
2017-08-27 10:51:22.852 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'DailyTimer1_OffHour' already exists! Failed to add a second with the same UID!
2017-08-27 10:51:22.855 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'AVMThermostatNoah_Absenktemperatur' already exists! Failed to add a second with the same UID!
My problem is now, the persisitence don’t work and the properties of the items are wrong and not editable per paperui. I got “some errors occured” by saving the item.
the json-file is ok, there no double items inside.
Any suggestions?
thx
Heiko
