Persistence Services configuration file name problems
I am developing an persistence bundle. The bundle is build and can be loaded in the openHAB 2 runtime.
I created the .persist file with the config.
But I need a services config file, e.g. the JDBC persistence service has “runtime”/conf/services/jdbc.cfg .
I cannot understand how the system determines the name of this config file.
How are the different names in the different files connected?
The pom.xml, MANIFEST, file in OSGI-INF?
I created a .cfg file in “runtime”/conf/services but I do not get the config in my Persistence Service activate()-method.
Any hints?
Thanks a lot
No one an idea?
It is determined by the configuration-pid value of the service declaration. The “org.openhab” prefix is optional, so both files “jdbc.cfg” and “org.openhab.jdbc.cfg” will work in that example.
