- Platform information:
- Hardware: virtual Machine on ESX Server
- OS: Suse Linux Enterprise Server 15
- Java Runtime Environment: zulu8.33.0.1-jdk8.0.192
- openHAB version: 2.4.0
- Issue of the topic: Persistence sumSince() doesn’t output a valid numer, only zero
- my configurations:
- Items configuration related to the issue
items/door.items
Contact Door_Status "Door Status[%s]" <door> (GP_Persist_Restore, GP_Persist_Change, GP_Persist_Hour) { channel="mqtt:topic:door_status"}
Number:Dimensionless Door_Counter_monthly "Door Counter this month [%d]" <door> (GP_Persist_Restore)
- Sitemap configuration related to the issue
nothing special here
- Rules code related to the issue
rules/door.rules
rule "monthly door counter"
Item Door_Status changed to CLOSED or
Time cron "0 0 0 1 1/1 ? *" or // first of month, 0:00 o'clock
Item Debug_Trigger_Counter_Update changed to ON
Door_Counter_monthly.postUpdate(Door_Status.sumSince(now.minusDays(31), "influxdb"))
if(Debug_Trigger_Counter_Update.state == ON) {Debug_Trigger_Counter_Update.postUpdate(OFF)}
- Services configuration related to the issue
persistence/influxdb.persist
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
GP_Persist_Minute* : strategy = everyMinute
GP_Persist_Hour* : strategy = everyHour
GP_Persist_Day* : strategy = everyDay
GP_Persist_Change* : strategy = everyChange
persistence/mapdb.persist
Strategies {
Items {
GP_Persist_Restore* : strategy = everyChange, restoreOnStartup
- If logs where generated please post these here using code fences:
events.log
14:43:36.161 [ome.event.ItemCommandEvent] - Item 'Debug_Trigger_Counter_Update' received command ON
14:43:36.162 [vent.ItemStateChangedEvent] - Debug_Trigger_Counter_Update changed from NULL to ON
14:43:36.329 [vent.ItemStateChangedEvent] - Door_Counter_monthly changed from NULL to 0.0
14:43:36.338 [vent.ItemStateChangedEvent] - Debug_Trigger_Counter_Update changed from ON to OFF
I want to count the number of door opening events for this month (31 days in this example). Persistence itself works, I see data in Grafana (connected to same influxdb instance):
But sumSince() always outputs me a zero, why?
Is there aproblem in using two persistence services? That’s why I put sumSince([...], "influxdb")
there, but that doesn’t change anything.
Just for record:
- I never used calculation on persistence data, so there might be a more general configuration issue there
- I first wanted to use
sumSince(now.withTimeAtStartOfDay.minusDays(now.getDayOfMonth())))
but to keep out complexity I made the example easier.
Thanks in advance
