Lately i moved from Oh 2.5.12 to Oh3.4.2
In oh2 I had a rule dicovering if my heat radiators were on while the window has been opened. If yes, i storred necessery thermostat settings and brought them back when the window was closed again.
this is the Oh2 rule:
import java.util.Map
var int TempVarOffice = 0
var Map ThermostatOfficePresistency
rule "Action on Window open in Office"
Item BS_Office_Window changed
// If Window is open and Theremostat is NOT OFF. If Thermostat is OFF no influence on it while window is open
if ((BS_Office_Window.state == OPEN) && (BS_Office_Thermostat_Mode.state != 0)) {
TempVarOffice = 1 // remember previous window status. Is open
ThermostatOfficePresistency = storeStates(BS_Office_Thermostat_Valve, BS_Office_Thermostat_Temp, BS_Office_Thermostat_Mode, BS_Office_Thermostat_SetpointHeat, BS_Office_Thermostat_SetpointEHeat)
logInfo("Thermostat Office:", "Thermostat Settings stored: " + ThermostatOfficePresistency )
BS_Office_Thermostat_Mode.sendCommand (0) // Close thermostat in the office
// If window is closed and previously was opened.
if ((BS_Office_Window.state == CLOSED) && (TempVarOffice == 1)) {
restoreStates(ThermostatOfficePresistency)
logInfo("Thermostat Office:", "Check Thermostat Mode after restore" )
TempVarOffice = 0
the rule has been working.
With hte OH3 (new items new names) i receive an error when the rule is launched.
2023-03-27 09:07:33.998 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Office_FIBARO_Window_Sensor_Door' changed from CLOSED to OPEN
2023-03-27 09:07:34.597 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'thermostatOfficePersistancy' failed: ___ import ___ java.util.Map
if ((Office_FIBARO_Window_Sensor_Door.state == OPEN) && (Office_Thermostatic_Valve_Thermostat_mode.state != 0)) {
ThermostatOfficePresistency = storeStates(Office_Thermostatic_Valve_Setpoint_energy_heat, Office_Thermostatic_Valve_Thermostat_mode, Office_Thermostatic_Valve_Setpoint_heat)
Office_Thermostatic_Valve_Thermostat_mode.sendCommand (0) // Close thermostat in the office
if ((Office_FIBARO_Window_Sensor_Door.state == CLOSED) && (TempVarOffice == 1)) {
TempVarOffice = 0
1. Map cannot be resolved to a type.; line 3, column 51, length 3
2. The method or field import is undefined; line 1, column 0, length 6
3. This expression is not allowed in this context, since it doesn't cause any side effects.; line 1, column 7, length 13
How can I implement the rule with persistency feature in OH3?
