Hi all
I am just starting with OpenHAB. I want to replace my PHC STM with an OpenHABian Raspberry PI 4.
I managed to flash the lates OpenHABian and it is starting up. However, in the event-log, I am facing an warning / exception being caused by the PHC Binding 3.0.0.
I first thought, I can ignore the problem, but later, when trying to access the items, it seems that this very error is relevant and cannot be ignored.
Can I do something about this problem? If yes, what? Any help very much appreciated.
Kai
Log
2020-12-28 17:01:40.310 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/OH-INF/thing/channel-types.xml' in module 'org.openhab.binding.phc' could not be parsed: The attribute 'advanced' of the node 'channel-group-type' is not supported or exists multiple times!
---- Debugging information ----
message : The attribute 'advanced' of the node 'channel-group-type' is not supported or exists multiple times!
class : org.openhab.core.thing.xml.internal.ChannelGroupTypeXmlResult
required-type : org.openhab.core.thing.xml.internal.ChannelGroupTypeXmlResult
converter-type : org.openhab.core.thing.xml.internal.ChannelGroupTypeConverter
path : /thing-descriptions/channel-group-type[4]
line number : 56
class[1] : java.util.ArrayList
required-type[1] : java.util.ArrayList
converter-type[1] : com.thoughtworks.xstream.converters.collections.CollectionConverter
class[2] : org.openhab.core.thing.xml.internal.ThingDescriptionList
required-type[2] : org.openhab.core.thing.xml.internal.ThingDescriptionList
converter-type[2] : org.openhab.core.thing.xml.internal.ThingDescriptionConverter
version : 1.4.13
com.thoughtworks.xstream.converters.ConversionException: The attribute 'advanced' of the node 'channel-group-type' is not supported or exists multiple times!
line number : 56
version : 1.4.13
at org.openhab.core.config.xml.util.ConverterAttributeMapValidator.readValidatedAttributes(ConverterAttributeMapValidator.java:117) ~[?:?]
at org.openhab.core.config.xml.util.ConverterAttributeMapValidator.readValidatedAttributes(ConverterAttributeMapValidator.java:82) ~[?:?]
at org.openhab.core.thing.xml.internal.AbstractDescriptionTypeConverter.unmarshal(AbstractDescriptionTypeConverter.java:184) ~[?:?]
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:72) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.core.AbstractReferenceUnmarshaller.convert(AbstractReferenceUnmarshaller.java:72) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:66) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:50) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.converters.collections.AbstractCollectionConverter.readBareItem(AbstractCollectionConverter.java:132) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.converters.collections.AbstractCollectionConverter.readItem(AbstractCollectionConverter.java:117) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.converters.collections.CollectionConverter.addCurrentElementToCollection(CollectionConverter.java:98) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.converters.collections.CollectionConverter.populateCollection(CollectionConverter.java:91) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.converters.collections.CollectionConverter.populateCollection(CollectionConverter.java:85) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.converters.collections.CollectionConverter.unmarshal(CollectionConverter.java:80) ~[bundleFile:1.4.13]
at org.openhab.core.thing.xml.internal.ThingDescriptionConverter.unmarshal(ThingDescriptionConverter.java:53) ~[?:?]
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:134) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1404) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1383) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1334) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1288) ~[bundleFile:1.4.13]
at org.openhab.core.config.xml.util.XmlDocumentReader.readFromXML(XmlDocumentReader.java:106) ~[bundleFile:?]
at org.openhab.core.config.xml.osgi.XmlDocumentBundleTracker.parseDocuments(XmlDocumentBundleTracker.java:396) [bundleFile:?]
at org.openhab.core.config.xml.osgi.XmlDocumentBundleTracker.processBundle(XmlDocumentBundleTracker.java:382) [bundleFile:?]
at org.openhab.core.config.xml.osgi.XmlDocumentBundleTracker$2.run(XmlDocumentBundleTracker.java:347) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
2020-12-28 17:01:40.522 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channels for channel group 'am' for thing type 'phc:AM:00000', because channel group type 'phc:amChannels' could not be found.
2020-12-28 17:01:40.532 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channels for channel group 'em' for thing type 'phc:EM:00000', because channel group type 'phc:emChannels' could not be found.
2020-12-28 17:01:40.538 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channels for channel group 'emLed' for thing type 'phc:EM:00000', because channel group type 'phc:amChannels' could not be found.
2020-12-28 17:01:40.546 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channels for channel group 'em' for thing type 'phc:EM:01000', because channel group type 'phc:emChannels' could not be found.
2020-12-28 17:01:40.552 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channels for channel group 'emLed' for thing type 'phc:EM:01000', because channel group type 'phc:amChannels' could not be found.
