I’ve installed Philio PAN04-1 and use it with a single switch in edge-mode.
You can find details to Philio PAN04-1 here -> http://www.pepper1.net/zwavedb/device/610
Every thing is fine - PAN04-1 works in a correct way (the switch in wall works and openhab works too).
Afterwards I connect a second switch on board S2 and a second lamp on board N02.
Result: I can control the second lamp only via openhab. If I try to switch the lamp via the switch in the wall, nothing happens
The first switch works fine.
You can find my zwave configuration on the screenshot below:
Can anyone help me ?
