2016-10-08 14:14:54.966 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
2016-10-08 14:14:54.967 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:14:54.970 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class MULTI_CMD
2016-10-08 14:14:54.971 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Received Multi-Command Request
2016-10-08 14:14:54.973 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
2016-10-08 14:14:54.974 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:14:54.975 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received SENSOR_MULTILEVEL command V5
2016-10-08 14:14:54.977 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
2016-10-08 14:14:54.978 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Temperature(1), Scale = 0
2016-10-08 14:14:54.979 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 25
2016-10-08 14:14:54.981 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-10-08 14:14:54.982 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 25
2016-10-08 14:14:54.983 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: No converter set for channel zwave:device:d385b628:node9:sensor_temperature
2016-10-08 14:17:53.908 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
2016-10-08 14:17:53.918 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:17:53.922 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class MULTI_CMD
2016-10-08 14:17:53.925 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Received Multi-Command Request
2016-10-08 14:17:53.927 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
2016-10-08 14:17:53.929 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:17:53.930 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received SENSOR_MULTILEVEL command V5
2016-10-08 14:17:53.932 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
2016-10-08 14:17:53.934 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Luminance(3), Scale = 0
2016-10-08 14:17:53.936 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 7
2016-10-08 14:17:53.939 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-10-08 14:17:53.941 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 7
2016-10-08 14:17:53.943 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: No converter set for channel zwave:device:d385b628:node9:sensor_temperature
2016-10-08 14:18:43.465 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
2016-10-08 14:18:43.467 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:18:43.469 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class MULTI_CMD
2016-10-08 14:18:43.470 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Received Multi-Command Request
2016-10-08 14:18:43.471 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class BATTERY
2016-10-08 14:18:43.472 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:18:43.474 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 9: Received Battery Request
2016-10-08 14:18:43.475 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 9: Battery report value = 100
2016-10-08 14:18:43.476 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-10-08 14:18:43.477 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 100
2016-10-08 14:18:43.479 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Updating channel state zwave:device:d385b628:node9:battery-level to 100 [DecimalType]
2016-10-08 14:18:43.487 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class ALARM
2016-10-08 14:18:43.490 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:18:43.490 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Received Alarm Request V3
2016-10-08 14:18:43.492 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Process Alarm Report, V3, length 33
2016-10-08 14:18:43.494 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm report - 6 = 0, sensor=0, event=23, status=255
2016-10-08 14:18:43.496 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm Type = Access Control (6)
2016-10-08 14:18:43.502 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2016-10-08 14:18:43.503 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
2016-10-08 14:18:43.505 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
2016-10-08 14:18:43.507 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:18:43.508 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received SENSOR_MULTILEVEL command V5
2016-10-08 14:18:43.510 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
2016-10-08 14:18:43.511 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Luminance(3), Scale = 0
2016-10-08 14:18:43.513 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 6
2016-10-08 14:18:43.515 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-10-08 14:18:43.516 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 6
2016-10-08 14:18:43.517 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: No converter set for channel zwave:device:d385b628:node9:sensor_temperature
2016-10-08 14:18:43.518 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
2016-10-08 14:18:43.519 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:18:43.520 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received SENSOR_MULTILEVEL command V5
2016-10-08 14:18:43.521 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
2016-10-08 14:18:43.522 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Temperature(1), Scale = 0
2016-10-08 14:18:43.522 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 25
2016-10-08 14:18:43.525 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-10-08 14:18:43.526 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 25
2016-10-08 14:18:43.527 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: No converter set for channel zwave:device:d385b628:node9:sensor_temperature
2016-10-08 14:18:48.510 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
2016-10-08 14:18:48.510 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:18:48.512 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class BASIC
2016-10-08 14:18:48.513 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Received Basic Request
2016-10-08 14:18:48.513 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic Set sent to the controller will be processed as Basic Report
2016-10-08 14:18:48.514 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic report, value = 0x00
2016-10-08 14:18:48.516 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-10-08 14:18:48.516 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
2016-10-08 14:18:53.542 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
2016-10-08 14:18:53.543 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:18:53.546 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class MULTI_CMD
2016-10-08 14:18:53.547 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Received Multi-Command Request
2016-10-08 14:18:53.548 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
2016-10-08 14:18:53.549 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:18:53.550 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received SENSOR_MULTILEVEL command V5
2016-10-08 14:18:53.551 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
2016-10-08 14:18:53.553 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Luminance(3), Scale = 0
2016-10-08 14:18:53.554 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 6
2016-10-08 14:18:53.557 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-10-08 14:18:53.559 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 6
2016-10-08 14:18:53.561 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: No converter set for channel zwave:device:d385b628:node9:sensor_temperature
2016-10-08 14:19:53.254 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
2016-10-08 14:19:53.255 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:19:53.258 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class MULTI_CMD
2016-10-08 14:19:53.260 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Received Multi-Command Request
2016-10-08 14:19:53.268 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
2016-10-08 14:19:53.269 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:19:53.277 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received SENSOR_MULTILEVEL command V5
2016-10-08 14:19:53.281 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
2016-10-08 14:19:53.282 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Luminance(3), Scale = 0
2016-10-08 14:19:53.283 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 7
2016-10-08 14:19:53.286 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-10-08 14:19:53.289 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 7
2016-10-08 14:19:53.292 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: No converter set for channel zwave:device:d385b628:node9:sensor_temperature
2016-10-08 14:20:44.743 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
2016-10-08 14:20:44.744 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:20:44.749 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class BASIC
2016-10-08 14:20:44.754 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Received Basic Request
2016-10-08 14:20:44.761 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic Set sent to the controller will be processed as Basic Report
2016-10-08 14:20:44.762 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic report, value = 0xFF
2016-10-08 14:20:44.789 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-10-08 14:20:44.794 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
2016-10-08 14:20:44.811 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
2016-10-08 14:20:44.812 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:20:44.814 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class MULTI_CMD
2016-10-08 14:20:44.817 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Received Multi-Command Request
2016-10-08 14:20:44.818 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class BATTERY
2016-10-08 14:20:44.819 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:20:44.820 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 9: Received Battery Request
2016-10-08 14:20:44.823 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 9: Battery report value = 100
2016-10-08 14:20:44.829 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-10-08 14:20:44.831 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 100
2016-10-08 14:20:44.834 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Updating channel state zwave:device:d385b628:node9:battery-level to 100 [DecimalType]
2016-10-08 14:20:44.840 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class ALARM
2016-10-08 14:20:44.841 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:20:44.844 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Received Alarm Request V3
2016-10-08 14:20:44.845 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Process Alarm Report, V3, length 33
2016-10-08 14:20:44.847 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm report - 6 = 0, sensor=0, event=22, status=255
2016-10-08 14:20:44.858 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 9: Alarm Type = Access Control (6)
2016-10-08 14:20:44.860 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2016-10-08 14:20:44.861 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
2016-10-08 14:20:44.863 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
2016-10-08 14:20:44.864 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:20:44.865 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received SENSOR_MULTILEVEL command V5
2016-10-08 14:20:44.866 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
2016-10-08 14:20:44.868 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Luminance(3), Scale = 0
2016-10-08 14:20:44.869 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 7
2016-10-08 14:20:44.872 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-10-08 14:20:44.873 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 7
2016-10-08 14:20:44.875 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: No converter set for channel zwave:device:d385b628:node9:sensor_temperature
2016-10-08 14:20:44.876 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
2016-10-08 14:20:44.877 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:20:44.878 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received SENSOR_MULTILEVEL command V5
2016-10-08 14:20:44.879 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
2016-10-08 14:20:44.881 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Temperature(1), Scale = 0
2016-10-08 14:20:44.882 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 25
2016-10-08 14:20:44.884 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-10-08 14:20:44.885 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 25
2016-10-08 14:20:44.887 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: No converter set for channel zwave:device:d385b628:node9:sensor_temperature
2016-10-08 14:20:45.063 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 9: Application update request. Node information received.
2016-10-08 14:20:45.065 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:20:45.067 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 9: Is awake with 0 messages in the wake-up queue.
2016-10-08 14:20:45.070 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveWakeUpEvent
2016-10-08 14:20:45.973 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
2016-10-08 14:20:45.975 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:20:45.979 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class WAKE_UP
2016-10-08 14:20:45.981 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 9: Received Wake Up Request
2016-10-08 14:20:45.982 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 9: Received WAKE_UP_NOTIFICATION
2016-10-08 14:20:45.984 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 9: Is awake with 0 messages in the wake-up queue.
2016-10-08 14:20:45.987 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveWakeUpEvent
2016-10-08 14:20:46.993 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 9: No more messages, go back to sleep
2016-10-08 14:20:47.000 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 9: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2016-10-08 14:20:47.014 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 9: Sending REQUEST Message = 01 09 00 13 09 02 84 08 25 85 C2
2016-10-08 14:20:47.053 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 9: Sent Data successfully placed on stack.
2016-10-08 14:20:47.103 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 9: SendData Request. CallBack ID = 133, Status = Transmission complete and ACK received(0)
2016-10-08 14:20:47.105 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:20:47.116 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2016-10-08 14:20:47.120 [DEBUG] [curityCommandClassWithInitialization] - NODE 9: updating lastSentMessageTimestamp
2016-10-08 14:20:47.123 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 9: Went to sleep
2016-10-08 14:20:47.127 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 9: Is sleeping
2016-10-08 14:20:47.128 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 9: Response processed after 111ms/4902ms.
2016-10-08 14:20:49.518 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:49.558 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:49.622 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:49.766 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:49.951 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:50.045 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:50.250 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:50.527 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:50.619 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:50.934 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:51.173 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:51.303 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:51.493 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:51.658 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:53.024 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
2016-10-08 14:20:53.025 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:20:53.053 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class MULTI_CMD
2016-10-08 14:20:53.058 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Received Multi-Command Request
2016-10-08 14:20:53.069 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
2016-10-08 14:20:53.070 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:20:53.071 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received SENSOR_MULTILEVEL command V5
2016-10-08 14:20:53.071 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
2016-10-08 14:20:53.076 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Temperature(1), Scale = 0
2016-10-08 14:20:53.079 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 25
2016-10-08 14:20:53.081 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-10-08 14:20:53.082 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 25
2016-10-08 14:20:53.083 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: No converter set for channel zwave:device:d385b628:node9:sensor_temperature
2016-10-08 14:20:56.802 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:20:57.367 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Transaction not completed: node address inconsistent. lastSent=9, incoming=255
2016-10-08 14:21:16.259 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
2016-10-08 14:21:16.267 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:21:16.276 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class BASIC
2016-10-08 14:21:16.279 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Received Basic Request
2016-10-08 14:21:16.282 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic Set sent to the controller will be processed as Basic Report
2016-10-08 14:21:16.284 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 9: Basic report, value = 0x00
2016-10-08 14:21:16.287 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-10-08 14:21:16.289 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
2016-10-08 14:21:52.769 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
2016-10-08 14:21:52.770 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:21:52.772 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class MULTI_CMD
2016-10-08 14:21:52.773 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Received Multi-Command Request
2016-10-08 14:21:52.774 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
2016-10-08 14:21:52.774 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:21:52.775 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received SENSOR_MULTILEVEL command V5
2016-10-08 14:21:52.776 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
2016-10-08 14:21:52.777 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Temperature(1), Scale = 0
2016-10-08 14:21:52.778 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 25
2016-10-08 14:21:52.780 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-10-08 14:21:52.781 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 25
2016-10-08 14:21:52.782 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: No converter set for channel zwave:device:d385b628:node9:sensor_temperature
2016-10-08 14:22:52.478 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Application Command Request (ALIVE:DONE)
2016-10-08 14:22:52.479 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2016-10-08 14:22:52.481 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class MULTI_CMD
2016-10-08 14:22:52.482 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Received Multi-Command Request
2016-10-08 14:22:52.483 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Incoming command class SENSOR_MULTILEVEL
2016-10-08 14:22:52.484 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 9: Calling handleApplicationCommandRequest.
2016-10-08 14:22:52.485 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Received SENSOR_MULTILEVEL command V5
2016-10-08 14:22:52.485 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Multi Level REPORT received
2016-10-08 14:22:52.486 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Type = Temperature(1), Scale = 0
2016-10-08 14:22:52.487 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 9: Sensor Value = 25
2016-10-08 14:22:52.489 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-10-08 14:22:52.490 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 25
2016-10-08 14:22:52.491 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: No converter set for channel zwave:device:d385b628:node9:sensor_temperature
