Hi all, I´m facing with the same problem as @schmidmuc.
Everything works fine with this sensor (temperature, luminance) but the sensor doesn´t send ":sensor_door " values, but “sensor_binary” ON/OFF.
I´ve mapped these values in translation.map, anyway all I get is status “XYZ” (where XYZ is “-” to know if something is sent there).
But in the logfile I can´t see this value, so I don´t know what exactly has been sent.
I´v also checked the configuration parameters of the sensor (customer function=20, etc.), it worked fine in OH1 before.
I´ve deleted the whole thing and item, but have still the same result
Node 20
Interestent thing is that “sensor_door” works fine for another version of this Philio Sensor I´m using: PST02A!
Do you have any idea, why
- sensor_binary is sent instead of sensor_door
- why the value of sensor_binary (ON/OFF) is not translated correctly
> 2018-12-12 06:24:39.915 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 1F 00 04 00 14 19 8F 01 04 03 80 03 64 04 30 03 FF 0A 05 31 05 03 01 04 06 31 05 01 22 00 DC BF 2018-12-12 06:24:39.916 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 1F 00 04 00 14 19 8F 01 04 03 80 03 64 04 30 03 FF 0A 05 31 05 03 01 04 06 31 05 01 22 00 DC BF 2018-12-12 06:24:39.916 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = 0xBF 2018-12-12 06:24:39.917 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Checksum matched 2018-12-12 06:24:39.918 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Message payload = 00 14 19 8F 01 04 03 80 03 64 04 30 03 FF 0A 05 31 05 03 01 04 06 31 05 01 22 00 DC 2018-12-12 06:24:39.918 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK 2018-12-12 06:24:39.919 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 2018-12-12 06:24:39.919 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0 2018-12-12 06:24:39.920 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = 0xBF 2018-12-12 06:24:39.921 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 1F 00 04 00 14 19 8F 01 04 03 80 03 64 04 30 03 FF 0A 05 31 05 03 01 04 06 31 05 01 22 00 DC BF 2018-12-12 06:24:39.922 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 1F 00 04 00 14 19 8F 01 04 03 80 03 64 04 30 03 FF 0A 05 31 05 03 01 04 06 31 05 01 22 00 DC BF 2018-12-12 06:24:39.923 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 14 19 8F 01 04 03 80 03 64 04 30 03 FF 0A 05 31 05 03 01 04 06 31 05 01 22 00 DC 2018-12-12 06:24:39.923 [TRACE] [ve.internal.protocol.ZWaveController] - Incoming Message type = REQUEST 2018-12-12 06:24:39.923 [TRACE] [ssage.ApplicationCommandMessageClass] - Handle Message Application Command Request 2018-12-12 06:24:39.924 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 20: Application Command Request (INITIALIZING:WAIT) 2018-12-12 06:24:39.924 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 20: Node is ALIVE. Init stage is WAIT. 2018-12-12 06:24:39.924 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveNodeStatusEvent 2018-12-12 06:24:39.925 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 20: Node Status event during initialisation - Node is ALIVE 2018-12-12 06:24:39.925 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 20: Node advancer - WAIT: queue length(0), free to send(true) 2018-12-12 06:24:39.925 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 20: Node advancer: loop - WAIT try 1: stageAdvanced(false) 2018-12-12 06:24:39.925 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 20: Node advancer: WAIT - Listening=false, FrequentlyListening=false 2018-12-12 06:24:39.926 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 20: Node advancer: WAIT - Still waiting! 2018-12-12 06:24:39.926 [TRACE] [alization.ZWaveNodeInitStageAdvancer] - NODE 20: Node Status event during initialisation processed 2018-12-12 06:24:39.926 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got an event from Z-Wave network: ZWaveNodeStatusEvent 2018-12-12 06:24:39.927 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Setting ONLINE 2018-12-12 06:24:39.927 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 20: Node Status event - Node is ALIVE 2018-12-12 06:24:39.928 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 20: Incoming command class MULTI_CMD 2018-12-12 06:24:39.928 [TRACE] [ssage.ApplicationCommandMessageClass] - NODE 20: Found Command Class MULTI_CMD, passing to handleApplicationCommandRequest 2018-12-12 06:24:39.928 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Received Multi-Command Request 2018-12-12 06:24:39.929 [TRACE] [dclass.ZWaveMultiCommandCommandClass] - Process Multi-command Encapsulation 2018-12-12 06:24:39.929 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Incoming command class BATTERY 2018-12-12 06:24:39.929 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Calling handleApplicationCommandRequest. 2018-12-12 06:24:39.930 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 20: Received Battery Request 2018-12-12 06:24:39.930 [TRACE] [ommandclass.ZWaveBatteryCommandClass] - Process Battery Report 2018-12-12 06:24:39.931 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 20: Battery report value = 100 2018-12-12 06:24:39.931 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent 2018-12-12 06:24:39.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got an event from Z-Wave network: ZWaveCommandClassValueEvent 2018-12-12 06:24:39.932 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 100 2018-12-12 06:24:39.932 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Updating channel state zwave:device:95603ab1:node20:battery-level to 100 [DecimalType] 2018-12-12 06:24:39.933 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Incoming command class SENSOR_BINARY 2018-12-12 06:24:39.933 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Calling handleApplicationCommandRequest. 2018-12-12 06:24:39.933 [TRACE] [dclass.ZWaveBinarySensorCommandClass] - Handle Message Sensor Binary Request 2018-12-12 06:24:39.934 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 20: Received SENSOR_BINARY command V2 2018-12-12 06:24:39.934 [TRACE] [dclass.ZWaveBinarySensorCommandClass] - Process Sensor Binary Report 2018-12-12 06:24:39.934 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Processing Sensor Type 10 2018-12-12 06:24:39.934 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Sensor Type is DOORWINDOW 2018-12-12 06:24:39.935 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 20: Sensor Binary report, type=Door/Window, value=255 2018-12-12 06:24:39.935 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveBinarySensorValueEvent 2018-12-12 06:24:39.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent 2018-12-12 06:24:39.936 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_BINARY, value = 255 2018-12-12 06:24:39.936 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Updating channel state zwave:device:95603ab1:node20:sensor_binary to ON [OnOffType] 2018-12-12 06:24:39.937 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Incoming command class SENSOR_MULTILEVEL 2018-12-12 06:24:39.938 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Calling handleApplicationCommandRequest. 2018-12-12 06:24:39.938 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V5 2018-12-12 06:24:39.938 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Sensor Multi Level REPORT received 2018-12-12 06:24:39.939 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Sensor Type = Luminance(3), Scale = 0 2018-12-12 06:24:39.939 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Sensor Value = 4 2018-12-12 06:24:39.940 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent 2018-12-12 06:24:39.940 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent 2018-12-12 06:24:39.940 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 4 2018-12-12 06:24:39.941 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Updating channel state zwave:device:95603ab1:node20:sensor_luminance to 4 [DecimalType] 2018-12-12 06:24:39.941 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Incoming command class SENSOR_MULTILEVEL 2018-12-12 06:24:39.942 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Calling handleApplicationCommandRequest. 2018-12-12 06:24:39.942 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V5 2018-12-12 06:24:39.942 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Sensor Multi Level REPORT received 2018-12-12 06:24:39.943 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Sensor Type = Temperature(1), Scale = 0 2018-12-12 06:24:39.943 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Sensor Value = 22 2018-12-12 06:24:39.944 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent 2018-12-12 06:24:39.944 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent 2018-12-12 06:24:39.944 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 22 2018-12-12 06:24:39.945 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 20: Sensor is reporting scale 0, requiring conversion to 0. Value is now 22. 2018-12-12 06:24:39.945 [DEBUG] [converter.ZWaveCommandClassConverter] - Converted temperature from 22C to 22C 2018-12-12 06:24:39.946 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Updating channel state zwave:device:95603ab1:node20:sensor_temperature to 22 [DecimalType] 2018-12-12 06:24:39.947 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Transaction not completed: node address inconsistent. lastSent=2, incoming=255 2018-12-12 06:24:41.337 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Received SOF 2018-12-12 06:24:41.340 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 1F 00 04 00 14 19 8F 01 04 03 80 03 64 04 30 03 00 0A 05 31 05 03 01 06 06 31 05 01 22 00 DC 42 2018-12-12 06:24:41.341 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 1F 00 04 00 14 19 8F 01 04 03 80 03 64 04 30 03 00 0A 05 31 05 03 01 06 06 31 05 01 22 00 DC 42 2018-12-12 06:24:41.341 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = 0x42 2018-12-12 06:24:41.342 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Checksum matched 2018-12-12 06:24:41.342 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Message payload = 00 14 19 8F 01 04 03 80 03 64 04 30 03 00 0A 05 31 05 03 01 06 06 31 05 01 22 00 DC 2018-12-12 06:24:41.343 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK 2018-12-12 06:24:41.343 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 2018-12-12 06:24:41.344 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0 2018-12-12 06:24:41.344 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = 0x42 2018-12-12 06:24:41.344 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 1F 00 04 00 14 19 8F 01 04 03 80 03 64 04 30 03 00 0A 05 31 05 03 01 06 06 31 05 01 22 00 DC 42 2018-12-12 06:24:41.345 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 1F 00 04 00 14 19 8F 01 04 03 80 03 64 04 30 03 00 0A 05 31 05 03 01 06 06 31 05 01 22 00 DC 42 2018-12-12 06:24:41.346 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 14 19 8F 01 04 03 80 03 64 04 30 03 00 0A 05 31 05 03 01 06 06 31 05 01 22 00 DC 2018-12-12 06:24:41.346 [TRACE] [ve.internal.protocol.ZWaveController] - Incoming Message type = REQUEST 2018-12-12 06:24:41.347 [TRACE] [ssage.ApplicationCommandMessageClass] - Handle Message Application Command Request 2018-12-12 06:24:41.347 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 20: Application Command Request (ALIVE:WAIT) 2018-12-12 06:24:41.347 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 20: Incoming command class MULTI_CMD 2018-12-12 06:24:41.348 [TRACE] [ssage.ApplicationCommandMessageClass] - NODE 20: Found Command Class MULTI_CMD, passing to handleApplicationCommandRequest 2018-12-12 06:24:41.348 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Received Multi-Command Request 2018-12-12 06:24:41.348 [TRACE] [dclass.ZWaveMultiCommandCommandClass] - Process Multi-command Encapsulation 2018-12-12 06:24:41.349 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Incoming command class BATTERY 2018-12-12 06:24:41.349 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Calling handleApplicationCommandRequest. 2018-12-12 06:24:41.349 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 20: Received Battery Request 2018-12-12 06:24:41.350 [TRACE] [ommandclass.ZWaveBatteryCommandClass] - Process Battery Report 2018-12-12 06:24:41.350 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 20: Battery report value = 100 2018-12-12 06:24:41.350 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent 2018-12-12 06:24:41.351 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got an event from Z-Wave network: ZWaveCommandClassValueEvent 2018-12-12 06:24:41.351 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 100 2018-12-12 06:24:41.351 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Updating channel state zwave:device:95603ab1:node20:battery-level to 100 [DecimalType] 2018-12-12 06:24:41.352 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Incoming command class SENSOR_BINARY 2018-12-12 06:24:41.352 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Calling handleApplicationCommandRequest. 2018-12-12 06:24:41.353 [TRACE] [dclass.ZWaveBinarySensorCommandClass] - Handle Message Sensor Binary Request 2018-12-12 06:24:41.353 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 20: Received SENSOR_BINARY command V2 2018-12-12 06:24:41.353 [TRACE] [dclass.ZWaveBinarySensorCommandClass] - Process Sensor Binary Report 2018-12-12 06:24:41.354 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Processing Sensor Type 10 2018-12-12 06:24:41.354 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Sensor Type is DOORWINDOW 2018-12-12 06:24:41.354 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 20: Sensor Binary report, type=Door/Window, value=0 2018-12-12 06:24:41.355 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveBinarySensorValueEvent 2018-12-12 06:24:41.355 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent 2018-12-12 06:24:41.356 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_BINARY, value = 0 2018-12-12 06:24:41.356 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Updating channel state zwave:device:95603ab1:node20:sensor_binary to OFF [OnOffType] 2018-12-12 06:24:41.360 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Incoming command class SENSOR_MULTILEVEL 2018-12-12 06:24:41.360 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Calling handleApplicationCommandRequest. 2018-12-12 06:24:41.361 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V5 2018-12-12 06:24:41.361 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Sensor Multi Level REPORT received 2018-12-12 06:24:41.362 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Sensor Type = Luminance(3), Scale = 0 2018-12-12 06:24:41.362 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Sensor Value = 6 2018-12-12 06:24:41.362 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent 2018-12-12 06:24:41.363 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent 2018-12-12 06:24:41.363 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 6 2018-12-12 06:24:41.363 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Updating channel state zwave:device:95603ab1:node20:sensor_luminance to 6 [DecimalType] 2018-12-12 06:24:41.364 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Incoming command class SENSOR_MULTILEVEL 2018-12-12 06:24:41.365 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 20: Calling handleApplicationCommandRequest. 2018-12-12 06:24:41.365 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V5 2018-12-12 06:24:41.366 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Sensor Multi Level REPORT received 2018-12-12 06:24:41.366 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Sensor Type = Temperature(1), Scale = 0 2018-12-12 06:24:41.366 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 20: Sensor Value = 22 2018-12-12 06:24:41.366 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent 2018-12-12 06:24:41.367 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent 2018-12-12 06:24:41.367 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 22 2018-12-12 06:24:41.367 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 20: Sensor is reporting scale 0, requiring conversion to 0. Value is now 22. 2018-12-12 06:24:41.368 [DEBUG] [converter.ZWaveCommandClassConverter] - Converted temperature from 22C to 22C
