I’ve pulled down the sensor from the ceiling, fully removed and excluded the device. Whilst resetting everything, I somehow managed to change the uid on my zwave stick so I had go through every device and re-add.
Anyway here is the log from including the PAN03 again, please let me know if anything jumps out at you:
2022-12-12 16:51:31.584 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=38, payload=26 00 00 02
2022-12-12 16:51:31.586 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 3E 0A 32 02 A1 22 09 13 00 00 00 00 76
2022-12-12 16:51:31.586 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 454: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 38
2022-12-12 16:51:31.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-12-12 16:51:31.588 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=62, callback=0, payload=00 3E 0A 32 02 A1 22 09 13 00 00 00 00
2022-12-12 16:51:31.588 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 454: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 38
2022-12-12 16:51:31.589 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 454: (Callback 38)
2022-12-12 16:51:31.590 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2022-12-12 16:51:31.591 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 454: callback 38
2022-12-12 16:51:31.592 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=38, payload=26 00 00 02
2022-12-12 16:51:31.594 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 62: SendData Request. CallBack ID = 38, Status = Transmission complete and ACK received(0)
2022-12-12 16:51:31.595 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 454: Advanced to WAIT_DATA
2022-12-12 16:51:31.596 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: TID 454: Transaction not completed
2022-12-12 16:51:31.597 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=62, callback=0, payload=00 3E 0A 32 02 A1 22 09 13 00 00 00 00
2022-12-12 16:51:31.598 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-12-12 16:51:31.599 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-12-12 16:51:31.601 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-12-12 16:51:31.603 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: SECURITY NOT required on COMMAND_CLASS_METER
2022-12-12 16:51:31.604 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 62: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-12-12 16:51:31.606 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 62: Meter: Type=Electric(1), Scale=V(4), Value=232.3
2022-12-12 16:51:31.608 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Commands processed 1.
2022-12-12 16:51:31.609 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5d257b42.
2022-12-12 16:51:31.610 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5d257b42.
2022-12-12 16:51:31.611 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: notifyTransactionResponse TID:454 DONE
2022-12-12 16:51:31.613 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2022-12-12 16:51:31.614 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-12-12 16:51:31.614 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 454: Transaction event listener: DONE: DONE -> UNINTIALIZED
2022-12-12 16:51:31.616 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-12-12 16:51:31.617 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-12-12 16:51:31.620 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@1fa89801
2022-12-12 16:51:31.621 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Node Init transaction completed with response COMPLETE
2022-12-12 16:51:31.622 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: SECURITY NOT required on COMMAND_CLASS_METER
2022-12-12 16:51:31.624 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: Command Class COMMAND_CLASS_METER is NOT required to be secured
2022-12-12 16:51:31.625 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: ZWaveCommandClassTransactionPayload - send to node
2022-12-12 16:51:31.627 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: SECURITY NOT required on COMMAND_CLASS_METER
2022-12-12 16:51:31.628 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: Command Class COMMAND_CLASS_METER is NOT required to be secured
2022-12-12 16:51:31.629 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@36793b4b
2022-12-12 16:51:31.631 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Adding to device queue
2022-12-12 16:51:31.632 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Added 455 to queue - size 28
2022-12-12 16:51:31.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-12-12 16:51:31.635 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 3E 03 32 01 28 25 27 C2
2022-12-12 16:51:31.638 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 62: Sending REQUEST Message = 01 0A 00 13 3E 03 32 01 28 25 27 C2
2022-12-12 16:51:31.639 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2022-12-12 16:51:31.642 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 455: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 39
2022-12-12 16:51:31.649 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2022-12-12 16:51:31.650 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-12-12 16:51:31.652 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-12-12 16:51:31.652 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2022-12-12 16:51:31.654 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 455: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 39
2022-12-12 16:51:31.655 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-12-12 16:51:31.656 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2022-12-12 16:51:31.657 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-12-12 16:51:31.658 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-12-12 16:51:31.660 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-12-12 16:51:31.661 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 455: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 39
2022-12-12 16:51:31.663 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-12-12 16:51:31.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 455: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 39
2022-12-12 16:51:31.666 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-12-12 16:51:31.668 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 27 00 00 03 CF
2022-12-12 16:51:31.669 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 62: sentData successfully placed on stack.
2022-12-12 16:51:31.669 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 455: Advanced to WAIT_REQUEST
2022-12-12 16:51:31.671 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: TID 455: Transaction not completed
2022-12-12 16:51:31.671 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=39, payload=27 00 00 03
2022-12-12 16:51:31.672 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-12-12 16:51:31.674 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-12-12 16:51:31.677 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=39, payload=27 00 00 03
2022-12-12 16:51:31.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 455: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 39
2022-12-12 16:51:31.681 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 3E 0A 32 02 A1 4A 00 00 00 00 00 00 04
2022-12-12 16:51:31.682 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-12-12 16:51:31.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 455: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 39
2022-12-12 16:51:31.683 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=62, callback=0, payload=00 3E 0A 32 02 A1 4A 00 00 00 00 00 00
2022-12-12 16:51:31.685 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 455: (Callback 39)
2022-12-12 16:51:31.686 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2022-12-12 16:51:31.687 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 455: callback 39
2022-12-12 16:51:31.688 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=39, payload=27 00 00 03
2022-12-12 16:51:31.689 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 62: SendData Request. CallBack ID = 39, Status = Transmission complete and ACK received(0)
2022-12-12 16:51:31.690 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 455: Advanced to WAIT_DATA
2022-12-12 16:51:31.693 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: TID 455: Transaction not completed
2022-12-12 16:51:31.696 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=62, callback=0, payload=00 3E 0A 32 02 A1 4A 00 00 00 00 00 00
2022-12-12 16:51:31.697 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-12-12 16:51:31.698 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-12-12 16:51:31.699 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-12-12 16:51:31.701 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: SECURITY NOT required on COMMAND_CLASS_METER
2022-12-12 16:51:31.702 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 62: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-12-12 16:51:31.703 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 62: Meter: Type=Electric(1), Scale=A(5), Value=0E+1
2022-12-12 16:51:31.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Commands processed 1.
2022-12-12 16:51:31.707 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@270f6db9.
2022-12-12 16:51:31.707 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@270f6db9.
2022-12-12 16:51:31.708 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: notifyTransactionResponse TID:455 DONE
2022-12-12 16:51:31.710 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2022-12-12 16:51:31.710 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 455: Transaction event listener: DONE: DONE -> UNINTIALIZED
2022-12-12 16:51:31.711 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@78112d99
2022-12-12 16:51:31.712 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Node Init transaction completed with response COMPLETE
2022-12-12 16:51:31.713 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: SECURITY NOT required on COMMAND_CLASS_METER
2022-12-12 16:51:31.715 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: Command Class COMMAND_CLASS_METER is NOT required to be secured
2022-12-12 16:51:31.717 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: ZWaveCommandClassTransactionPayload - send to node
2022-12-12 16:51:31.719 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: SECURITY NOT required on COMMAND_CLASS_METER
2022-12-12 16:51:31.721 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: Command Class COMMAND_CLASS_METER is NOT required to be secured
2022-12-12 16:51:31.721 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-12-12 16:51:31.723 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@6f9e0843
2022-12-12 16:51:31.723 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-12-12 16:51:31.724 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Adding to device queue
2022-12-12 16:51:31.726 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Added 456 to queue - size 28
2022-12-12 16:51:31.729 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-12-12 16:51:31.731 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 3E 03 32 01 10 25 28 F5
2022-12-12 16:51:31.732 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 62: Sending REQUEST Message = 01 0A 00 13 3E 03 32 01 10 25 28 F5
2022-12-12 16:51:31.740 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2022-12-12 16:51:31.740 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2022-12-12 16:51:31.743 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-12-12 16:51:31.744 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 456: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 40
2022-12-12 16:51:31.744 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2022-12-12 16:51:31.746 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 1<>127 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-12-12 16:51:31.747 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-12-12 16:51:31.748 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (1): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2022-12-12 16:51:31.749 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 456: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 40
2022-12-12 16:51:31.751 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2022-12-12 16:51:31.752 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-12-12 16:51:31.753 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 456: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 40
2022-12-12 16:51:31.754 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-12-12 16:51:31.755 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 456: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 40
2022-12-12 16:51:31.756 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2022-12-12 16:51:31.757 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 62: sentData successfully placed on stack.
2022-12-12 16:51:31.759 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 456: Advanced to WAIT_REQUEST
2022-12-12 16:51:31.760 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: TID 456: Transaction not completed
2022-12-12 16:51:31.761 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-12-12 16:51:31.762 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-12-12 16:51:31.764 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 28 00 00 02 C1
2022-12-12 16:51:31.765 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=40, payload=28 00 00 02
2022-12-12 16:51:31.767 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=40, payload=28 00 00 02
2022-12-12 16:51:31.768 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 456: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 40
2022-12-12 16:51:31.769 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2022-12-12 16:51:31.770 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 456: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 40
2022-12-12 16:51:31.772 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 456: (Callback 40)
2022-12-12 16:51:31.774 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 3E 0E 32 02 21 34 00 00 00 02 00 00 00 00 00 00 F8
2022-12-12 16:51:31.778 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2022-12-12 16:51:31.780 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 456: callback 40
2022-12-12 16:51:31.783 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=40, payload=28 00 00 02
2022-12-12 16:51:31.785 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 62: SendData Request. CallBack ID = 40, Status = Transmission complete and ACK received(0)
2022-12-12 16:51:31.786 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 456: Advanced to WAIT_DATA
2022-12-12 16:51:31.787 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: TID 456: Transaction not completed
2022-12-12 16:51:31.792 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=62, callback=0, payload=00 3E 0E 32 02 21 34 00 00 00 02 00 00 00 00 00 00
2022-12-12 16:51:31.797 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=62, callback=0, payload=00 3E 0E 32 02 21 34 00 00 00 02 00 00 00 00 00 00
2022-12-12 16:51:31.799 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-12-12 16:51:31.800 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-12-12 16:51:31.802 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-12-12 16:51:31.803 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: SECURITY NOT required on COMMAND_CLASS_METER
2022-12-12 16:51:31.805 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 62: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-12-12 16:51:31.808 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 62: Meter: Type=Electric(1), Scale=W(2), Value=0.2
2022-12-12 16:51:31.811 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Commands processed 1.
2022-12-12 16:51:31.813 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2e23e1d0.
2022-12-12 16:51:31.817 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2e23e1d0.
2022-12-12 16:51:31.822 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: notifyTransactionResponse TID:456 DONE
2022-12-12 16:51:31.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2022-12-12 16:51:31.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 456: Transaction event listener: DONE: DONE -> UNINTIALIZED
2022-12-12 16:51:31.827 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-12-12 16:51:31.828 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@342dfd21
2022-12-12 16:51:31.828 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-12-12 16:51:31.829 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Node Init transaction completed with response COMPLETE
2022-12-12 16:51:31.831 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_FIRMWARE_UPDATE_MD
2022-12-12 16:51:31.831 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-12-12 16:51:31.832 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_SWITCH_ALL
2022-12-12 16:51:31.834 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_ZWAVEPLUS_INFO
2022-12-12 16:51:31.835 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Node advancer: Initialisation complete!
2022-12-12 16:51:31.850 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Node advancer - advancing to DYNAMIC_END
2022-12-12 16:51:31.855 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 62: Serializing to file /var/lib/openhab/zwave/network_e3faa253__node_62.xml
2022-12-12 16:51:31.915 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Node advancer - advancing to DONE
2022-12-12 16:51:31.919 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 62: Serializing to file /var/lib/openhab/zwave/network_e3faa253__node_62.xml
2022-12-12 16:51:44.585 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 38 03 30 03 00 FA
2022-12-12 16:51:44.586 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=56, callback=0, payload=00 38 03 30 03 00
2022-12-12 16:51:44.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=56, callback=0, payload=00 38 03 30 03 00
2022-12-12 16:51:44.588 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
network_e3faa253__node_62 3.xml (10.8 KB)
