Philips Hue CLIP 2 API v2 Discussion Thread
when I switch off my HUE’s with a rule the log is showing a warning. Ideas, why that happens?
items:
Switch allHueLamps "all Hue-Lamps" {channel="hue:room:69f9118654:8:on-off-only"}
rule:
allHueLamps.sendCommand(OFF)
log:
[WARN ] [e.internal.handler.Clip2ThingHandler] - Command 'OFF' for thing 'hue:room:69f9118654:8', channel 'hue:room:69f9118654:8:on-off-only' failed with error 'Unexpected Content-Type: text/html'.
Can you enable debug level and try again? It might reveal more specifically what’s failing, for example the html body of the response.
Does anyone know what would be the equivalent of the effect channel (type Switch) for API v2 thing types 0200, 0210 and 0220? It’s documented as “This channel supports color looping.”
I was using it to start an RGB color loop in my son’s room when his gamer laptop is turned on. :slightly_smiling_face: With API v2 there now is an effect channel of type String which I don’t know how to use:
This will have been fixed by PR #15169 and PR #15324
Let me answer this in two parts…
  1. Effects: Every thing (device or room or zone) that supports effects will have an effects channel. And the supported state options for that channel are dynamically populated in Main UI depending on the respective thing’s capabilities. (Same applies for things that support alerts). The effects and alerts state options are the same as you see in the Hue app. To activate an effect or alert via Main UI just click on the current value “NO EFFECT” and the drop down will show you the available state options; which you can select.
  2. Color loop: in API v2 this is not an effect, nor an alert. Instead API v2 allows you to set up a free list of possible states with transitions and time delays between each state step. So you can program (say) your own color loop with your own custom colour steps, transition delays and intervals. Or you can program your Christmas tree light show. Or whatever. It is an incredibly powerful model, but IMHO completely impossible to integrate in OH.
EDIT: I don’t fully recall, (the meethue developers portal is down so I cannot check it), but I think such a free programmable series of states, transitions and delays is called a ‘dynamic effect’. But the handling is certainly completely different from the standard effects.
Thanks! I tried on my test system and now see exactly what you described:
However, on my production system, where I initially checked, this is not clickable:
This is outside the scope of my question, and I’ll need to figure this out. However, it was the reason for my initial confusion.
I guess the conclusion is that effect channel (and underlying API) no longer supports the color loop, so I’ll need to figure out a way to code this on my own. When I dive into this and get something working through the API, in the back of my head, I’ll try to think of ways to maybe expose some of this functionality to openHAB so I won’t have to code it completely outside.
Thanks for the explanation.
I was now able to create the color loop through Hue Labs in the app. So maybe managing Hue Labs controls could be possible.
Wanted to do a quick peek, but https://developers.meethue.com/ currently:
502 Bad Gateway
502 Bad Gateway
nginx
Project for later. :slight_smile:
Yes. From memory the dynamic_effect DTO is a JSON array of state command entries, where each entry in the array can contain a colorXy / colorTemperature / dimmer / onOff command element with also (optionally) a transition time and I think a delay to start the next step, plus also a flag if the array of state commands shall execute as one-off or in a repeating loop. Hue Labs is a tool for creating such an array of state command entries. I cannot think of any way of creating such an array of state command entries within OH – probably you would need to invent some kind of script interpreter – which is the reason why I did not implement it in #13570 :wink:
4YI I reported the error here https://developers.meethue.com/forum/t/502-error-on-https-developers-meethue-com/6929
And here too.
That report is inaccessible right now, because… you know… 502. :smiley:
I was thinking about just creating it in Hue Labs in the app… but if it could then be activated from openHAB, that would be sufficient. I also wouldn’t like to (or see a way to) create such a script interpreter within openHAB. :slight_smile:
From memory I think you could indeed activate a predefined dynamic effect from OH. But you would need to know the UID of the effect in advance, since I think there is no process in the API to discover predefined dynamic effects.
Actually the /forum sub-page is accessible still. But the main page gives an HTTP 502 error.
Hi Andrew
I created an “Effect?” using Hue labs on the APP. This was applied to my “Lounge Room” and when tested it works fine (using the APP).
I cannot get the Effect Channel to show up on the room, even after deleting and re-adding the room.
Am I missing something?
The TRACE log is as follows:
2023-07-29 20:10:42.599 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2023-07-29T18:10:42Z","data":[{"id":"82e0f4b2-ea5f-4442-bc3f-a0e2bbc1886d","id_v1":"/lights/6","owner":{"rid":"d7aa1d72-009f-4b8d-a28f-798da9d7b33f","rtype":"device"},"status":"connectivity_issue","type":"zigbee_connectivity"}],"id":"550db402-929b-43e4-b9d0-7174e541278a","type":"update"}]
2023-07-29 20:10:42.601 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2023-07-29T18:10:42Z","data":[{"id":"82e0f4b2-ea5f-4442-bc3f-a0e2bbc1886d","id_v1":"/lights/6","owner":{"rid":"d7aa1d72-009f-4b8d-a28f-798da9d7b33f","rtype":"device"},"status":"connectivity_issue","type":"zigbee_connectivity"}],"id":"550db402-929b-43e4-b9d0-7174e541278a","type":"update"}]
2023-07-29 20:10:58.244 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2023-07-29T18:10:58Z","data":[{"id":"ffc936d4-978d-402a-854c-a5da60ca3ad7","id_v1":"/lights/2","owner":{"rid":"9bb57c71-2a47-4eaf-a915-e55c7ac78d5b","rtype":"device"},"status":"connectivity_issue","type":"zigbee_connectivity"}],"id":"cc1f2b64-803a-4333-936c-5ed04edecacc","type":"update"}]
2023-07-29 20:11:07.254 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2023-07-29T18:11:07Z","data":[{"id":"33278fd3-2358-42af-9383-2fe19a5e4ce0","id_v1":"/lights/1","owner":{"rid":"6485b533-3d67-429c-89ff-e7ba813513f6","rtype":"device"},"status":"connectivity_issue","type":"zigbee_connectivity"}],"id":"3b879402-86bc-4468-b32d-0d721cdf397c","type":"update"}]
2023-07-29 20:11:07.255 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2023-07-29T18:11:07Z","data":[{"id":"33278fd3-2358-42af-9383-2fe19a5e4ce0","id_v1":"/lights/1","owner":{"rid":"6485b533-3d67-429c-89ff-e7ba813513f6","rtype":"device"},"status":"connectivity_issue","type":"zigbee_connectivity"}],"id":"3b879402-86bc-4468-b32d-0d721cdf397c","type":"update"}]
2023-07-29 20:11:24.575 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - GET https://10.163.199.253/clip/v2/resource/device HTTP/2
2023-07-29 20:11:24.624 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - HTTP/2 200 OK (Content-Type: application/json) << {"errors":[],"data":[{"id":"ee1aa624-91b6-41f9-9921-e3ae2bae291d","id_v1":"/lights/4","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 4","archetype":"ceiling_round"},"identify":null,"services":[{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},{"rid":"06c12063-18bd-423d-b6d7-6a1b1d53ebc3","rtype":"zigbee_connectivity"},{"rid":"bba7de72-9cda-40d6-820e-6d6da529539f","rtype":"entertainment"}],"type":"device"},{"id":"0c18b50b-572f-4f50-ad3e-476293accd7b","id_v1":"/lights/8","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 8","archetype":"ceiling_round"},"identify":null,"services":[{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},{"rid":"4a30a959-6dbb-40e4-9025-002ae82d0b53","rtype":"zigbee_connectivity"},{"rid":"fe7f4fb7-9340-4133-bdda-e4bf786bd187","rtype":"entertainment"}],"type":"device"},{"id":"d7aa1d72-009f-4b8d-a28f-798da9d7b33f","id_v1":"/lights/6","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 6","archetype":"ceiling_round"},"identify":{},"services":[{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},{"rid":"82e0f4b2-ea5f-4442-bc3f-a0e2bbc1886d","rtype":"zigbee_connectivity"},{"rid":"911bf558-1307-4978-a7cd-16f008d11691","rtype":"entertainment"}],"type":"device"},{"id":"fb032c0c-4187-4f93-9bab-3ae1c3dc5567","id_v1":"/lights/7","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 7","archetype":"ceiling_round"},"identify":{},"services":[{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},{"rid":"97a64528-2dc7-425e-b2b8-7f72f6dbefed","rtype":"zigbee_connectivity"},{"rid":"eb56af30-4886-4e2c-8f34-08094d2abff8","rtype":"entertainment"}],"type":"device"},{"id":"42328b03-94e3-441c-a1e1-a174efff6f73","id_v1":"/lights/10","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Riley Light 2","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"d9871d5d-02a0-4158-8b47-596f917b6340","rtype":"light"},{"rid":"98a1b4ef-43e0-4a43-9229-64e9e69dec12","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"6485b533-3d67-429c-89ff-e7ba813513f6","id_v1":"/lights/1","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 1","archetype":"ceiling_round"},"identify":{},"services":[{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},{"rid":"33278fd3-2358-42af-9383-2fe19a5e4ce0","rtype":"zigbee_connectivity"},{"rid":"5c2f5a73-f01d-4319-90b1-fa2adf16543a","rtype":"entertainment"}],"type":"device"},{"id":"3f922aa6-2647-483c-bb3f-c32ec8d7cce6","id_v1":"/lights/11","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Riley Light 3","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"2e657fe9-fd81-43b4-b4ec-c057ff00fbe1","rtype":"light"},{"rid":"12e799cd-216f-454d-8075-705da92445a1","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"4a1f8a73-3543-41f4-b4d9-173dc03747f5","id_v1":"/lights/3","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 3","archetype":"ceiling_round"},"identify":{},"services":[{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},{"rid":"6cec8768-bb8d-4c9e-8370-865eeb413312","rtype":"zigbee_connectivity"},{"rid":"3bef0fff-efb9-46db-ba83-6f4ea04ce9a8","rtype":"entertainment"}],"type":"device"},{"id":"805f6b62-aa16-4be4-9342-c6f1932110a7","product_data":{"model_id":"BSB002","manufacturer_name":"Signify Netherlands B.V.","product_name":"Philips hue","product_archetype":"bridge_v2","certified":true,"software_version":"1.59.1959097030"},"metadata":{"name":"Philips hue","archetype":"bridge_v2"},"identify":{},"services":[{"rid":"a9d28cc5-ff01-40d0-afe7-f7c9e5205571","rtype":"bridge"},{"rid":"5fa5b437-8bb2-4a44-9807-89b1968673cf","rtype":"zigbee_connectivity"},{"rid":"30aef9de-ff7b-4cc3-b7f3-8549449fe4fd","rtype":"entertainment"},{"rid":"132d8d68-ad52-4175-8f92-f69aa1e4e584","rtype":"zigbee_device_discovery"}],"type":"device"},{"id":"5d89d53f-165b-49ef-a2e5-34590fbe6fc4","id_v1":"/lights/15","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Ethan Light 2","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"32d0c787-5bd2-40dc-b4d6-f229493a12e3","rtype":"light"},{"rid":"c183b49c-2800-4169-8416-3c523af95532","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"45dd7454-2ae9-4a9b-90ca-b89e39023cbf","id_v1":"/lights/14","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Ethan Light 1","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"b5b0089f-01cc-405e-9301-b9abe27ad3e9","rtype":"light"},{"rid":"37e50047-bff8-4f1e-b087-fd38fee4baaf","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"6865d13e-18a1-4511-8fa3-c8251ce5cc3e","id_v1":"/lights/16","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Ethan Light 3","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"1aaafabd-dc30-4f56-b2d4-9ec90b982383","rtype":"light"},{"rid":"a995e64d-a6c5-4e8f-98f8-25a70027563a","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"9bb57c71-2a47-4eaf-a915-e55c7ac78d5b","id_v1":"/lights/2","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 2","archetype":"ceiling_round"},"identify":{},"services":[{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},{"rid":"ffc936d4-978d-402a-854c-a5da60ca3ad7","rtype":"zigbee_connectivity"},{"rid":"f1b0189d-a5db-438a-8f15-4d0c4f30904c","rtype":"entertainment"}],"type":"device"},{"id":"1a76d0a1-8dfb-404b-b6ba-3f5565405a85","id_v1":"/lights/17","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Ethan Light 4","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"9b925046-9253-4a70-af58-9cfc8af88fa5","rtype":"light"},{"rid":"a48c9eed-e507-4c28-ad06-415031300aec","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"18d47ab1-36fd-4c0f-8206-a95969f6b8b9","id_v1":"/lights/5","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 5","archetype":"ceiling_round"},"identify":{},"services":[{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},{"rid":"b091836b-3d15-469c-b708-8e2c24da3997","rtype":"zigbee_connectivity"},{"rid":"258b4219-5502-4ed1-ac2d-bb5cef292196","rtype":"entertainment"}],"type":"device"},{"id":"9ca6fe80-e5f2-4ea9-bcbe-f2c5ff565d53","id_v1":"/lights/12","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Riley Light 4","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"06236f4d-3175-4609-8cd5-fdf5764ad615","rtype":"light"},{"rid":"5d0c5385-37cb-4a18-a1c5-180aed0a7c38","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"cf8dbe0f-fc9a-4ac3-a5c8-743e5beed749","id_v1":"/lights/18","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Riley Light 1","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"6d1f0ce1-acfb-410c-866e-9c2a94a3c01b","rtype":"light"},{"rid":"86d6eebd-0e47-4321-ac28-719b97cbbcec","rtype":"zigbee_connectivity"}],"type":"device"}]}
2023-07-29 20:11:24.628 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - GET https://10.163.199.253/clip/v2/resource/bridge_home HTTP/2
2023-07-29 20:11:24.687 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - HTTP/2 200 OK (Content-Type: application/json) << {"errors":[],"data":[{"id":"bd9983ea-ce23-447e-95a8-cfd02bd037d7","id_v1":"/groups/0","children":[{"rid":"805f6b62-aa16-4be4-9342-c6f1932110a7","rtype":"device"},{"rid":"0c3872fc-9c14-4d02-8ebc-bb3a8c142aea","rtype":"room"},{"rid":"a781070d-57b2-433a-815f-2059eb63dacc","rtype":"room"},{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"}],"services":[{"rid":"c766b174-536e-4a2d-bc62-e3365c5229ae","rtype":"grouped_light"}],"type":"bridge_home"}]}
2023-07-29 20:11:24.687 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - GET https://10.163.199.253/clip/v2/resource/room HTTP/2
2023-07-29 20:11:24.745 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - HTTP/2 200 OK (Content-Type: application/json) << {"errors":[],"data":[{"id":"0c3872fc-9c14-4d02-8ebc-bb3a8c142aea","id_v1":"/groups/5","children":[{"rid":"1a76d0a1-8dfb-404b-b6ba-3f5565405a85","rtype":"device"},{"rid":"45dd7454-2ae9-4a9b-90ca-b89e39023cbf","rtype":"device"},{"rid":"5d89d53f-165b-49ef-a2e5-34590fbe6fc4","rtype":"device"},{"rid":"6865d13e-18a1-4511-8fa3-c8251ce5cc3e","rtype":"device"}],"services":[{"rid":"f5f2fa98-94f2-4f60-977b-a8a4f454e6aa","rtype":"grouped_light"}],"metadata":{"name":"Ethan","archetype":"bedroom"},"type":"room"},{"id":"a781070d-57b2-433a-815f-2059eb63dacc","id_v1":"/groups/4","children":[{"rid":"3f922aa6-2647-483c-bb3f-c32ec8d7cce6","rtype":"device"},{"rid":"42328b03-94e3-441c-a1e1-a174efff6f73","rtype":"device"},{"rid":"9ca6fe80-e5f2-4ea9-bcbe-f2c5ff565d53","rtype":"device"},{"rid":"cf8dbe0f-fc9a-4ac3-a5c8-743e5beed749","rtype":"device"}],"services":[{"rid":"f1b79c17-908f-4d06-8450-46b6c4761b33","rtype":"grouped_light"}],"metadata":{"name":"Riley","archetype":"bedroom"},"type":"room"},{"id":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","id_v1":"/groups/1","children":[{"rid":"0c18b50b-572f-4f50-ad3e-476293accd7b","rtype":"device"},{"rid":"18d47ab1-36fd-4c0f-8206-a95969f6b8b9","rtype":"device"},{"rid":"4a1f8a73-3543-41f4-b4d9-173dc03747f5","rtype":"device"},{"rid":"6485b533-3d67-429c-89ff-e7ba813513f6","rtype":"device"},{"rid":"9bb57c71-2a47-4eaf-a915-e55c7ac78d5b","rtype":"device"},{"rid":"d7aa1d72-009f-4b8d-a28f-798da9d7b33f","rtype":"device"},{"rid":"ee1aa624-91b6-41f9-9921-e3ae2bae291d","rtype":"device"},{"rid":"fb032c0c-4187-4f93-9bab-3ae1c3dc5567","rtype":"device"}],"services":[{"rid":"ba365fdb-f055-410c-9021-561b725cdc22","rtype":"grouped_light"}],"metadata":{"name":"Lounge","archetype":"living_room"},"type":"room"}]}
2023-07-29 20:11:24.757 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - GET https://10.163.199.253/clip/v2/resource/zone HTTP/2
2023-07-29 20:11:24.770 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - HTTP/2 200 OK (Content-Type: application/json) << {"errors":[],"data":[]}
2023-07-29 20:11:38.190 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - GET https://10.163.199.253/clip/v2/resource/scene HTTP/2
2023-07-29 20:11:38.263 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - HTTP/2 200 OK (Content-Type: application/json) << {"errors":[],"data":[{"id":"64dd2f42-f70d-43d4-b6a5-2657ee3697fc","id_v1":"/scenes/VrqCXWtm3Zzvyun","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":48.43},"color":{"xy":{"x":0.2911,"y":0.2248}}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":48.43},"color":{"xy":{"x":0.486,"y":0.3757}}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":48.43},"color":{"xy":{"x":0.486,"y":0.3757}}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":43.31},"color":{"xy":{"x":0.2924,"y":0.2189}}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":48.03},"color":{"xy":{"x":0.5982,"y":0.3776}}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":48.03},"color":{"xy":{"x":0.3595,"y":0.2878}}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":48.03},"color":{"xy":{"x":0.5418,"y":0.3867}}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":48.03},"color":{"xy":{"x":0.4843,"y":0.3752}}}}],"recall":null,"metadata":{"name":"Tropical twilight","image":{"rid":"a6a03e6a-fe6e-45bc-b686-878137f3ba91","rtype":"public_image"},"appdata":"XetsG_r01_d16"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.5982,"y":0.3776}},"dimming":{"brightness":48.03}},{"color":{"xy":{"x":0.5823,"y":0.3631}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.479,"y":0.3736}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.3625,"y":0.2796}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.2412,"y":0.1171}},"dimming":{"brightness":44.09}}],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":455},"dimming":{"brightness":44.09}}],"effects":[]},"speed":0.6388888888888888,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"a81bc06c-45d1-40b3-89da-7f70b9ad80c0","id_v1":"/scenes/HaEuRw03pJbiUUb","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":367}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":367}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":367}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":367}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":367}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":367}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":367}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":367}}}],"recall":null,"metadata":{"name":"Bright","image":{"rid":"732ff1d9-76a7-4630-aad0-c8acc499bb0b","rtype":"public_image"},"appdata":"UwwWQ_r01_d05"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[],"dimming":[],"color_temperature":[],"effects":[]},"speed":0.5,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"49943a31-77bf-47da-ab92-cc6ef66b6dab","id_v1":"/scenes/45OB9mFr59IVN3R","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":78.35},"color":{"xy":{"x":0.6396,"y":0.3345}}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":78.35},"color":{"xy":{"x":0.4641,"y":0.4515}}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":78.35},"color":{"xy":{"x":0.3866,"y":0.4028}}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":80.31},"color":{"xy":{"x":0.5318,"y":0.3854}}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":77.95},"color":{"xy":{"x":0.4634,"y":0.4509}}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":77.95},"color":{"xy":{"x":0.5878,"y":0.3541}}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":77.95},"color":{"xy":{"x":0.5327,"y":0.3871}}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":77.95},"color":{"xy":{"x":0.5327,"y":0.3871}}}}],"recall":{},"metadata":{"name":"Savanna sunset","image":{"rid":"4f2ed241-5aea-4c9d-8028-55d2b111e06f","rtype":"public_image"},"appdata":"w6nhp_r01_d15"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.6424,"y":0.3344}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.5878,"y":0.3559}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.5305,"y":0.3861}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.4641,"y":0.4515}},"dimming":{"brightness":78.35}},{"color":{"xy":{"x":0.4162,"y":0.4341}},"dimming":{"brightness":57.87}}],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":455},"dimming":{"brightness":57.87}}],"effects":[]},"speed":0.6190476190476191,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"b2229b6a-5700-44ba-9d3f-00f9399cc64f","id_v1":"/scenes/We3GMgMHeUjMzkX","actions":[{"target":{"rid":"b5b0089f-01cc-405e-9301-b9abe27ad3e9","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":53.15},"color":{"xy":{"x":0.1598,"y":0.3036}}}},{"target":{"rid":"32d0c787-5bd2-40dc-b4d6-f229493a12e3","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":53.15},"color":{"xy":{"x":0.1545,"y":0.0715}}}},{"target":{"rid":"1aaafabd-dc30-4f56-b2d4-9ec90b982383","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":53.15},"color":{"xy":{"x":0.1561,"y":0.1586}}}},{"target":{"rid":"9b925046-9253-4a70-af58-9cfc8af88fa5","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":53.15},"color":{"xy":{"x":0.1532,"y":0.0476}}}}],"recall":{},"metadata":{"name":"Motown","image":{"rid":"60de81e9-ffa6-485a-b7d1-e50c47912f18","rtype":"public_image"},"appdata":"BDvAA_r05_d48"},"group":{"rid":"0c3872fc-9c14-4d02-8ebc-bb3a8c142aea","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.1532,"y":0.0476}},"dimming":{"brightness":53.15}},{"color":{"xy":{"x":0.1544,"y":0.0711}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.1561,"y":0.1586}},"dimming":{"brightness":53.15}},{"color":{"xy":{"x":0.1572,"y":0.202}},"dimming":{"brightness":53.15}},{"color":{"xy":{"x":0.1598,"y":0.3036}},"dimming":{"brightness":53.15}}],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":455},"dimming":{"brightness":53.15}}],"effects":[]},"speed":0.6904761904761905,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"6211060a-2bc6-4cd6-ab09-7398dd5b90b9","id_v1":"/scenes/mm2Ul3FRAmE4eWz","actions":[{"target":{"rid":"b5b0089f-01cc-405e-9301-b9abe27ad3e9","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":77.95},"color":{"xy":{"x":0.4039,"y":0.1914}}}},{"target":{"rid":"32d0c787-5bd2-40dc-b4d6-f229493a12e3","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":77.95},"color":{"xy":{"x":0.2299,"y":0.0862}}}},{"target":{"rid":"1aaafabd-dc30-4f56-b2d4-9ec90b982383","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":77.95},"color":{"xy":{"x":0.5403,"y":0.4219}}}},{"target":{"rid":"9b925046-9253-4a70-af58-9cfc8af88fa5","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":77.95},"color":{"xy":{"x":0.474,"y":0.4378}}}}],"recall":{},"metadata":{"name":"Vapor wave","image":{"rid":"d8d1a014-5551-4ada-8da1-5a527d7bc09b","rtype":"public_image"},"appdata":"oT6nf_r05"},"group":{"rid":"0c3872fc-9c14-4d02-8ebc-bb3a8c142aea","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.1783,"y":0.1212}},"dimming":{"brightness":77.95}},{"color":{"xy":{"x":0.2299,"y":0.0862}},"dimming":{"brightness":77.95}},{"color":{"xy":{"x":0.4039,"y":0.1914}},"dimming":{"brightness":77.95}},{"color":{"xy":{"x":0.5403,"y":0.4219}},"dimming":{"brightness":77.95}},{"color":{"xy":{"x":0.474,"y":0.4378}},"dimming":{"brightness":77.95}}],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":400},"dimming":{"brightness":77.95}}],"effects":[]},"speed":0.626984126984127,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"d78a37c0-e14b-4906-9cf6-357b1af039d7","id_v1":"/scenes/G2z7FI1Cr7W6R2V","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":156}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":156}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":156}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":156}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":156}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":156}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":156}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":156}}}],"recall":{},"metadata":{"name":"Energize","image":{"rid":"7fd2ccc5-5749-4142-b7a5-66405a676f03","rtype":"public_image"},"appdata":"E8wA6_r01_d04"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":156},"dimming":{"brightness":100.0}}],"effects":[]},"speed":0.5,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"de4bef7a-f77a-4809-a624-6e9ca87d2b8e","id_v1":"/scenes/4TFeFljpOuLJBeJ","actions":[{"target":{"rid":"d9871d5d-02a0-4158-8b47-596f917b6340","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":66.14},"color_temperature":{"mirek":286}}},{"target":{"rid":"2e657fe9-fd81-43b4-b4ec-c057ff00fbe1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":44.49},"color_temperature":{"mirek":286}}},{"target":{"rid":"06236f4d-3175-4609-8cd5-fdf5764ad615","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":44.49},"color_temperature":{"mirek":286}}},{"target":{"rid":"6d1f0ce1-acfb-410c-866e-9c2a94a3c01b","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":44.49},"color_temperature":{"mirek":286}}}],"recall":{},"metadata":{"name":"everyday","appdata":"Ooz0x_r04"},"group":{"rid":"a781070d-57b2-433a-815f-2059eb63dacc","rtype":"room"},"palette":{"color":[],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":286},"dimming":{"brightness":100.0}}],"effects":[]},"speed":0.6031746031746031,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"371096e9-cae4-4c98-ba19-b082e95b5713","id_v1":"/scenes/juZNwu7QSuNOKVf","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":233}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":233}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":233}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":233}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":233}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":233}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":233}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":233}}}],"recall":{},"metadata":{"name":"Concentrate","image":{"rid":"b90c8900-a6b7-422c-a5d3-e170187dbf8c","rtype":"public_image"},"appdata":"njkJF_r01_d03"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":233},"dimming":{"brightness":100.0}}],"effects":[]},"speed":0.5,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"b152a37a-0d45-4afd-863b-f11695f595cb","id_v1":"/scenes/CnlJbsW04J5HweL","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.202,"y":0.0707}}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.4347,"y":0.1892}}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.5834,"y":0.272}}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":75.59},"color":{"xy":{"x":0.4157,"y":0.4495}}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.6737,"y":0.3221}}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.2198,"y":0.1425}}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.408,"y":0.517}}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.4803,"y":0.464}}}}],"recall":{},"metadata":{"name":"Ocean Dawn","appdata":"rSmgT_r01"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.4157,"y":0.4495}},"dimming":{"brightness":75.59}},{"color":{"xy":{"x":0.408,"y":0.517}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.4803,"y":0.464}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.6735,"y":0.3218}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.5834,"y":0.272}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.4347,"y":0.1892}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.2198,"y":0.1425}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.2018,"y":0.0711}},"dimming":{"brightness":100.0}}],"dimming":[],"color_temperature":[],"effects":[]},"speed":0.5,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"1567f02c-9f3d-4869-a75a-c56728ec896a","id_v1":"/scenes/c9DY7Zo6MaO--Av","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":78.74},"color":{"xy":{"x":0.4325,"y":0.4337}}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":78.74},"color":{"xy":{"x":0.4325,"y":0.4337}}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":78.74},"color":{"xy":{"x":0.4325,"y":0.4337}}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":99.61},"color":{"xy":{"x":0.4325,"y":0.4337}}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":78.74},"color":{"xy":{"x":0.4325,"y":0.4337}}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":78.74},"color":{"xy":{"x":0.4325,"y":0.4337}}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":78.74},"color":{"xy":{"x":0.4325,"y":0.4337}}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":78.74},"color":{"xy":{"x":0.4325,"y":0.4337}}}}],"recall":{},"metadata":{"name":"Optimize","appdata":"7WcqG_r01"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.4325,"y":0.4337}},"dimming":{"brightness":78.74}}],"dimming":[],"color_temperature":[],"effects":[]},"speed":0.5,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"8ce8d6fd-efa7-45f3-a381-2cce5a406e2c","id_v1":"/scenes/4uzs65vwcMzv0Iu","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":0.39},"color":{"xy":{"x":0.561,"y":0.4042}}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":0.39},"color":{"xy":{"x":0.561,"y":0.4042}}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":0.39},"color":{"xy":{"x":0.561,"y":0.4042}}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":0.39},"color":{"xy":{"x":0.561,"y":0.4042}}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":0.39},"color":{"xy":{"x":0.561,"y":0.4042}}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":0.39},"color":{"xy":{"x":0.561,"y":0.4042}}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":0.39},"color":{"xy":{"x":0.561,"y":0.4042}}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":0.39},"color":{"xy":{"x":0.561,"y":0.4042}}}}],"recall":{},"metadata":{"name":"Nightlight","image":{"rid":"28bbfeff-1a0c-444e-bb4b-0b74b88e0c95","rtype":"public_image"},"appdata":"6bt1V_r01_d07"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[],"dimming":[],"color_temperature":[],"effects":[]},"speed":0.5,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"e099b656-83ef-43d8-84ec-5d72f9e0ea15","id_v1":"/scenes/PhSHGYov0PShKkM","actions":[{"target":{"rid":"b5b0089f-01cc-405e-9301-b9abe27ad3e9","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.3515,"y":0.5637}}}},{"target":{"rid":"32d0c787-5bd2-40dc-b4d6-f229493a12e3","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.3515,"y":0.5637}}}},{"target":{"rid":"1aaafabd-dc30-4f56-b2d4-9ec90b982383","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.3515,"y":0.5637}}}},{"target":{"rid":"9b925046-9253-4a70-af58-9cfc8af88fa5","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.3515,"y":0.5637}}}}],"recall":{},"metadata":{"name":"Green","appdata":"9KrVY_r05"},"group":{"rid":"0c3872fc-9c14-4d02-8ebc-bb3a8c142aea","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.3515,"y":0.5637}},"dimming":{"brightness":100.0}}],"dimming":[],"color_temperature":[],"effects":[]},"speed":0.6031746031746031,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"e01c74c3-23ea-4417-a385-2f27ac170ba9","id_v1":"/scenes/08hfM4fLL8XGBrf","actions":[{"target":{"rid":"d9871d5d-02a0-4158-8b47-596f917b6340","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":370}}},{"target":{"rid":"2e657fe9-fd81-43b4-b4ec-c057ff00fbe1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":370}}},{"target":{"rid":"06236f4d-3175-4609-8cd5-fdf5764ad615","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":370}}},{"target":{"rid":"6d1f0ce1-acfb-410c-866e-9c2a94a3c01b","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":370}}}],"recall":{},"metadata":{"name":"Everyday","image":{"rid":"732ff1d9-76a7-4630-aad0-c8acc499bb0b","rtype":"public_image"},"appdata":"y3syN_r04_d05"},"group":{"rid":"a781070d-57b2-433a-815f-2059eb63dacc","rtype":"room"},"palette":{"color":[],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":370},"dimming":{"brightness":100.0}}],"effects":[]},"speed":0.6031746031746031,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"1b5ae513-c5ca-453a-a128-2eb74494bde1","id_v1":"/scenes/ZN7pJvfZ3zRmobu","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":30.31},"color_temperature":{"mirek":367}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":30.31},"color_temperature":{"mirek":367}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":30.31},"color_temperature":{"mirek":367}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":30.31},"color_temperature":{"mirek":367}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":30.31},"color_temperature":{"mirek":367}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":30.31},"color_temperature":{"mirek":367}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":30.31},"color_temperature":{"mirek":367}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":30.31},"color_temperature":{"mirek":367}}}],"recall":{},"metadata":{"name":"Dimmed","image":{"rid":"8c74b9ba-6e89-4083-a2a7-b10a1e566fed","rtype":"public_image"},"appdata":"qj6tS_r01_d06"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[],"dimming":[],"color_temperature":[],"effects":[]},"speed":0.5,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"189196e0-b2b4-4f2e-8f2a-74d4ae67b93c","id_v1":"/scenes/6VxPBj6S9DeITMV","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":84.25},"color":{"xy":{"x":0.5056,"y":0.2673}}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":84.25},"color":{"xy":{"x":0.4345,"y":0.2809}}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":84.25},"color":{"xy":{"x":0.394,"y":0.2967}}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":80.71},"color":{"xy":{"x":0.4766,"y":0.3289}}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":83.86},"color":{"xy":{"x":0.335,"y":0.3169}}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":83.86},"color":{"xy":{"x":0.4331,"y":0.2821}}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":83.86},"color":{"xy":{"x":0.3945,"y":0.2966}}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":83.86},"color":{"xy":{"x":0.3945,"y":0.2966}}}}],"recall":{},"metadata":{"name":"Spring blossom","image":{"rid":"adfa9c3e-e9aa-4b65-b9d3-c5b2c0576715","rtype":"public_image"},"appdata":"fhs8u_r01_d18"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.3945,"y":0.2966}},"dimming":{"brightness":83.86}},{"color":{"xy":{"x":0.4345,"y":0.2809}},"dimming":{"brightness":84.25}},{"color":{"xy":{"x":0.4435,"y":0.2537}},"dimming":{"brightness":59.84}},{"color":{"xy":{"x":0.5056,"y":0.2673}},"dimming":{"brightness":84.25}},{"color":{"xy":{"x":0.514,"y":0.3338}},"dimming":{"brightness":59.84}}],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":370},"dimming":{"brightness":59.84}}],"effects":[]},"speed":0.5595238095238095,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"10fb6384-7042-4f71-b0bc-2c26393f8a63","id_v1":"/scenes/4ZntBG-VjP7vbZA","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":75.2},"color":{"xy":{"x":0.5018,"y":0.4156}}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":75.2},"color":{"xy":{"x":0.5018,"y":0.4156}}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":75.2},"color":{"xy":{"x":0.5018,"y":0.4156}}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.5021,"y":0.4137}}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":75.2},"color":{"xy":{"x":0.5018,"y":0.4156}}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":75.2},"color":{"xy":{"x":0.5018,"y":0.4156}}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":79.53},"color":{"xy":{"x":0.5018,"y":0.4156}}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":75.2},"color":{"xy":{"x":0.5018,"y":0.4156}}}}],"recall":{},"metadata":{"name":"Comfortable","appdata":"Nxbko_r01"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.5018,"y":0.4156}},"dimming":{"brightness":75.2}}],"dimming":[],"color_temperature":[],"effects":[]},"speed":0.5,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"79f278e7-0457-4308-b7a7-c151907671b6","id_v1":"/scenes/WSpVvjXZGKZTIX0","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":false}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":false}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":false}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":false}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":false}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":false}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.6744,"y":0.3212}}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":false}}}],"recall":{},"metadata":{"name":"Alarm Test","appdata":"FQ0WF_r01"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.6744,"y":0.3212}},"dimming":{"brightness":100.0}}],"dimming":[],"color_temperature":[],"effects":[]},"speed":0.6031746031746031,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"9a8352b8-1abd-4a29-a93e-5802cf115437","id_v1":"/scenes/mZsqeOqvo7pUrbu","actions":[{"target":{"rid":"b5b0089f-01cc-405e-9301-b9abe27ad3e9","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":233}}},{"target":{"rid":"32d0c787-5bd2-40dc-b4d6-f229493a12e3","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":233}}},{"target":{"rid":"1aaafabd-dc30-4f56-b2d4-9ec90b982383","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":233}}},{"target":{"rid":"9b925046-9253-4a70-af58-9cfc8af88fa5","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":233}}}],"recall":{},"metadata":{"name":"Concentrate","image":{"rid":"b90c8900-a6b7-422c-a5d3-e170187dbf8c","rtype":"public_image"},"appdata":"ptAx-_r05_d03"},"group":{"rid":"0c3872fc-9c14-4d02-8ebc-bb3a8c142aea","rtype":"room"},"palette":{"color":[],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":233},"dimming":{"brightness":100.0}}],"effects":[]},"speed":0.6031746031746031,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"2a36e73e-b4a4-4f79-ba21-f1546cb2f433","id_v1":"/scenes/uBs1fmgE3nQHuP1","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":56.69},"color_temperature":{"mirek":447}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":56.69},"color_temperature":{"mirek":447}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":56.69},"color_temperature":{"mirek":447}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":56.69},"color_temperature":{"mirek":447}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":56.69},"color_temperature":{"mirek":447}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":56.69},"color_temperature":{"mirek":447}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":56.69},"color_temperature":{"mirek":447}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":56.69},"color_temperature":{"mirek":447}}}],"recall":{},"metadata":{"name":"Relax","image":{"rid":"a1f7da49-d181-4328-abea-68c9dc4b5416","rtype":"public_image"},"appdata":"qV2I4_r01_d01"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[],"dimming":[],"color_temperature":[],"effects":[]},"speed":0.5,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"02a3bd91-7da5-47b7-bb6d-5223683cc318","id_v1":"/scenes/wXoFAzX7otxfnd3","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":346}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":346}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":346}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":346}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":346}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":346}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":346}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":346}}}],"recall":{},"metadata":{"name":"Read","image":{"rid":"e101a77f-9984-4f61-aac8-15741983c656","rtype":"public_image"},"appdata":"JEVgF_r01_d02"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":346},"dimming":{"brightness":100.0}}],"effects":[]},"speed":0.5,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"f6bd2b7b-a775-4fee-bc80-6139e9407304","id_v1":"/scenes/3NB5ev9RN6fqVPX","actions":[{"target":{"rid":"d9871d5d-02a0-4158-8b47-596f917b6340","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":79.92},"color":{"xy":{"x":0.3972,"y":0.4025}}}},{"target":{"rid":"2e657fe9-fd81-43b4-b4ec-c057ff00fbe1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":79.92},"color":{"xy":{"x":0.24,"y":0.2761}}}},{"target":{"rid":"06236f4d-3175-4609-8cd5-fdf5764ad615","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":79.92},"color":{"xy":{"x":0.4419,"y":0.4164}}}},{"target":{"rid":"6d1f0ce1-acfb-410c-866e-9c2a94a3c01b","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":79.92},"color":{"xy":{"x":0.2674,"y":0.3018}}}}],"recall":{},"metadata":{"name":"Blossom","image":{"rid":"a8897dcb-5c90-4459-8e4a-02b984bd32b5","rtype":"public_image"},"appdata":"8f7kD_r04"},"group":{"rid":"a781070d-57b2-433a-815f-2059eb63dacc","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.24,"y":0.2761}},"dimming":{"brightness":79.92}},{"color":{"xy":{"x":0.2667,"y":0.3001}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.3986,"y":0.4027}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.4419,"y":0.4164}},"dimming":{"brightness":79.92}},{"color":{"xy":{"x":0.5119,"y":0.4249}},"dimming":{"brightness":79.92}}],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":335},"dimming":{"brightness":79.92}}],"effects":[]},"speed":0.626984126984127,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"756f5a28-8051-4196-99dc-b629828c080d","id_v1":"/scenes/9-OAEyyCwo9UCbw","actions":[{"target":{"rid":"b5b0089f-01cc-405e-9301-b9abe27ad3e9","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":61.81},"color":{"xy":{"x":0.5115,"y":0.3625}}}},{"target":{"rid":"32d0c787-5bd2-40dc-b4d6-f229493a12e3","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":61.81},"color":{"xy":{"x":0.5865,"y":0.2575}}}},{"target":{"rid":"1aaafabd-dc30-4f56-b2d4-9ec90b982383","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":61.81},"color":{"xy":{"x":0.2219,"y":0.0825}}}},{"target":{"rid":"9b925046-9253-4a70-af58-9cfc8af88fa5","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":61.81},"color":{"xy":{"x":0.1916,"y":0.3954}}}}],"recall":{},"metadata":{"name":"Soho","image":{"rid":"e4ee61c3-ecdd-4005-b483-58207e693258","rtype":"public_image"},"appdata":"NBfrb_r05_d45"},"group":{"rid":"0c3872fc-9c14-4d02-8ebc-bb3a8c142aea","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.5865,"y":0.2575}},"dimming":{"brightness":61.81}},{"color":{"xy":{"x":0.5115,"y":0.3625}},"dimming":{"brightness":61.81}},{"color":{"xy":{"x":0.5019,"y":0.2751}},"dimming":{"brightness":61.81}},{"color":{"xy":{"x":0.2215,"y":0.0822}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.1916,"y":0.3954}},"dimming":{"brightness":61.81}}],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":370},"dimming":{"brightness":61.81}}],"effects":[]},"speed":0.626984126984127,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"fc344d9a-4c63-4e38-8082-d23b48b2152c","id_v1":"/scenes/zqEj6fQ8nSN8AUO","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":84.65},"color_temperature":{"mirek":413}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":84.65},"color_temperature":{"mirek":413}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":84.65},"color_temperature":{"mirek":413}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":84.65},"color_temperature":{"mirek":413}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":84.65},"color_temperature":{"mirek":413}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":84.65},"color_temperature":{"mirek":413}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":84.65},"color_temperature":{"mirek":413}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":84.65},"color_temperature":{"mirek":413}}}],"recall":{},"metadata":{"name":"Lounge Default","appdata":"zekdy_r01"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.4695,"y":0.4125}},"dimming":{"brightness":100.0}}],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":413},"dimming":{"brightness":84.65}}],"effects":[]},"speed":0.5,"auto_dynamic":false,"status":{"active":"static"},"type":"scene"},{"id":"220ec5f6-58cc-4dd7-a6dc-606f95b2dd6d","id_v1":"/scenes/7obvBQY70kP9Qdb","actions":[{"target":{"rid":"b5b0089f-01cc-405e-9301-b9abe27ad3e9","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":370}}},{"target":{"rid":"32d0c787-5bd2-40dc-b4d6-f229493a12e3","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":370}}},{"target":{"rid":"1aaafabd-dc30-4f56-b2d4-9ec90b982383","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":370}}},{"target":{"rid":"9b925046-9253-4a70-af58-9cfc8af88fa5","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":370}}}],"recall":{},"metadata":{"name":"Bright","image":{"rid":"732ff1d9-76a7-4630-aad0-c8acc499bb0b","rtype":"public_image"},"appdata":"rDNYP_r05_d05"},"group":{"rid":"0c3872fc-9c14-4d02-8ebc-bb3a8c142aea","rtype":"room"},"palette":{"color":[],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":370},"dimming":{"brightness":100.0}}],"effects":[]},"speed":0.6031746031746031,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"a874c531-aef4-494b-bef8-446157dc3ec9","id_v1":"/scenes/TRMWQ1umQArsOHx","actions":[{"target":{"rid":"b5b0089f-01cc-405e-9301-b9abe27ad3e9","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":46.85},"color":{"xy":{"x":0.5894,"y":0.2589}}}},{"target":{"rid":"32d0c787-5bd2-40dc-b4d6-f229493a12e3","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":46.85},"color":{"xy":{"x":0.1753,"y":0.0585}}}},{"target":{"rid":"1aaafabd-dc30-4f56-b2d4-9ec90b982383","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":46.85},"color":{"xy":{"x":0.2676,"y":0.103}}}},{"target":{"rid":"9b925046-9253-4a70-af58-9cfc8af88fa5","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":46.85},"color":{"xy":{"x":0.1562,"y":0.1626}}}}],"recall":{},"metadata":{"name":"Tokyo","image":{"rid":"60f088f5-4224-4f01-bcb1-81ef46099f63","rtype":"public_image"},"appdata":"TVwYJ_r05_d47"},"group":{"rid":"0c3872fc-9c14-4d02-8ebc-bb3a8c142aea","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.1753,"y":0.0585}},"dimming":{"brightness":46.85}},{"color":{"xy":{"x":0.1562,"y":0.1626}},"dimming":{"brightness":46.85}},{"color":{"xy":{"x":0.2676,"y":0.103}},"dimming":{"brightness":46.85}},{"color":{"xy":{"x":0.5894,"y":0.2589}},"dimming":{"brightness":46.85}},{"color":{"xy":{"x":0.5614,"y":0.406}},"dimming":{"brightness":46.85}}],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":455},"dimming":{"brightness":46.85}}],"effects":[]},"speed":0.6904761904761905,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"6eca2075-75a8-4d14-b177-976c0c426607","id_v1":"/scenes/VIBIQueA1ZSh5GA","actions":[{"target":{"rid":"b5b0089f-01cc-405e-9301-b9abe27ad3e9","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":346}}},{"target":{"rid":"32d0c787-5bd2-40dc-b4d6-f229493a12e3","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":346}}},{"target":{"rid":"1aaafabd-dc30-4f56-b2d4-9ec90b982383","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":346}}},{"target":{"rid":"9b925046-9253-4a70-af58-9cfc8af88fa5","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":100.0},"color_temperature":{"mirek":346}}}],"recall":{},"metadata":{"name":"Read","image":{"rid":"e101a77f-9984-4f61-aac8-15741983c656","rtype":"public_image"},"appdata":"a-cPB_r05_d02"},"group":{"rid":"0c3872fc-9c14-4d02-8ebc-bb3a8c142aea","rtype":"room"},"palette":{"color":[],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":346},"dimming":{"brightness":100.0}}],"effects":[]},"speed":0.6031746031746031,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"64231865-c6eb-4774-a17a-a2f83b6f4ded","id_v1":"/scenes/8ThMcLZHnR7Fcsd","actions":[{"target":{"rid":"b5b0089f-01cc-405e-9301-b9abe27ad3e9","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":0.0},"color":{"xy":{"x":0.561,"y":0.4042}}}},{"target":{"rid":"32d0c787-5bd2-40dc-b4d6-f229493a12e3","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":0.0},"color":{"xy":{"x":0.561,"y":0.4042}}}},{"target":{"rid":"1aaafabd-dc30-4f56-b2d4-9ec90b982383","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":0.0},"color":{"xy":{"x":0.561,"y":0.4042}}}},{"target":{"rid":"9b925046-9253-4a70-af58-9cfc8af88fa5","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":0.0},"color":{"xy":{"x":0.561,"y":0.4042}}}}],"recall":{},"metadata":{"name":"Nightlight","image":{"rid":"28bbfeff-1a0c-444e-bb4b-0b74b88e0c95","rtype":"public_image"},"appdata":"HLsEI_r05_d07"},"group":{"rid":"0c3872fc-9c14-4d02-8ebc-bb3a8c142aea","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.561,"y":0.4042}},"dimming":{"brightness":0.0}}],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":500},"dimming":{"brightness":0.0}}],"effects":[]},"speed":0.6031746031746031,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"},{"id":"0f706420-c976-4004-b399-b6b1ec563d1e","id_v1":"/scenes/MFaSS-RlKjaKC-p","actions":[{"target":{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":53.94},"color":{"xy":{"x":0.2354,"y":0.1746}}}},{"target":{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":53.94},"color":{"xy":{"x":0.2915,"y":0.286}}}},{"target":{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":53.94},"color":{"xy":{"x":0.2388,"y":0.1814}}}},{"target":{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":29.92},"color":{"xy":{"x":0.2403,"y":0.1844}}}},{"target":{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":53.54},"color":{"xy":{"x":0.2346,"y":0.1731}}}},{"target":{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":53.54},"color":{"xy":{"x":0.2915,"y":0.286}}}},{"target":{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":53.54},"color":{"xy":{"x":0.2346,"y":0.1731}}}},{"target":{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},"action":{"on":{"on":true},"dimming":{"brightness":53.54},"color":{"xy":{"x":0.2346,"y":0.1731}}}}],"recall":{},"metadata":{"name":"Arctic aurora","image":{"rid":"1e42b2e8-d02e-40d2-9c8d-b1fd8216c686","rtype":"public_image"},"appdata":"4ZxpE_r01_d17"},"group":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"palette":{"color":[{"color":{"xy":{"x":0.2072,"y":0.4525}},"dimming":{"brightness":25.98}},{"color":{"xy":{"x":0.1868,"y":0.3348}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.2376,"y":0.1797}},"dimming":{"brightness":100.0}},{"color":{"xy":{"x":0.1581,"y":0.1508}},"dimming":{"brightness":25.98}},{"color":{"xy":{"x":0.1541,"y":0.0844}},"dimming":{"brightness":25.98}}],"dimming":[],"color_temperature":[{"color_temperature":{"mirek":286},"dimming":{"brightness":25.98}}],"effects":[]},"speed":0.6388888888888888,"auto_dynamic":false,"status":{"active":"inactive"},"type":"scene"}]}
2023-07-29 20:11:38.265 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - GET https://10.163.199.253/clip/v2/resource/device HTTP/2
2023-07-29 20:11:38.311 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - HTTP/2 200 OK (Content-Type: application/json) << {"errors":[],"data":[{"id":"ee1aa624-91b6-41f9-9921-e3ae2bae291d","id_v1":"/lights/4","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 4","archetype":"ceiling_round"},"identify":null,"services":[{"rid":"3f746425-6c0f-4192-9540-9a85b7dd04db","rtype":"light"},{"rid":"06c12063-18bd-423d-b6d7-6a1b1d53ebc3","rtype":"zigbee_connectivity"},{"rid":"bba7de72-9cda-40d6-820e-6d6da529539f","rtype":"entertainment"}],"type":"device"},{"id":"0c18b50b-572f-4f50-ad3e-476293accd7b","id_v1":"/lights/8","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 8","archetype":"ceiling_round"},"identify":null,"services":[{"rid":"58a9dd84-310a-44f8-b641-e555807e6bf4","rtype":"light"},{"rid":"4a30a959-6dbb-40e4-9025-002ae82d0b53","rtype":"zigbee_connectivity"},{"rid":"fe7f4fb7-9340-4133-bdda-e4bf786bd187","rtype":"entertainment"}],"type":"device"},{"id":"d7aa1d72-009f-4b8d-a28f-798da9d7b33f","id_v1":"/lights/6","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 6","archetype":"ceiling_round"},"identify":{},"services":[{"rid":"5666c6f5-71ab-478a-bd59-1308142cd999","rtype":"light"},{"rid":"82e0f4b2-ea5f-4442-bc3f-a0e2bbc1886d","rtype":"zigbee_connectivity"},{"rid":"911bf558-1307-4978-a7cd-16f008d11691","rtype":"entertainment"}],"type":"device"},{"id":"fb032c0c-4187-4f93-9bab-3ae1c3dc5567","id_v1":"/lights/7","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 7","archetype":"ceiling_round"},"identify":{},"services":[{"rid":"a7967b2a-bdb2-4b7c-955d-b54d363efabc","rtype":"light"},{"rid":"97a64528-2dc7-425e-b2b8-7f72f6dbefed","rtype":"zigbee_connectivity"},{"rid":"eb56af30-4886-4e2c-8f34-08094d2abff8","rtype":"entertainment"}],"type":"device"},{"id":"42328b03-94e3-441c-a1e1-a174efff6f73","id_v1":"/lights/10","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Riley Light 2","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"d9871d5d-02a0-4158-8b47-596f917b6340","rtype":"light"},{"rid":"98a1b4ef-43e0-4a43-9229-64e9e69dec12","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"6485b533-3d67-429c-89ff-e7ba813513f6","id_v1":"/lights/1","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 1","archetype":"ceiling_round"},"identify":{},"services":[{"rid":"224d33d8-ceb7-4a8d-a3c9-3c71c9996a59","rtype":"light"},{"rid":"33278fd3-2358-42af-9383-2fe19a5e4ce0","rtype":"zigbee_connectivity"},{"rid":"5c2f5a73-f01d-4319-90b1-fa2adf16543a","rtype":"entertainment"}],"type":"device"},{"id":"3f922aa6-2647-483c-bb3f-c32ec8d7cce6","id_v1":"/lights/11","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Riley Light 3","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"2e657fe9-fd81-43b4-b4ec-c057ff00fbe1","rtype":"light"},{"rid":"12e799cd-216f-454d-8075-705da92445a1","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"4a1f8a73-3543-41f4-b4d9-173dc03747f5","id_v1":"/lights/3","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 3","archetype":"ceiling_round"},"identify":{},"services":[{"rid":"8b0ca755-f39a-40cb-b46b-b538aec29091","rtype":"light"},{"rid":"6cec8768-bb8d-4c9e-8370-865eeb413312","rtype":"zigbee_connectivity"},{"rid":"3bef0fff-efb9-46db-ba83-6f4ea04ce9a8","rtype":"entertainment"}],"type":"device"},{"id":"805f6b62-aa16-4be4-9342-c6f1932110a7","product_data":{"model_id":"BSB002","manufacturer_name":"Signify Netherlands B.V.","product_name":"Philips hue","product_archetype":"bridge_v2","certified":true,"software_version":"1.59.1959097030"},"metadata":{"name":"Philips hue","archetype":"bridge_v2"},"identify":{},"services":[{"rid":"a9d28cc5-ff01-40d0-afe7-f7c9e5205571","rtype":"bridge"},{"rid":"5fa5b437-8bb2-4a44-9807-89b1968673cf","rtype":"zigbee_connectivity"},{"rid":"30aef9de-ff7b-4cc3-b7f3-8549449fe4fd","rtype":"entertainment"},{"rid":"132d8d68-ad52-4175-8f92-f69aa1e4e584","rtype":"zigbee_device_discovery"}],"type":"device"},{"id":"5d89d53f-165b-49ef-a2e5-34590fbe6fc4","id_v1":"/lights/15","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Ethan Light 2","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"32d0c787-5bd2-40dc-b4d6-f229493a12e3","rtype":"light"},{"rid":"c183b49c-2800-4169-8416-3c523af95532","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"45dd7454-2ae9-4a9b-90ca-b89e39023cbf","id_v1":"/lights/14","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Ethan Light 1","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"b5b0089f-01cc-405e-9301-b9abe27ad3e9","rtype":"light"},{"rid":"37e50047-bff8-4f1e-b087-fd38fee4baaf","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"6865d13e-18a1-4511-8fa3-c8251ce5cc3e","id_v1":"/lights/16","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Ethan Light 3","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"1aaafabd-dc30-4f56-b2d4-9ec90b982383","rtype":"light"},{"rid":"a995e64d-a6c5-4e8f-98f8-25a70027563a","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"9bb57c71-2a47-4eaf-a915-e55c7ac78d5b","id_v1":"/lights/2","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 2","archetype":"ceiling_round"},"identify":{},"services":[{"rid":"c00eff47-e666-4ff7-86c2-51f11fe8e713","rtype":"light"},{"rid":"ffc936d4-978d-402a-854c-a5da60ca3ad7","rtype":"zigbee_connectivity"},{"rid":"f1b0189d-a5db-438a-8f15-4d0c4f30904c","rtype":"entertainment"}],"type":"device"},{"id":"1a76d0a1-8dfb-404b-b6ba-3f5565405a85","id_v1":"/lights/17","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Ethan Light 4","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"9b925046-9253-4a70-af58-9cfc8af88fa5","rtype":"light"},{"rid":"a48c9eed-e507-4c28-ad06-415031300aec","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"18d47ab1-36fd-4c0f-8206-a95969f6b8b9","id_v1":"/lights/5","product_data":{"model_id":"LCT003","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue color spot","product_archetype":"spot_bulb","certified":true,"software_version":"67.101.2","hardware_platform_type":"100b-104"},"metadata":{"name":"Hue color spot 5","archetype":"ceiling_round"},"identify":{},"services":[{"rid":"164226b9-c8b2-485a-b8d8-269ca60019e1","rtype":"light"},{"rid":"b091836b-3d15-469c-b708-8e2c24da3997","rtype":"zigbee_connectivity"},{"rid":"258b4219-5502-4ed1-ac2d-bb5cef292196","rtype":"entertainment"}],"type":"device"},{"id":"9ca6fe80-e5f2-4ea9-bcbe-f2c5ff565d53","id_v1":"/lights/12","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Riley Light 4","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"06236f4d-3175-4609-8cd5-fdf5764ad615","rtype":"light"},{"rid":"5d0c5385-37cb-4a18-a1c5-180aed0a7c38","rtype":"zigbee_connectivity"}],"type":"device"},{"id":"cf8dbe0f-fc9a-4ac3-a5c8-743e5beed749","id_v1":"/lights/18","product_data":{"model_id":"ZB-RGBCW","manufacturer_name":"JunYu","product_name":"Extended color light","product_archetype":"classic_bulb","certified":false,"software_version":"2.0.1"},"metadata":{"name":"Riley Light 1","archetype":"classic_bulb"},"identify":{},"services":[{"rid":"6d1f0ce1-acfb-410c-866e-9c2a94a3c01b","rtype":"light"},{"rid":"86d6eebd-0e47-4321-ac28-719b97cbbcec","rtype":"zigbee_connectivity"}],"type":"device"}]}
2023-07-29 20:11:38.316 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - GET https://10.163.199.253/clip/v2/resource/room HTTP/2
2023-07-29 20:11:38.376 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - HTTP/2 200 OK (Content-Type: application/json) << {"errors":[],"data":[{"id":"0c3872fc-9c14-4d02-8ebc-bb3a8c142aea","id_v1":"/groups/5","children":[{"rid":"1a76d0a1-8dfb-404b-b6ba-3f5565405a85","rtype":"device"},{"rid":"45dd7454-2ae9-4a9b-90ca-b89e39023cbf","rtype":"device"},{"rid":"5d89d53f-165b-49ef-a2e5-34590fbe6fc4","rtype":"device"},{"rid":"6865d13e-18a1-4511-8fa3-c8251ce5cc3e","rtype":"device"}],"services":[{"rid":"f5f2fa98-94f2-4f60-977b-a8a4f454e6aa","rtype":"grouped_light"}],"metadata":{"name":"Ethan","archetype":"bedroom"},"type":"room"},{"id":"a781070d-57b2-433a-815f-2059eb63dacc","id_v1":"/groups/4","children":[{"rid":"3f922aa6-2647-483c-bb3f-c32ec8d7cce6","rtype":"device"},{"rid":"42328b03-94e3-441c-a1e1-a174efff6f73","rtype":"device"},{"rid":"9ca6fe80-e5f2-4ea9-bcbe-f2c5ff565d53","rtype":"device"},{"rid":"cf8dbe0f-fc9a-4ac3-a5c8-743e5beed749","rtype":"device"}],"services":[{"rid":"f1b79c17-908f-4d06-8450-46b6c4761b33","rtype":"grouped_light"}],"metadata":{"name":"Riley","archetype":"bedroom"},"type":"room"},{"id":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","id_v1":"/groups/1","children":[{"rid":"0c18b50b-572f-4f50-ad3e-476293accd7b","rtype":"device"},{"rid":"18d47ab1-36fd-4c0f-8206-a95969f6b8b9","rtype":"device"},{"rid":"4a1f8a73-3543-41f4-b4d9-173dc03747f5","rtype":"device"},{"rid":"6485b533-3d67-429c-89ff-e7ba813513f6","rtype":"device"},{"rid":"9bb57c71-2a47-4eaf-a915-e55c7ac78d5b","rtype":"device"},{"rid":"d7aa1d72-009f-4b8d-a28f-798da9d7b33f","rtype":"device"},{"rid":"ee1aa624-91b6-41f9-9921-e3ae2bae291d","rtype":"device"},{"rid":"fb032c0c-4187-4f93-9bab-3ae1c3dc5567","rtype":"device"}],"services":[{"rid":"ba365fdb-f055-410c-9021-561b725cdc22","rtype":"grouped_light"}],"metadata":{"name":"Lounge","archetype":"living_room"},"type":"room"}]}
2023-07-29 20:11:38.376 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - GET https://10.163.199.253/clip/v2/resource/zone HTTP/2
2023-07-29 20:11:38.389 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - HTTP/2 200 OK (Content-Type: application/json) << {"errors":[],"data":[]}
2023-07-29 20:11:38.428 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - GET https://10.163.199.253/clip/v2/resource/bridge_home HTTP/2
2023-07-29 20:11:38.428 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - GET https://10.163.199.253/clip/v2/resource/grouped_light/ba365fdb-f055-410c-9021-561b725cdc22 HTTP/2
2023-07-29 20:11:38.443 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - HTTP/2 200 OK (Content-Type: application/json) << {"errors":[],"data":[{"id":"bd9983ea-ce23-447e-95a8-cfd02bd037d7","id_v1":"/groups/0","children":[{"rid":"805f6b62-aa16-4be4-9342-c6f1932110a7","rtype":"device"},{"rid":"0c3872fc-9c14-4d02-8ebc-bb3a8c142aea","rtype":"room"},{"rid":"a781070d-57b2-433a-815f-2059eb63dacc","rtype":"room"},{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"}],"services":[{"rid":"c766b174-536e-4a2d-bc62-e3365c5229ae","rtype":"grouped_light"}],"type":"bridge_home"}]}
2023-07-29 20:11:38.453 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - HTTP/2 200 OK (Content-Type: application/json) << {"errors":[],"data":[{"id":"ba365fdb-f055-410c-9021-561b725cdc22","id_v1":"/groups/1","owner":{"rid":"dc30bab1-66e9-4b8e-9d9d-8725a770c515","rtype":"room"},"on":{"on":true},"dimming":{"brightness":84.64999999999999},"dimming_delta":null,"color_temperature":null,"color_temperature_delta":{},"color":{},"alert":{"action_values":["breathe"]},"signaling":{"signal_values":["no_signal","on_off"]},"dynamics":{},"type":"grouped_light"}]}
2023-07-29 20:11:52.394 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2023-07-29T18:11:52Z","data":[{"id":"82e0f4b2-ea5f-4442-bc3f-a0e2bbc1886d","id_v1":"/lights/6","owner":{"rid":"d7aa1d72-009f-4b8d-a28f-798da9d7b33f","rtype":"device"},"status":"connected","type":"zigbee_connectivity"}],"id":"30abfc29-5050-4f50-bc4a-eeb0289db666","type":"update"}]
2023-07-29 20:11:52.395 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2023-07-29T18:11:52Z","data":[{"id":"82e0f4b2-ea5f-4442-bc3f-a0e2bbc1886d","id_v1":"/lights/6","owner":{"rid":"d7aa1d72-009f-4b8d-a28f-798da9d7b33f","rtype":"device"},"status":"connected","type":"zigbee_connectivity"}],"id":"30abfc29-5050-4f50-bc4a-eeb0289db666","type":"update"}]
2023-07-29 20:12:04.225 [TRACE] [penhab.binding.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2023-07-29T18:12:04Z","data":[{"id":"ffc936d4-978d-402a-854c-a5da60ca3ad7","id_v1":"/lights/2","owner":{"rid":"9bb57c71-2a47-4eaf-a915-e55c7ac78d5b","rtype":"device"},"status":"connected","type":"zigbee_connectivity"}],"id":"c6e43d23-484e-4755-989f-260a01af9fbb","type":"update"}]
2023-07-29 20:12:07.052 [DEBUG] [penhab.binding.hue.internal.connection.Clip2Bridge] - checkAlive()
2023-07-29 20:12:07.054 [DEBUG] [penhab.binding.hue.internal.connection.Clip2Bridge] - checkAliveOk()
Mark
Only the Hue standard effects will show up in the UI. As you say, it is possible for users to create your own ‘effects’ (aka dynamic effects). However the Hue API v2 does not seem to allow OH to discover such user created dynamic effects, so therefore currently it is not possible for OH to command such effects to be activated. (this is the same issue as mentioned by @jlaur)
https://developers.meethue.com/forum/t/502-error-on-https-developers-meethue-com/6929
I am running OH 4.0.1 with Hue CLIP2 API. I have only 1 Hue bridge and nothing connects using V1 api.
After running fine for a 3 days with the lights and a switch turned on and off many times, I suddenly could not turn off the lights. The message in the log was:
2023-08-06 22:54:56.252 [WARN ] [.hue.internal.connection.Clip2Bridge] - Fatal error SessionListenerAdapter GO_AWAY => closing session.
2023-08-06 23:14:28.025 [WARN ] [e.internal.handler.Clip2ThingHandler] - Command 'OFF' for thing 'hue:device:1:ThStueplanStueHueVenstreLampe', channel 'hue:device:1:ThStueplanStueHueVenstreLampe:color' failed with error 'Unexpected Content-Type: text/html'.
2023-08-06 23:14:28.076 [WARN ] [e.internal.handler.Clip2ThingHandler] - Command 'OFF' for thing 'hue:device:1:ThStueplanStueHueHojreLampe', channel 'hue:device:1:ThStueplanStueHueHojreLampe:color' failed with error 'Unexpected Content-Type: text/html'.
2023-08-06 23:14:28.487 [WARN ] [e.internal.handler.Clip2ThingHandler] - Command 'OFF' for thing 'hue:device:1:ThStueplanStueStikkontakt', channel 'hue:device:1:ThStueplanStueStikkontakt:switch' failed with error 'Unexpected Content-Type: text/html'.
2023-08-06 23:14:29.026 [WARN ] [.hue.internal.connection.Clip2Bridge] - Fatal error SessionListenerAdapter RESET => closing session.
After that the Hue binding and other Hue Things are Offline in the OH UI. The error message in the UI is:
COMMUNICATION_ERROR
An unexpected exception occurred during execution.
and I not able to turn any lights on or off. After a restart of OH everything works again.
In these 3 days running OH nothing has been changed in hardware or OH configuration.
Actually, I had the same error once in OH 4.0.0 also after a few days, but I thought the fixes brought to 4.0.1 might have solved it - apparently it did not.
I now stopped my regularly OH reboots (you remember … because of Homekit Issues? :slight_smile: ).
Now I am facing new challenges:
When using the HUE Dimmer Switches and Wall-Switches I have the impression that binding is loosing the connection to the Bridge (fixed IP) after a while, because Dimmer Triggers are not recognized anymore. No log entry, nothing.
But the HUE-App on iPhone still shows that button was pressed.
When I disable/enable the HUE-binding in OH it is working again immediately. How can I troubleshoot this? Any ideas?
I am also observing the ‘Unexpected Content Type’ error, as reported here. I think that the following PR – once merged – will prevent a large part of these errors. However on my own system I do still occasionally observe it even after that fix. I am not entirely sure what is going on, so if you guys can give more context on your error cases, it would help me greatly.
See my post above. The fix is indeed to disable/reenable the bridge thing.
I havent yet figured out why the binding internal restart mechansism fails in case of ‘Unexpected Content Type’ errors, whereas disable/enable (‘hammer’ restart) does work. Nor have I figured out why the error occurs in the first place. So if you can supply any more context about your error cases, it would be much appreciated.
