Philips Hue Lamps?
Hello
I would like to bind the Hue Lamps, found this
Bind Hue
but can not follow the bind of the Hue bridge to openHAB, do not get a message during start up?
Thanks in advance.
  • I need the binding - file, but I do not understand Github… I am finding so many different files, do not get the point… ??
The binding is at the same place where all bindings are: in the addon zip.
Hi
Yes I found it, sometimes you can not see the tree in the forest…
ok, copied the binding into openhab/addons folder, restart of the PI
Hmm, how can I see the Logging of openHAB on the Pi ?
Pressing the button on the Hue bridge still nothing.
Richard
I can see in the openhab.log that there was a asking for the button on the Hue bridge.
How can I see on the PI monitor, what happens in the log, when is it asking for the button ?
[quote=“Richard_Nussdorfer, post:3, topic:3716, full:true”]
how can I see the Logging of openHAB on the Pi ?[/quote]
I can see in the openhab.log …[/quote]
Why are you asking if you know where to look? :astonished:
NO, sorry you don’t understand.
I can not see the osgi-console on the pi, I can just open the log file manually.
→ can not see the question from the binding - press the button.
But, I already solved it.
  • deleting the binding file
  • stopping runtime of openhab on the pi
  • starting runtime of openhab on the pi → now I can see the Logging
  • copy the binding file → binding code starts
  • now I can see the question for the button → pressed and it works now.
I did’t ready that the binding just works once. Had no visual logging on the Pi, so a little bit tricky for a beginner.
Still the question how can I see (open) the osgi-console ?
PS: I do not delete written words - then everyone can see my step or conclusions I made
[quote=“Richard_Nussdorfer, post:5, topic:3716, full:true”]
PS: I do not delete written words - then everyone can see my step or conclusions I made[/quote]
That is good, but it is not good if you just edit your old post!
That is confusing.
You should edit a post when you have made a typo error or pasted a wrong link.
If you want to add information just open a new post in your existing thread and quote the part you are referring to.
aren’t these post normaly merged, always different between forums
normaly I do a hash in front, 2 hashes next and so on
but in this forum:
#hash has a code behind here…
