Hi Michael,
I too noticed that the UI at times does not update and needs to be manually refreshed. I have the same issue also with graphs at times. Not pretty (the need to have to refresh), but it may help to locate what is working and what not. And wait for the next release.
Hope this helps
I’m also having the same problem, but for me refreshing the UI (basic and android) does not help. I can see in the events log that the change in the light state has been noted. Could it have anything to do with the fact that the update status returned is “hue_0210_001788268cf2_6_color changed from 231,86,0 to 231,86,66” rather than an ON/OFF state?
Have a similar issue here when items are being switched on/off via external app or switch (eg. Hue App):
items with thing Id 210 are being updated
items with thing Id 0000 or 0010 (Switches) are not being updated
There is no log entry either for items where status is not being updated. My configuration seems to be right since I can control all items via openhab2. When controlled with openhab2, status also changes accordingly. Issue is effective with external controls only.
