Still on âactivatingâ â see below
openhabian@openhabian:~ $ systemctl status deconz
â deconz.service - deCONZ: ZigBee gateway -- REST API
Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: e
Active: activating (auto-restart) (Result: exit-code) since Mon 2021-06-28 07
Main PID: 1425 (code=exited, status=127)
Tasks: 0 (limit: 840)
CGroup: /system.slice/deconz.service
actually not yet, I started it manually but I added it now.
thats everything I found: (character limit)
-- The unit deconz-init.service has successfully entered the 'dead' state.
Jun 28 08:02:19 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
-- Subject: A start job for unit deconz-init.service has finished successfully
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- A start job for unit deconz-init.service has finished successfully.
-- The job identifier is 1829.
Jun 28 08:02:48 openhabian systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Jun 28 08:02:48 openhabian systemd[1]: deconz.service: Scheduled restart job, restart counter is at 14.
-- Subject: Automatic restarting of a unit has been scheduled
-- Automatic restarting of the unit deconz.service has been scheduled, as the result for
-- the configured Restart= setting for the unit.
Jun 28 08:02:48 openhabian systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
-- Subject: A start job for unit deconz-init.service has begun execution
-- A start job for unit deconz-init.service has begun execution.
-- The job identifier is 1895.
Jun 28 08:02:48 openhabian systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
-- Subject: A stop job for unit deconz.service has finished
-- A stop job for unit deconz.service has finished.
-- The job identifier is 1832 and the job result is done.
Jun 28 08:02:48 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
-- Subject: A start job for unit deconz.service has finished successfully
-- A start job for unit deconz.service has finished successfully.
-- The job identifier is 1832.
Jun 28 08:02:48 openhabian deCONZ[2880]: /usr/bin/deCONZ: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Jun 28 08:02:48 openhabian systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
-- Subject: Unit process exited
-- An ExecStart= process belonging to unit deconz.service has exited.
-- The process' exit code is 'exited' and its exit status is 127.
Jun 28 08:02:48 openhabian systemd[1]: deconz.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- The unit deconz.service has entered the 'failed' state with result 'exit-code'.
Jun 28 08:02:48 openhabian deCONZ-init.sh[2879]: stopping deconz-wifi.service
Jun 28 08:02:48 openhabian systemd[1]: Reloading.
Jun 28 08:02:49 openhabian systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid â /run/samba/nmbd.pid; please update the unit file accordingly.
Jun 28 08:02:49 openhabian systemd[1]: deconz-init.service: Succeeded.
-- Subject: Unit succeeded
Jun 28 08:02:49 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
Jun 28 08:03:19 openhabian systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Jun 28 08:03:19 openhabian systemd[1]: deconz.service: Scheduled restart job, restart counter is at 15.
-- A new seat seat0 has been configured and is now available.
Jun 28 07:55:32 openhabian kernel: 8021q: 802.1Q VLAN Support v1.8
Jun 28 07:55:32 openhabian systemd-logind[421]: Watching system buttons on /dev/input/event0 (vc4)
Jun 28 07:55:32 openhabian dphys-swapfile[417]: want /var/swap=1820MByte, checking existing: keeping it
Jun 28 07:55:32 openhabian deCONZ[387]: /usr/bin/deCONZ: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Jun 28 07:55:32 openhabian kernel: zram: Added device: zram0
Jun 28 07:55:32 openhabian systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Jun 28 07:55:32 openhabian systemd[1]: deconz.service: Failed with result 'exit-code'.
Jun 28 07:55:32 openhabian avahi-daemon[416]: Successfully called chroot().
Jun 28 07:55:32 openhabian avahi-daemon[416]: Successfully dropped remaining capabilities.
Jun 28 07:55:32 openhabian loadcpufreq[385]: Loading cpufreq kernel modules...done (none).
Jun 28 07:55:32 openhabian avahi-daemon[416]: No service file found in /etc/avahi/services.
Jun 28 07:55:32 openhabian avahi-daemon[416]: Network interface enumeration completed.
Jun 28 07:55:32 openhabian avahi-daemon[416]: Server startup complete. Host name is openhabian.local. Local service cookie is 1496181856.
Jun 28 07:55:32 openhabian wpa_supplicant[411]: Successfully initialized wpa_supplicant
Jun 28 07:55:32 openhabian kernel: zram0: detected capacity change from 0 to 471859200
Jun 28 07:55:32 openhabian systemd[1]: Started LSB: Load kernel modules needed to enable cpufreq scaling.
-- Subject: A start job for unit loadcpufreq.service has finished successfully
-- The job identifier is 84.
Jun 28 07:55:32 openhabian deCONZ-init.sh[398]: stopping deconz-wifi.service
Jun 28 07:55:32 openhabian systemd[1]: Started Login Service.
-- Subject: A start job for unit systemd-logind.service has finished successfully
-- The job identifier is 129.
Jun 28 07:55:33 openhabian systemd[1]: deconz-init.service: Succeeded.
Jun 28 07:55:33 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
-- The job identifier is 127.
Jun 28 07:55:33 openhabian systemd[1]: Stopping System Logging Service...
-- Subject: A stop job for unit rsyslog.service has begun execution
-- The unit systemd-fsckd.service has successfully entered the 'dead' state.
Jun 28 07:56:15 openhabian systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Jun 28 07:56:15 openhabian systemd[1]: deconz.service: Scheduled restart job, restart counter is at 1.
Jun 28 07:56:15 openhabian systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 783 and the job result is done.
Jun 28 07:56:15 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 783.
Jun 28 07:56:15 openhabian systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
-- The job identifier is 847.
Jun 28 07:56:15 openhabian deCONZ[1425]: /usr/bin/deCONZ: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Jun 28 07:56:15 openhabian systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Jun 28 07:56:15 openhabian systemd[1]: deconz.service: Failed with result 'exit-code'.
Jun 28 07:56:15 openhabian deCONZ-init.sh[1426]: stopping deconz-wifi.service
Jun 28 07:56:15 openhabian systemd[1]: Reloading.
Jun 28 07:56:16 openhabian systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid â /run/samba/nmbd.pid; please update the unit file accordingly.
Jun 28 07:56:16 openhabian systemd[1]: getty@tty1.service: Current command vanished from the unit file, execution of the command list won't be resumed.
Jun 28 07:56:16 openhabian systemd[1]: deconz-init.service: Succeeded.
Jun 28 07:56:16 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
Jun 28 07:56:19 openhabian systemd[1]: systemd-hostnamed.service: Succeeded.
-- The unit systemd-hostnamed.service has successfully entered the 'dead' state.
Jun 28 07:56:22 openhabian frontail[801]: tail: '/var/log/openhab/openhab.log' has been replaced; following new file
Jun 28 07:56:22 openhabian frontail[801]: tail: '/var/log/openhab/events.log' has been replaced; following new file
Jun 28 07:56:45 openhabian systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Jun 28 07:56:45 openhabian systemd[1]: deconz.service: Scheduled restart job, restart counter is at 2.
Jun 28 07:56:45 openhabian systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 849 and the job result is done.
Jun 28 07:56:45 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 849.
Jun 28 07:56:45 openhabian deCONZ[1523]: /usr/bin/deCONZ: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Jun 28 07:56:45 openhabian systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
-- The job identifier is 912.
Jun 28 07:56:45 openhabian systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Jun 28 07:56:45 openhabian systemd[1]: deconz.service: Failed with result 'exit-code'.
Jun 28 07:56:45 openhabian deCONZ-init.sh[1524]: stopping deconz-wifi.service
Jun 28 07:56:45 openhabian systemd[1]: Reloading.
Jun 28 07:56:46 openhabian systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid â /run/samba/nmbd.pid; please update the unit file accordingly.
Jun 28 07:56:47 openhabian systemd[1]: deconz-init.service: Succeeded.
Jun 28 07:56:47 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
Jun 28 07:57:16 openhabian systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Jun 28 07:57:16 openhabian systemd[1]: deconz.service: Scheduled restart job, restart counter is at 3.
Jun 28 07:57:16 openhabian systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 915 and the job result is done.
Jun 28 07:57:16 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 915.
Jun 28 07:57:16 openhabian systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
-- The job identifier is 979.
Jun 28 07:57:16 openhabian deCONZ[1610]: /usr/bin/deCONZ: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Jun 28 07:57:16 openhabian systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Jun 28 07:57:16 openhabian systemd[1]: deconz.service: Failed with result 'exit-code'.
Jun 28 07:57:16 openhabian deCONZ-init.sh[1611]: stopping deconz-wifi.service
Jun 28 07:57:16 openhabian systemd[1]: Reloading.
Jun 28 07:57:16 openhabian systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid â /run/samba/nmbd.pid; please update the unit file accordingly.
Jun 28 07:57:17 openhabian systemd[1]: deconz-init.service: Succeeded.
Jun 28 07:57:17 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
Jun 28 07:57:39 openhabian sudo[1717]: openhabian : TTY=pts/0 ; PWD=/home/openhabian ; USER=root ; COMMAND=/usr/bin/journalctl -xb
Jun 28 07:57:39 openhabian sudo[1717]: pam_unix(sudo:session): session opened for user root by openhabian(uid=0)
Jun 28 07:57:46 openhabian systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Jun 28 07:57:46 openhabian systemd[1]: deconz.service: Scheduled restart job, restart counter is at 4.
Jun 28 07:57:46 openhabian systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 981 and the job result is done.
Jun 28 07:57:46 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 981.
Jun 28 07:57:46 openhabian systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
-- The job identifier is 1045.
Jun 28 07:57:46 openhabian deCONZ[1726]: /usr/bin/deCONZ: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Jun 28 07:57:46 openhabian systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Jun 28 07:57:46 openhabian systemd[1]: deconz.service: Failed with result 'exit-code'.
Jun 28 07:57:46 openhabian deCONZ-init.sh[1727]: stopping deconz-wifi.service
Jun 28 07:57:46 openhabian systemd[1]: Reloading.
Jun 28 07:57:46 openhabian systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid â /run/samba/nmbd.pid; please update the unit file accordingly.
Jun 28 07:57:47 openhabian systemd[1]: deconz-init.service: Succeeded.
Jun 28 07:57:47 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
Jun 28 07:58:16 openhabian systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Jun 28 07:58:16 openhabian systemd[1]: deconz.service: Scheduled restart job, restart counter is at 5.
Jun 28 07:58:16 openhabian systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
-- The job identifier is 1111.
Jun 28 07:58:16 openhabian systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1047 and the job result is done.
Jun 28 07:58:16 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1047.
Jun 28 07:58:16 openhabian deCONZ[1762]: /usr/bin/deCONZ: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Jun 28 07:58:16 openhabian systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Jun 28 07:58:16 openhabian systemd[1]: deconz.service: Failed with result 'exit-code'.
Jun 28 07:58:16 openhabian deCONZ-init.sh[1761]: stopping deconz-wifi.service
Jun 28 07:58:16 openhabian systemd[1]: Reloading.
Jun 28 07:58:17 openhabian systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid â /run/samba/nmbd.pid; please update the unit file accordingly.
Jun 28 07:58:17 openhabian systemd[1]: deconz-init.service: Succeeded.
Jun 28 07:58:17 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
Jun 28 07:58:46 openhabian systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Jun 28 07:58:46 openhabian systemd[1]: deconz.service: Scheduled restart job, restart counter is at 6.
Jun 28 07:58:46 openhabian systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1113 and the job result is done.
Jun 28 07:58:46 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1113.
Jun 28 07:58:46 openhabian systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
-- The job identifier is 1177.
Jun 28 07:58:46 openhabian deCONZ[1800]: /usr/bin/deCONZ: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Jun 28 07:58:46 openhabian systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Jun 28 07:58:46 openhabian systemd[1]: deconz.service: Failed with result 'exit-code'.
Jun 28 07:58:46 openhabian deCONZ-init.sh[1801]: stopping deconz-wifi.service
Jun 28 07:58:46 openhabian systemd[1]: Reloading.
Jun 28 07:58:47 openhabian systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid â /run/samba/nmbd.pid; please update the unit file accordingly.
Jun 28 07:58:47 openhabian systemd[1]: deconz-init.service: Succeeded.
Jun 28 07:58:47 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
Jun 28 07:59:17 openhabian systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Jun 28 07:59:17 openhabian systemd[1]: deconz.service: Scheduled restart job, restart counter is at 7.
Jun 28 07:59:17 openhabian systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1179 and the job result is done.
Jun 28 07:59:17 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1179.
Jun 28 07:59:17 openhabian systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
-- The job identifier is 1242.
Jun 28 07:59:17 openhabian deCONZ[1838]: /usr/bin/deCONZ: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Jun 28 07:59:17 openhabian systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Jun 28 07:59:17 openhabian systemd[1]: deconz.service: Failed with result 'exit-code'.
Jun 28 07:59:17 openhabian deCONZ-init.sh[1839]: stopping deconz-wifi.service
Jun 28 07:59:17 openhabian systemd[1]: Reloading.
Jun 28 07:59:17 openhabian systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid â /run/samba/nmbd.pid; please update the unit file accordingly.
Jun 28 07:59:17 openhabian systemd[1]: deconz-init.service: Succeeded.
Jun 28 07:59:17 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
Jun 28 07:59:47 openhabian systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Jun 28 07:59:47 openhabian systemd[1]: deconz.service: Scheduled restart job, restart counter is at 8.
Jun 28 07:59:47 openhabian systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1245 and the job result is done.
Jun 28 07:59:47 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1245.
Jun 28 07:59:47 openhabian systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
-- The job identifier is 1309.
Jun 28 07:59:47 openhabian deCONZ[1875]: /usr/bin/deCONZ: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Jun 28 07:59:47 openhabian systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Jun 28 07:59:47 openhabian systemd[1]: deconz.service: Failed with result 'exit-code'.
Jun 28 07:59:47 openhabian deCONZ-init.sh[1876]: stopping deconz-wifi.service
Jun 28 07:59:47 openhabian systemd[1]: Reloading.
Jun 28 07:59:47 openhabian systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid â /run/samba/nmbd.pid; please update the unit file accordingly.
Jun 28 07:59:48 openhabian systemd[1]: deconz-init.service: Succeeded.
Jun 28 07:59:48 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
Jun 28 07:59:48 openhabian systemd[1]: Starting Daily apt download activities...
-- Subject: A start job for unit apt-daily.service has begun execution
-- A start job for unit apt-daily.service has begun execution.
-- The job identifier is 1311.
Jun 28 07:59:58 openhabian dbus-daemon[393]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service' requested by ':1.21' (uid=0 pid=2623 comm="/usr/bin/gdbus call --system --dest org.freedesk
Jun 28 07:59:58 openhabian systemd[1]: Starting PackageKit Daemon...
-- Subject: A start job for unit packagekit.service has begun execution
-- A start job for unit packagekit.service has begun execution.
-- The job identifier is 1374.
Jun 28 07:59:58 openhabian PackageKit[2626]: daemon start
Jun 28 07:59:58 openhabian dbus-daemon[393]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.23' (uid=0 pid=2626 comm="/usr/lib/packagekit/packagekitd ")
Jun 28 07:59:58 openhabian systemd[1]: Starting Authorization Manager...
-- Subject: A start job for unit polkit.service has begun execution
-- A start job for unit polkit.service has begun execution.
-- The job identifier is 1438.
Jun 28 07:59:58 openhabian polkitd[2630]: started daemon version 0.105 using authority implementation `local' version `0.105'
Jun 28 07:59:58 openhabian dbus-daemon[393]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Jun 28 07:59:58 openhabian systemd[1]: Started Authorization Manager.
-- Subject: A start job for unit polkit.service has finished successfully
-- A start job for unit polkit.service has finished successfully.
Jun 28 07:59:58 openhabian dbus-daemon[393]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Jun 28 07:59:58 openhabian systemd[1]: Started PackageKit Daemon.
-- Subject: A start job for unit packagekit.service has finished successfully
-- A start job for unit packagekit.service has finished successfully.
Jun 28 08:00:17 openhabian systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Jun 28 08:00:17 openhabian systemd[1]: deconz.service: Scheduled restart job, restart counter is at 9.
Jun 28 08:00:17 openhabian systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1502 and the job result is done.
Jun 28 08:00:17 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1502.
Jun 28 08:00:17 openhabian systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
-- The job identifier is 1565.
Jun 28 08:00:17 openhabian deCONZ[2666]: /usr/bin/deCONZ: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Jun 28 08:00:17 openhabian systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Jun 28 08:00:17 openhabian systemd[1]: deconz.service: Failed with result 'exit-code'.
Jun 28 08:00:17 openhabian deCONZ-init.sh[2667]: stopping deconz-wifi.service
Jun 28 08:00:17 openhabian systemd[1]: Reloading.
Jun 28 08:00:18 openhabian systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid â /run/samba/nmbd.pid; please update the unit file accordingly.
Jun 28 08:00:18 openhabian systemd[1]: deconz-init.service: Succeeded.
Jun 28 08:00:18 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
Jun 28 08:00:25 openhabian systemd[1]: apt-daily.service: Succeeded.
-- The unit apt-daily.service has successfully entered the 'dead' state.
Jun 28 08:00:25 openhabian systemd[1]: Started Daily apt download activities.
-- Subject: A start job for unit apt-daily.service has finished successfully
-- A start job for unit apt-daily.service has finished successfully.
Jun 28 08:00:47 openhabian systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Jun 28 08:00:47 openhabian systemd[1]: deconz.service: Scheduled restart job, restart counter is at 10.
Jun 28 08:00:47 openhabian systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1568 and the job result is done.
Jun 28 08:00:47 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1568.
Jun 28 08:00:47 openhabian systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
-- The job identifier is 1632.
Jun 28 08:00:47 openhabian deCONZ[2705]: /usr/bin/deCONZ: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Jun 28 08:00:47 openhabian systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Jun 28 08:00:47 openhabian systemd[1]: deconz.service: Failed with result 'exit-code'.
Jun 28 08:00:47 openhabian deCONZ-init.sh[2706]: stopping deconz-wifi.service
Jun 28 08:00:47 openhabian systemd[1]: Reloading.
Jun 28 08:00:48 openhabian systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid â /run/samba/nmbd.pid; please update the unit file accordingly.
Jun 28 08:00:48 openhabian systemd[1]: deconz-init.service: Succeeded.
Jun 28 08:00:48 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
Jun 28 08:01:18 openhabian systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Jun 28 08:01:18 openhabian systemd[1]: deconz.service: Scheduled restart job, restart counter is at 11.
Jun 28 08:01:18 openhabian systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
-- The job identifier is 1698.
Jun 28 08:01:18 openhabian systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1634 and the job result is done.
Jun 28 08:01:18 openhabian systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
-- The job identifier is 1634.
Jun 28 08:01:18 openhabian deCONZ[2756]: /usr/bin/deCONZ: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Jun 28 08:01:18 openhabian systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Thats a lot to read, I think the interesting parts are:
The rest of it repeats a lot
