Phoscon/deCONZ on openHABian
Hello folks,
any chance to install Phoscon/deCONZ on same RPi running openHABian?
Thanks!
I did it! You have to change the deconz services file so the deconz port is something other than 8080. But it does work
short yes it does!
Long: Do the following steps in the command line
grafik
grafik
grafik
-> now change this part “–http-port=??” to your favorite port, and save this nano file
-> reboot your system
Now you can discover your GateWay the same way as described in the manual.
cheers
Hannes
The new wget is
wget http://deconz.dresden-elektronik.de/raspbian/deconz-latest.deb
Anyone to use this please help with integrating it with openHABian.
