Fresh OpenHabian install on Raspberry Pi 4.
Image:
openhabian-pi-raspios32-202010031354-git535d54d-crc0cf8e591.img.xz
Module: https://www.amazon.com/Z-Wave-Me-RaZberry2-Plug-Raspberry-frequency/dp/B01M3Q764U
Light is on, fitted properly. Fresh out of the box.
OS
## Ip = Unable to parse ip . Please debug.
## Release = Raspbian GNU/Linux 10 (buster)
## Kernel = Linux 5.4.72-v7l+
## Platform = Raspberry Pi 4 Model B Rev 1.2
## Uptime = 0 day(s). 0:0:49
## CPU Usage = 52.28% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
## CPU Load = 1m: 2.23, 5m: 0.65, 15m: 0.23
## Memory = Free: 3.30GB (87%), Used: 0.48GB (13%), Total: 3.78GB
## Swap = Free: 2.58GB (100%), Used: 0.00GB (0%), Total: 2.58GB
## Root = Free: 23.55GB (84%), Used: 4.29GB (16%), Total: 29.07GB
## Updates = 0 apt updates available.
## Sessions = 1 session(s)
## Processes = 128 running processes of 32768 maximum processes
Hardware:
sudo lshw -short
H/W path Device Class Description
system Raspberry Pi 4 Model B Rev 1.2
/0 bus Motherboard
/0/1 processor cpu
/0/2 processor cpu
/0/3 processor cpu
/0/4 processor cpu
/0/5 memory 3877MiB System memory
/0/0 bridge Broadcom Limited
/0/0/0 bus VL805 USB 3.0 Host Controller
/0/0/0/0 usb1 bus xHCI Host Controller
/0/0/0/0/1 bus USB2.0 Hub
/0/0/0/1 usb2 bus xHCI Host Controller
/1 wlan0 network Wireless interface
/2 eth0 network Ethernet interface
Java:
openjdk version "1.8.0_265"
OpenJDK Runtime Environment (Zulu 8.48.3.246-CA-linux_aarch32hf) (build 1.8.0_265-b11)
OpenJDK Client VM (Zulu 8.48.3.246-CA-linux_aarch32hf) (build 25.265-b11, mixed mode)
OpenHab:
openhab-cli info
Version: 2.5.10 (Build)
User: openhab (Active Process 777)
User Groups: openhab tty dialout audio bluetooth gpio
Directories: Folder Name | Path | User:Group
OPENHAB_HOME | /usr/share/openhab2 | openhab:openhab
OPENHAB_RUNTIME | /usr/share/openhab2/runtime | openhab:openhab
OPENHAB_USERDATA | /var/lib/openhab2 | openhab:openhab
OPENHAB_CONF | /etc/openhab2 | openhab:openhab
OPENHAB_LOGDIR | /var/log/openhab2 | openhab:openhab
URLs: http://192.168.88.248:8080
https://192.168.88.248:8443
Serials:
(snipped)
crw--w---- 1 root tty 4, 9 Nov 7 17:17 tty9
crw-rw---- 1 root dialout 204, 64 Nov 7 17:17 ttyAMA0
crw------- 1 root root 5, 3 Nov 7 17:17 ttyprintk
crw-rw---- 1 root dialout 4, 64 Nov 7 17:17 ttyS0
crw------- 1 root root 10, 239 Nov 7 17:17 uhid
dmesg -T | grep tty
[Sat Nov 7 17:17:38 2020] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 smsc95xx.macaddr=DC:A6:32:96:F7:26 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 console=tty1 root=PARTUUID=1b839919-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[Sat Nov 7 17:17:38 2020] printk: console [tty1] enabled
[Sat Nov 7 17:17:39 2020] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
[Sat Nov 7 17:17:39 2020] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 30, base_baud = 62500000) is a 16550
/etc/default/openhab2:
## JAVA OPTIONS
## Additional options for the JAVA_OPTS environment variable.
## These will be appended to the execution of the openHAB Java runtime in front of all other options.
## A couple of independent examples:
EXTRA_JAVA_OPTS="-Xms192m -Xmx320m"
EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyUSB1:/dev/ttyS0:/dev/ttyS2:/dev/ttyACM0:/dev/ttyAMA0"
Config:
- openhabian-conflg: both options to disable serial are selected and executed.
- Z-Wave binding specifies tttyS0 as the port.
- /dev/ttyAMA0 port doesn’t work either
- uart=1 is set in /boot/config.txt
- openhab is part of the dialout group
- Switching to master branch makes no difference
Logs:
2020-11-07 16:58:50.384 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-11-07 16:58:52.753 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.88.248:8080
2020-11-07 16:58:52.759 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.88.248:8443
2020-11-07 16:58:53.862 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-11-07 16:58:54.062 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2020-11-07 16:58:54.284 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2020-11-07 16:59:04.017 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-11-07 16:59:09.533 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-11-07 16:59:09.535 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-11-07 17:13:24.986 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-11-07 17:13:24.988 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-11-07 17:13:35.091 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-11-07 17:13:35.093 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-11-07 17:18:49.678 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-11-07 17:18:52.684 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.88.248:8080
2020-11-07 17:18:52.694 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.88.248:8443
2020-11-07 17:18:53.854 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-11-07 17:18:54.051 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2020-11-07 17:18:54.328 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2020-11-07 17:19:04.067 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-11-07 17:19:09.585 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-11-07 17:19:09.587 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-11-08 01:08:11.398 [thome.event.ExtensionEvent] - Extension 'package-standard' has been installed.
2020-11-08 01:08:19.156 [thome.event.ExtensionEvent] - Extension 'ui-homebuilder' has been installed.
2020-11-08 01:08:19.159 [thome.event.ExtensionEvent] - Extension 'ui-basic' has been installed.
2020-11-08 01:08:19.161 [thome.event.ExtensionEvent] - Extension 'ui-habpanel' has been installed.
2020-11-08 01:08:19.163 [thome.event.ExtensionEvent] - Extension 'ui-paper' has been installed.
2020-11-08 01:13:01.547 [thome.event.ExtensionEvent] - Extension 'binding-zwave' has been installed.
2020-11-08 01:14:13.811 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f4155d95' changed from UNINITIALIZED to INITIALIZING
2020-11-08 01:14:13.911 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f4155d95' has been updated.
2020-11-08 01:14:13.914 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f4155d95' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-11-08 01:14:35.785 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f4155d95' has been updated.
2020-11-08 01:14:59.525 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f4155d95' has been updated.
2020-11-08 01:24:47.873 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f4155d95' has been updated.
2020-11-07 16:59:04.410 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f4155d95' changed from UNINITIALIZED to INITIALIZING
2020-11-07 16:59:04.435 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f4155d95' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-11-07 17:13:19.692 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f4155d95' has been updated.
2020-11-07 17:13:29.819 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f4155d95' has been updated.
2020-11-07 17:19:04.468 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f4155d95' changed from UNINITIALIZED to INITIALIZING
2020-11-07 17:19:04.490 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f4155d95' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
After going into CLI and setting log to monitor the Z-Wave binding:
sudo openhab-cli console
log:set DEBUG org.openhab.binding.zwave
2020-11-07 18:39:03.254 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyS0'
2020-11-07 18:39:03.283 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Starting receive thread
2020-11-07 18:39:03.290 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Starting ZWave thread: Receive
2020-11-07 18:39:03.293 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2020-11-07 18:39:03.294 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initialising ZWave controller
2020-11-07 18:39:03.343 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-11-07 18:39:03.343 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-11-07 18:39:03.344 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-11-07 18:39:03.345 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-11-07 18:39:03.347 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2020-11-07 18:39:03.350 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2020-11-07 18:39:03.353 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Scheduling network mesh heal for 8 hours time.
2020-11-07 18:39:06.347 [DEBUG] [.ZWaveController$InitializeDelayTask] - Initialising network
2020-11-07 18:39:06.374 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 0 to queue - size 1
2020-11-07 18:39:06.375 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-11-07 18:39:06.385 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 15 E9
2020-11-07 18:39:06.387 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 15 E9
2020-11-07 18:39:06.390 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-11-07 18:39:06.392 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 0: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2020-11-07 18:39:06.398 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 1 to queue - size 1
2020-11-07 18:39:06.399 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-11-07 18:39:06.404 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 2 to queue - size 2
2020-11-07 18:39:06.405 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-11-07 18:39:06.409 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 3 to queue - size 3
2020-11-07 18:39:06.411 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-11-07 18:39:06.414 [DEBUG] [rialmessage.GetSucNodeIdMessageClass] - Get SUC NodeID
2020-11-07 18:39:06.416 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 4 to queue - size 4
2020-11-07 18:39:06.418 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-11-07 18:39:08.395 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 255: TID 0: Timeout at state WAIT_RESPONSE. 3 retries remaining.
2020-11-07 18:39:08.396 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 0: Transaction is current transaction, so clearing!!!!!
2020-11-07 18:39:08.398 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 0: Transaction CANCELLED
2020-11-07 18:39:08.405 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:0 CANCELLED
2020-11-07 18:39:08.426 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-11-07 18:39:08.428 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 20 DC
2020-11-07 18:39:08.430 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 20 DC
2020-11-07 18:39:08.432 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-11-07 18:39:08.433 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 1: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2020-11-07 18:39:10.434 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 255: TID 1: Timeout at state WAIT_RESPONSE. 3 retries remaining.
2020-11-07 18:39:10.436 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 1: Transaction is current transaction, so clearing!!!!!
2020-11-07 18:39:10.437 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1: Transaction CANCELLED
2020-11-07 18:39:10.438 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:1 CANCELLED
2020-11-07 18:39:10.440 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-11-07 18:39:10.443 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 07 FB
2020-11-07 18:39:10.445 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 07 FB
2020-11-07 18:39:10.446 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-11-07 18:39:10.448 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 2: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2020-11-07 18:39:12.449 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 255: TID 2: Timeout at state WAIT_RESPONSE. 3 retries remaining.
2020-11-07 18:39:12.451 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 2: Transaction is current transaction, so clearing!!!!!
2020-11-07 18:39:12.452 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2: Transaction CANCELLED
2020-11-07 18:39:12.453 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:2 CANCELLED
2020-11-07 18:39:12.455 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-11-07 18:39:12.458 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 06 96 0F 65
2020-11-07 18:39:12.460 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 06 96 0F 65
2020-11-07 18:39:12.461 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-11-07 18:39:12.462 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 3: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2020-11-07 18:39:14.464 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 255: TID 3: Timeout at state WAIT_RESPONSE. 3 retries remaining.
2020-11-07 18:39:14.465 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 3: Transaction is current transaction, so clearing!!!!!
2020-11-07 18:39:14.466 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 3: Transaction CANCELLED
2020-11-07 18:39:14.467 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:3 CANCELLED
2020-11-07 18:39:14.469 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-11-07 18:39:14.473 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 56 AA
2020-11-07 18:39:14.474 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 56 AA
2020-11-07 18:39:14.476 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-11-07 18:39:14.477 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 4: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2020-11-07 18:39:16.478 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 255: TID 4: Timeout at state WAIT_RESPONSE. 3 retries remaining.
2020-11-07 18:39:16.480 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 4: Transaction is current transaction, so clearing!!!!!
2020-11-07 18:39:16.481 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 4: Transaction CANCELLED
2020-11-07 18:39:16.483 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:4 CANCELLED
2020-11-07 18:39:16.485 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
After installing Z-Way as an alternative:
Raspberry Pi 4B Detected. Setting up miniUART for Bluetooth
Adding 'dtoverlay=pi3-miniuart-bt' to /boot/config.txt
Usage: ./z-cfg-update <filename>
Starting z-way-server: done.
Setting up webif (1.2) ...
[ ok ] Starting mongoose (via systemctl): mongoose.service.
Setting up zbw (1.2) ...
tail: cannot open '/etc/init.d/zbw_connect' for reading: No such file or directory
chmod: cannot access 'zbw_connect': No such file or directory
zbw_connect patched
/var/lib/dpkg/info/zbw.postinst: 94: /var/lib/dpkg/info/zbw.postinst: /etc/init.d/zbw_connect: Permission denied
--2020-11-07 18:00:03-- https://find.z-wave.me/zbw_new_user
Resolving find.z-wave.me (find.z-wave.me)... 185.25.224.206, 194.190.114.100, 46.20.244.72, ...
Connecting to find.z-wave.me (find.z-wave.me)|185.25.224.206|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/octet-stream]
Saving to: ‘/tmp/zbw_connect_setup.run’
/tmp/zbw_connect_se [ <=> ] 6.09K --.-KB/s in 0s
2020-11-07 18:00:05 (39.6 MB/s) - ‘/tmp/zbw_connect_setup.run’ saved [6240]
Do you want to enable the remote support(y/n)? Remote support NOT enabled
Now you can run zbw_connect with /etc/init.d/zbw_connect start
or simply reboot your system
Your user id: 167066
Your password: [ removed ]
[ ok ] Starting zbw_connect (via systemctl): zbw_connect.service.
zbw_autosetup.service is not a native service, redirecting to systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable zbw_autosetup
Setting up z-way-full (1.0-latest-version) ...
Processing triggers for systemd (241-7~deb10u4+rpi1) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for install-info (6.5.0.dfsg.1-4+b1) ...
Processing triggers for libc-bin (2.28-10+rpi1) ...
Updating FireMotD available updates count ...
Package configuration files were changes: /etc/zbw/userid /etc/zbw/passwd /etc/zbw/local_port
Keeping your changed configuration files
Endless manual reboots later: Status: OFFLINE - BRIDGE_OFFLINE Controller is offline
