Pi3 to Pi4 OH4 4.0.3
Hi All,
If I mirrored my SD card from my Pi3 running my OH 4.0.3 and the used this card in a new Pi4 machine, would it work? If you go on the lunix forums, they say you would have change the bootloader for a larger file.
Or should I say install a clean copy, and then copy over the files. Or use my amanda back up files to import the configs etc.
Well, the RPi forums are going to have more experts on this than exist here on this forum. I would believe those forums over anything you find here.
But, so long as you have a backup, give it a try and see what happens.
In general, I prefer a clean base OS install to migrating. Fewer problems are encountered over all.
Many thanks
