I’am using a Rasbberry Pi 3 B+ Debian for my openhab2.4 config. On top of it a Piface Digital 2.
I have added the piface1.2 binding in the “Paper UI”. Now the following messages will apear in the /var/log/openhab2/openhab.log file. Is there someone who can help me with a good binding of my Piface and has an example to switch a relais via the gui based on a time schedule for my garden lights? When i start searching for things in the gui the Piface won’t appear.
Regards,
DJ
2018-10-13 06:58:25.083 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to ‘nl_NL’.
2018-10-13 06:58:26.299 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.10.45:8080
2018-10-13 06:58:26.311 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.10.45:8443
2018-10-13 06:58:36.115 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-10-13 06:58:38.326 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-10-13 06:58:38.489 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-10-13 06:58:38.616 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-10-13 06:58:38.727 [INFO ] [ding.piface.internal.PifaceActivator] - Piface binding has been started.
2018-10-13 06:58:38.842 [INFO ] [b.core.service.AbstractActiveService] - PiFace Watchdog Service has been started
2018-10-13 06:58:38.838 [ERROR] [inding.piface.internal.PifaceBinding] - Piface Monitor Thread [piface2] failed
java.net.BindException: Adres is al in gebruik
at java.net.PlainDatagramSocketImpl.bind0(Native Method) ~[?:?]
at java.net.AbstractPlainDatagramSocketImpl.bind(AbstractPlainDatagramSocketImpl.java:94) [?:?]
at java.net.DatagramSocket.bind(DatagramSocket.java:392) [?:?]
at java.net.DatagramSocket.(DatagramSocket.java:242) [?:?]
at java.net.DatagramSocket.(DatagramSocket.java:299) [?:?]
at java.net.DatagramSocket.(DatagramSocket.java:271) [?:?]
at org.openhab.binding.piface.internal.PifaceBinding$PifaceNodeMonitor.run(PifaceBinding.java:505) [200:org.openhab.binding.piface:1.12.0]
2018-10-13 06:58:38.838 [ERROR] [inding.piface.internal.PifaceBinding] - Piface Monitor Thread [piface1] failed
