I tried to get the PiFace board running with OH2 based on latest Raspbian version (August 2017, Kernel 4.9), i did the following steps:
- install ohpiface according this HowTo:
Step 3 is outdated from my point of view, due to a device tree Raspi Kernel. But I checked the correct loaded module by
lsmod | grep spi_bcm2835
spi_bcm2835 7596 0
- I configured the only necessary entry in piface.cfg:
pifaceid1.host=192.168.178.24
- I created my items for the PiFace, e.g.:
Switch PifaceSwitch1 “Relay 1” (PiFace) { piface=“pifaceid1:OUT:0” }
- and in addition, based on a community discussion, I changed the user for the openhab service to root.
ps -aux
shows me, that the openhab is executed as root now. Output from px -aux:
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.4 5452 3912 ? Ss Aug22 0:06 /sbin/init
root 2 0.0 0.0 0 0 ? S Aug22 0:00 [kthreadd]
root 3 0.0 0.0 0 0 ? S Aug22 0:01 [ksoftirqd/0]
root 5 0.0 0.0 0 0 ? S< Aug22 0:00 [kworker/0:0H]
root 7 0.0 0.0 0 0 ? S Aug22 0:30 [rcu_sched]
root 8 0.0 0.0 0 0 ? S Aug22 0:00 [rcu_bh]
root 9 0.0 0.0 0 0 ? S Aug22 0:00 [migration/0]
root 10 0.0 0.0 0 0 ? S< Aug22 0:00 [lru-add-drain]
root 11 0.0 0.0 0 0 ? S Aug22 0:00 [cpuhp/0]
root 12 0.0 0.0 0 0 ? S Aug22 0:00 [cpuhp/1]
root 13 0.0 0.0 0 0 ? S Aug22 0:00 [migration/1]
root 14 0.0 0.0 0 0 ? S Aug22 0:00 [ksoftirqd/1]
root 16 0.0 0.0 0 0 ? S< Aug22 0:00 [kworker/1:0H]
root 17 0.0 0.0 0 0 ? S Aug22 0:00 [cpuhp/2]
root 18 0.0 0.0 0 0 ? S Aug22 0:00 [migration/2]
root 19 0.0 0.0 0 0 ? S Aug22 0:00 [ksoftirqd/2]
root 21 0.0 0.0 0 0 ? S< Aug22 0:00 [kworker/2:0H]
root 22 0.0 0.0 0 0 ? S Aug22 0:00 [cpuhp/3]
root 23 0.0 0.0 0 0 ? S Aug22 0:00 [migration/3]
root 24 0.0 0.0 0 0 ? S Aug22 0:02 [ksoftirqd/3]
root 26 0.0 0.0 0 0 ? S< Aug22 0:00 [kworker/3:0H]
root 27 0.0 0.0 0 0 ? S Aug22 0:00 [kdevtmpfs]
root 28 0.0 0.0 0 0 ? S< Aug22 0:00 [netns]
root 29 0.0 0.0 0 0 ? S Aug22 0:00 [khungtaskd]
root 30 0.0 0.0 0 0 ? S Aug22 0:00 [oom_reaper]
root 31 0.0 0.0 0 0 ? S< Aug22 0:00 [writeback]
root 32 0.0 0.0 0 0 ? S Aug22 0:00 [kcompactd0]
root 33 0.0 0.0 0 0 ? S< Aug22 0:00 [crypto]
root 34 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 35 0.0 0.0 0 0 ? S< Aug22 0:00 [kblockd]
root 36 0.0 0.0 0 0 ? S< Aug22 0:00 [watchdogd]
root 38 0.0 0.0 0 0 ? S< Aug22 0:00 [rpciod]
root 39 0.0 0.0 0 0 ? S< Aug22 0:00 [xprtiod]
root 40 0.0 0.0 0 0 ? S Aug22 0:00 [kswapd0]
root 41 0.0 0.0 0 0 ? S< Aug22 0:00 [vmstat]
root 42 0.0 0.0 0 0 ? S< Aug22 0:00 [nfsiod]
root 52 0.0 0.0 0 0 ? S< Aug22 0:00 [kthrotld]
root 53 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 54 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 55 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 56 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 57 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 58 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 59 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 60 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 61 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 62 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 63 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 64 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 65 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 66 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 67 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 68 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 69 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 70 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 71 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 72 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 73 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 74 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 75 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 76 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 77 0.0 0.0 0 0 ? S< Aug22 0:00 [iscsi_eh]
root 78 0.0 0.0 0 0 ? S< Aug22 0:00 [dwc_otg]
root 80 0.0 0.0 0 0 ? S< Aug22 0:00 [DWC Notificatio]
root 81 0.0 0.0 0 0 ? S< Aug22 0:00 [VCHIQ-0]
root 82 0.0 0.0 0 0 ? S< Aug22 0:00 [VCHIQr-0]
root 83 0.0 0.0 0 0 ? S< Aug22 0:00 [VCHIQs-0]
root 84 0.0 0.0 0 0 ? S Aug22 0:00 [VCHIQka-0]
root 85 0.0 0.0 0 0 ? S< Aug22 0:00 [SMIO]
root 87 0.0 0.0 0 0 ? S Aug22 0:00 [kworker/2:1]
root 89 0.0 0.0 0 0 ? S< Aug22 0:00 [bioset]
root 90 0.0 0.0 0 0 ? S Aug22 0:13 [mmcqd/0]
root 92 0.0 0.0 0 0 ? S Aug22 0:07 [jbd2/mmcblk0p2-]
root 93 0.0 0.0 0 0 ? S< Aug22 0:00 [ext4-rsv-conver]
root 94 0.0 0.0 0 0 ? S< Aug22 0:00 [ipv6_addrconf]
root 111 0.0 0.0 0 0 ? S< Aug22 0:00 [kworker/1:1H]
root 133 0.0 0.0 0 0 ? S Aug22 0:06 [kworker/2:2]
root 139 0.0 0.3 9928 3656 ? Ss Aug22 0:05 /lib/systemd/systemd-journald
root 142 0.0 0.3 11984 3044 ? Ss Aug22 0:00 /lib/systemd/systemd-udevd
root 194 0.0 0.0 0 0 ? S Aug22 0:00 [spi0]
root 341 0.0 0.0 0 0 ? S< Aug22 0:00 [cfg80211]
avahi 412 0.0 0.2 3996 2588 ? Ss Aug22 0:06 avahi-daemon: running [wassermelderpi.local]
root 413 0.0 0.2 32140 2664 ? Ssl Aug22 0:01 /usr/sbin/rsyslogd -n
root 416 0.0 0.2 5544 2396 ? Ss Aug22 0:00 /usr/sbin/cron -f
message+ 419 0.0 0.3 5488 2892 ? Ss Aug22 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork –
avahi 426 0.0 0.0 3872 244 ? S Aug22 0:00 avahi-daemon: chroot helper
root 458 0.0 0.0 0 0 ? S< Aug22 0:00 [kworker/3:1H]
root 459 0.0 0.2 3848 2444 ? Ss Aug22 0:00 /lib/systemd/systemd-logind
nobody 483 0.0 0.1 2288 1448 ? Ss Aug22 0:00 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/triggers
root 512 0.0 0.3 7152 2984 ? Ss Aug22 0:01 /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid
root 515 0.0 0.0 0 0 ? S< Aug22 0:00 [kworker/2:1H]
root 697 0.0 0.1 2560 1772 ? Ss Aug22 0:06 /sbin/dhcpcd -q -w
root 698 0.0 0.4 7860 4248 ? Ss Aug22 0:00 /usr/sbin/sshd -D
root 701 0.0 0.3 5316 2908 ? Ss Aug22 0:00 /bin/bash /usr/share/openhab2/runtime/bin/karaf server
root 732 0.0 0.1 4524 1756 tty1 Ss+ Aug22 0:00 /sbin/agetty --noclear tty1 linux
root 733 0.0 0.1 4344 1880 ? Ss+ Aug22 0:00 /sbin/agetty --keep-baud 115200 38400 9600 ttyAMA0 vt102
ntp 934 0.0 0.3 5772 3696 ? Ss Aug22 0:12 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -c /var/lib/ntp/ntp.c
root 994 0.0 0.7 23608 7412 ? Ss Aug22 0:19 /usr/sbin/nmbd -D
root 997 2.3 16.2 431240 153928 ? Sl Aug22 33:39 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.c
root 1020 0.0 1.3 36152 12480 ? Ss Aug22 0:07 /usr/sbin/smbd -D
root 1025 0.0 0.5 36152 5084 ? S Aug22 0:00 /usr/sbin/smbd -D
root 1074 0.0 0.0 0 0 ? S< Aug22 0:00 [kworker/0:1H]
root 1463 0.0 0.0 0 0 ? S Aug22 0:06 [kworker/1:0]
root 1465 0.0 0.0 0 0 ? S Aug22 0:00 [kworker/1:3]
root 19871 0.0 0.0 0 0 ? S 10:15 0:04 [kworker/0:2]
root 28776 0.1 0.0 0 0 ? R 17:21 0:08 [kworker/u8:1]
root 29465 0.0 0.0 0 0 ? S 17:46 0:01 [kworker/3:2]
root 30246 0.1 0.0 0 0 ? S 18:17 0:04 [kworker/u8:0]
root 30511 0.0 0.0 0 0 ? S 18:28 0:00 [kworker/0:1]
root 30652 0.0 0.5 12144 5244 ? Ss 18:34 0:00 sshd: pi [priv]
pi 30659 0.0 0.3 4972 3232 ? Ss 18:35 0:00 /lib/systemd/systemd --user
pi 30662 0.0 0.1 6880 1232 ? S 18:35 0:00 (sd-pam)
pi 30665 0.0 0.3 12144 3524 ? R 18:35 0:00 sshd: pi@pts/0
pi 30667 0.0 0.4 6768 4412 pts/0 Ss 18:35 0:02 -bash
openhab 30709 0.0 1.4 36956 13812 ? S 18:37 0:02 /usr/sbin/smbd -D
root 31548 0.1 0.0 0 0 ? S 19:07 0:01 [kworker/u8:2]
root 31581 0.0 0.0 0 0 ? S 19:08 0:00 [kworker/3:0]
pi 31811 0.0 0.2 5212 2136 pts/0 R+ 19:17 0:00 ps -aux
But nothing works
Here the openhab.log:
2017-08-23 19:16:13.515 [ERROR] [inding.piface.internal.PifaceBinding] - Failed to send command (3) to 192.168.178.24:15432 (attempt 2)
java.net.SocketTimeoutException: Receive timed out
at java.net.PlainDatagramSocketImpl.receive0(Native Method)[:1.8.0_121]
at java.net.AbstractPlainDatagramSocketImpl.receive(AbstractPlainDatagramSocketImpl.java:143)[:1.8.0_121]
at java.net.DatagramSocket.receive(DatagramSocket.java:812)[:1.8.0_121]
at org.openhab.binding.piface.internal.PifaceBinding.sendCommand(PifaceBinding.java:305)[181:org.openhab.binding.piface:1.10.0]
at org.openhab.binding.piface.internal.PifaceBinding.sendCommand(PifaceBinding.java:274)[181:org.openhab.binding.piface:1.10.0]
at org.openhab.binding.piface.internal.PifaceBinding.sendReadOutputPins(PifaceBinding.java:256)[181:org.openhab.binding.piface:1.10.0]
at org.openhab.binding.piface.internal.PifaceBinding.access$6(PifaceBinding.java:255)[181:org.openhab.binding.piface:1.10.0]
at org.openhab.binding.piface.internal.PifaceBinding$PifaceInitialiser.initialiseBindingConfigs(PifaceBinding.java:597)[181:org.openhab.binding.piface:1.10.0]
at org.openhab.binding.piface.internal.PifaceBinding$PifaceInitialiser.run(PifaceBinding.java:562)[181:org.openhab.binding.piface:1.10.0]
Strange… From my point of view, the ohpiface UDB server is not working / running. I could not find it in ps -aux
and I’m not sure, if the HowTo is working on a systemd based kernel. Does anybody has the same problems and can help me here?
Thanks!
