PiHole Binding run with ver6
Hello Everyone.
I have install phole 6. I haven’t seen a option to generate a key. How can i get the binding run?
Thank you for help
You can find a temporary workaround here: Pi-Hole Integration - #76 by DrRSatzteil
The API key setup might be different from previous versions. Check the admin panel under API settings or try running pihole -a -t in the terminal to see if there’s an option to generate a key and make sure the OpenHAB Pi-hole binding supports v6.
