Continuing the discussion from OH3: Integrate PI-Hole via HTTP-Binding using the UI:
Hi OH community,
as it took me some time to get PiHole status changes integrated well after updating to OH3 (changed HTTP binding) I’m happy to share here my new configuration.
Things
Thing http:url:pihole "pihole" [
baseURL="http://pihole.local/admin/api.php",
stateMethod="GET",
commandMethod="POST",
refresh=30,
ignoreSSLErrors=true,
contentType="application/json" ]
Channels:
Type switch : status "PiHole Status" [ stateTransformation="JSONPATH:$.status", onValue="enabled", offValue="disabled", commandTransformation="MAP:pihole.map", commandExtension="?%2$s&auth=xx <pihole api key> xxx" ]
pihole.map
enabled=enable
disabled=disable
Item
Switch PiHole_Status "Status [%s]" <pihole> { channel="http:url:pihole:status" }
Sitemap
Frame label="Pi-Hole" {
Switch item=PiHole_Status
The state of pihole will be up-to-date regardless if it get’s changed by WebUI or other programm because status updated every 30 sec. State change can be done by sitemap.
Hope this will save you some time
