So I’ve got Openhab working on a Pine64 A64+ using the 1.4.1 image and using ethernet. When I try to enable wifi using the official Pine64 hat (the one that came with the IOT bundle) it will not connect to my wifi network. I used openhabian-config to set up and have verified that my wpa_supplicant.conf file has the correct SSID and Password. Anything else I need to do to get this to work?
