Just downloaded the OpenHAB 2 image for a Pine64 (openhabianpine64-xenial-20170317) - for my first try at getting a Linux smart home controller.
Followed the tutorial… BUT it missed that
It skips the WiFi configuration and stucks if you have no Ethernet connected… (I have no ethernet close enough to where I have screen and keyboard to setup the Pine)
If you hammer the keyboard long enough - you can get it unstuck! Where I tried to run “sudo openhabian-config” to set the WiFi.
However - when running “sudo openhabian-config” - it asks for a password… I used the same that was given (openhabian) - but then I only get told that “command is not found”.
Consider me a clean slate on Linux - so without guidance I am in the dark.
I could not find any more information about this in the starting tutorials or FAQ - so now moving on to you guys.
Anyone knows how I should proceed to get it working with network? Thank you!
PS If I had my z-wave USB stick and 433Mhz controller inserted, it also stopped during booting claiming that the modem is not really a modem… or something like that.
