mjptec
(Mike Perry)
April 3, 2017, 7:18pm
22
OK. Just in case there is something you didn’t try, these are the steps I took:
Place latest snapshot in addon folder
Uninstall previous binding with Karaf
Add new autodetected thing
( pioneeravr:genericAvr:5F9EC1B3-ED59-79BB-4530-745e1c36735d ) -> Nothing working
Restart openhab -> Nothing working
Powercycle AVR -> All working
There might have been other OH restarts as well but that doesn’t matter.
Celaeno1
(Alex)
April 6, 2017, 6:36am
23
Which “latest snapshot” do you mean? 2016-12-22 SNAPSHOT or latest official snapshot? I tried official, no success!
Celaeno1
(Alex)
April 7, 2017, 7:30pm
24
@mjptec I made a complete new installation with Build #858 and copied 2016-12-22 SNAPSHOT into addons folder.
Now it’s running! Thanks a lot!
andirs
(Andi)
July 17, 2017, 6:58pm
25
Has anyone configured the 2016-12-22 SNAPSHOT in the things file?
pioneeravr:genericAvr:vsx924 "Pioneer VSX-924" [ ipAddress="192.168.1.12", tcpPort=23, useSerial="false" ]
does not work. This is what the discovered thing shows in the jsonDB.
A hint is appreciated. Thanks
Celaeno1
(Alex)
July 17, 2017, 7:11pm
26
Did you also try port 8102?
andirs
(Andi)
July 17, 2017, 7:26pm
27
Then the thing is “UNINITIALIZED - HANDLER_REGISTERING_ERROR”
Celaeno1
(Alex)
July 17, 2017, 9:03pm
28
Please try:
Power on AVR.
Then start openhab.
And be sure that you use correct IP address . There can be another for DLNA or Internetradio…
andirs
(Andi)
July 18, 2017, 5:56am
29
Thanks it works with
pioneeravr:genericAvr:vsx924 "Pioneer VSX-924" [ ipAddress="192.168.1.12", tcpPort=8102 ]
Strange however that it gets discovered with port 23 and then works with it, but not when adding the thing manually…
mimo74
(MiMo)
August 1, 2017, 5:33am
30
[PioneerAVR] Fix for Zone2 / Zone3
this fix addresses two issues:
commands on Zone2 and Zone3 where not working properly due to failing match with GROUP_CHANNEL_ZONE_PATTERN
Volume_Level on Zones where not interpreted correctly due to the AVR sending only 2 digits on zone volume rather than 3 digits on Zone1
Changes where tested on my SC-LX89
this should fix #1206
(as am i new to doing changes to openhab2-addons, Eclipse, Java and even GitHub chances are i got something on the way wrong… please let me know
Celaeno1
(Alex)
August 1, 2017, 6:43am
31
Hopefully this will run with my SC-LX72, too.
Celaeno1
(Alex)
August 1, 2017, 2:50pm
32
@mimo74 Do you have a compiled .jar ? So I could test it, too.
mimo74
(MiMo)
August 4, 2017, 12:38pm
33
mimo74
(MiMo)
August 4, 2017, 12:39pm
34
there is still an issue on setting the volume for zones. I’ll be having a look at that next week.
Celaeno1
(Alex)
August 7, 2017, 8:28am
36
@mimo74 I installed latest PioneerAVR binding and ZONE2/ZONE3 are detected correctly, now! Thanks a lot! The issue on “setting the volume for zones” does not bother me, because I have set the volume for ZONE2/ZONE3 to a “fixed” value.
See here:
Celaeno1
(Alex)
September 7, 2017, 1:39pm
37
BTW, the issue on “setting the volume for zones” should be fixed with this PR:
