I now have a simple solution for play the song at the last stopped position, when no other song was played between:
I check if the title is still the title of the song which always plays and if yes, send playpause to on. Else send the url and then the song begins from the beginning.
Can i do that with a playlist as well? Or can i make a folder inside LMS and only play the songs which are inside this folder?
Only one song gets boring with the time. I want to have a playlist or folder with many songs and play them with shuffle.
But how can i check inside a rule, if this playlist is playing? There is no item for âplaylistâ, only artist, title, âŚ
And how can i send a command to my squeezebox to play a special playlist or a song from a special folder? Can i send folder url or playlist url instead of direct path and name of the song?
If i can´t check for which playlist is active at the moment, i have to edit all of the mp3-tags of the songs to a special name, let´s say âopenhabâ and if âtitleâ openhab is playing, i can look for this?
That channel was added to the binding relatively recently (itâs included starting in build 1208). So, you need to have a very recent version of the binding. And, if your server and player things were added before that, they wonât have the new channel (nor do they automatically pick it up). The normal solution is to delete and rediscover/readd the squeezebox server and player things.
The playFavorite channel is a String, so you send it a string. The link I shared above explains how to use it.
When i´m playing a song and stop this song, all mp3-tag information about album, genre and artist is removed from the sitemap.
Only the mp3-tag âtitleâ is still visible.
Is this a bug?
Would be nice, if i could still see all information. Because when i send play/pause command, the song will start again, so the song is still saved somewhere in LMS.
EDIT:
Strange, now it seems, that the values will be kept in the itemsâŚ
