I’m trying to play an mp3 that starts trough a rule. This rule gets created with the UI using the “Rule DSL” feature.
The rule basically looks like this: playStream("enhancedjavasound", "http://icecast.vrtcdn.be/stubru-high.mp3")
This does not work. I hear a short pop coming out of the speakers, it feels like the stream starts, but gets aborted once the rule is done executing.
Playing a sound via playSound() works fine.
Also playing that same stream with the openhab-cli works perfectly fine.
True. enhancedjavasound is the default. Tried both solutions with and without, did not make a different.
Only difference I had was when the rule was created from the UI vs a rules file.
