i just tried to play a stream via openhab3 (radio). it works but i now tried to send also the volume together with the stream according to the Multimedia doc.
However i receive the following error message:
2021-06-21 23:50:19.418 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'default-17' failed: An error occurred during the script execution: Could not invoke method: org.openhab.core.model.script.actions.Audio.playStream(java.lang.String,java.lang.String) on instance: null in default
Any idea how this is related to my rule line? without the percentType it works…but without setting the volume specifically…Thanks Norbert
I don’t do anything with sound on openHAB so I can’t really say anything more than what is in the docs. But I would not be surprised if you didn’t have to set the volume first before starting the stream.
