I finally have some time to completely migrate my Windows XP pc running HouseBot to openHABian. I currently just have openhab 2.5 running as a virtual machine to control my visonic alarm. But, would like to wipe XP and use openHABian and migrate x10, plcbus, visonic, rfxcom, zigbee and amazon echos.
I can see that version 3 is out now, but the problem is that I use PLCBus and the plugin only seems to be available on version 1. Could I use version 3? or would I need to use the older version?
You can use version 3.0 as your main system, and install the remoteopenhab binding to connect the older openHAB version to your main 3.0 version.
This way you will get the benefits of the new openHAB 3.0 as your main instance while keeping all 1.x bindings running on another openHAB 2.5 instance.
