I tried removing that line as you suggested, then I noticed I got some errors in my log. I put the rule back to the way I had it and I got even more errors. Here they are:
2019-06-30 20:36:44.156 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home.rules' has errors, therefore ignoring it: [37,17]: missing '}' at 'case'
[44,17]: mismatched input 'default' expecting 'end'
Is [37,17] the column then line? What exactly does this error mean, there should be a } in column 37? What does the next error mean? In case it helps, here is what I am currently using for my rule:
rule "Lock: Update lock states after alarm_raw event"
Member of gLockRaw received update
val actionItem = ScriptServiceUtil.getItemRegistry.getItem(triggeringItem.name.toString.replace("_Alarm_Raw",""))
logInfo("Rules", "Lock: Alarm events: {}=[{}]",actionItem.name,triggeringItem.state.toString)
val StringBuilder message = new StringBuilder(actionItem.name)
switch (transform("JSONPATH","$.type",triggeringItem.state.toString)) {
case "ACCESS_CONTROL" : {
switch (transform("JSONPATH", "$.event", triggeringItem.state.toString)) {
case "18", case "21", case "24" : {
actionItem.postUpdate(ON)
message.append(" updated to ON (locked)")
case "19", case "22" : {
actionItem.postUpdate(OFF)
message.append(" updated to OFF (unlocked)")
/* case "6" : {
message.append(" was unlocked with")
switch (transform("JSONPATH", "$.code", triggeringItem.state.toString)) {
case "1" : {
message.append(" Scott's code")
case "2" : {
message.append(" Lisa's code")
case "26", case "17", case "23" : {
actionItem.postUpdate(OFF)// jammed could mean unlocked, so I do this for safety... you may want to send an alert here too
message.append(" is jammed, so setting lock to OFF (unlocked)")
message.append(" keypad is disabled due to too many failed codes")
default : {
message.append(" unknown door lock Event, ").append(triggeringItem.state.toString)
if (transform("JSONPATH", "$.event", triggeringItem.previousState(true).state.toString) == "26" && transform("JSONPATH", "$.event", triggeringItem.state.toString) != "26") {
message.append(" and is no longer jammed")
case "BURGLAR" : {
//gSiren.sendCommand(ON)
message.append(" has detected an intruder")
case "POWER_MANAGEMENT" : {
message.append(" received a Power Management alarm, ").append(triggeringItem.state.toString)
default : {
message.append(" received and unknown Type in alarmRawParser, ").append(triggeringItem.state.toString)
logInfo("Rules", "Lock: Alarm events: {}", message.toString)
